Elyes Haouas has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/69406 )
Change subject: nb/intel/i945: Use <commonlib/bsd/helpers.h> macros ......................................................................
Change-Id: I2cbf7aaa31a560b0259ec763322045b34b479e23 Signed-off-by: Elyes Haouas ehaouas@noos.fr --- M src/northbridge/intel/i945/i945.h M src/northbridge/intel/i945/memmap.c M src/northbridge/intel/i945/northbridge.c 3 files changed, 25 insertions(+), 13 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/06/69406/1
diff --git a/src/northbridge/intel/i945/i945.h b/src/northbridge/intel/i945/i945.h index 4818a73..b1f8efa 100644 --- a/src/northbridge/intel/i945/i945.h +++ b/src/northbridge/intel/i945/i945.h @@ -332,8 +332,8 @@ void dump_spd_registers(u8 spd_map[4]); void sdram_dump_mchbar_registers(void);
-u32 decode_igd_memory_size(u32 gms); -u32 decode_tseg_size(const u8 esmramc); +size_t decode_igd_memory_size(u32 gms); +size_t decode_tseg_size(const u8 esmramc);
/* Romstage mainboard callbacks */ /* Optional: Override the default LPC config. */ diff --git a/src/northbridge/intel/i945/memmap.c b/src/northbridge/intel/i945/memmap.c index 1fa0358..321b387 100644 --- a/src/northbridge/intel/i945/memmap.c +++ b/src/northbridge/intel/i945/memmap.c @@ -5,6 +5,7 @@
#include <arch/romstage.h> #include <cbmem.h> +#include <commonlib/bsd/helpers.h> #include <console/console.h> #include <cpu/x86/mtrr.h> #include <cpu/x86/smm.h> @@ -14,17 +15,17 @@ #include "i945.h"
/* Decodes TSEG region size to bytes. */ -u32 decode_tseg_size(const u8 esmramc) +size_t decode_tseg_size(const u8 esmramc) { if (!(esmramc & 1)) return 0; switch ((esmramc >> 1) & 3) { case 0: - return 1 << 20; + return 1 * MiB; case 1: - return 2 << 20; + return 2 * MiB; case 2: - return 8 << 20; + return 8 * MiB; case 3: default: die("Bad TSEG setting.\n"); @@ -64,14 +65,14 @@ }
/* Decodes used Graphics Mode Select (GMS) to kilobytes. */ -u32 decode_igd_memory_size(const u32 gms) +size_t decode_igd_memory_size(const u32 gms) { - static const u16 ggc2uma[] = { 0, 1, 4, 8, 16, 32, 48, 64 }; + static const size_t ggc2uma[] = { 0, 1, 4, 8, 16, 32, 48, 64 };
if (gms >= ARRAY_SIZE(ggc2uma)) die("Bad Graphics Mode Select (GMS) setting.\n");
- return ggc2uma[gms] << 10; + return ggc2uma[gms] * KiB; }
void smm_region(uintptr_t *start, size_t *size) diff --git a/src/northbridge/intel/i945/northbridge.c b/src/northbridge/intel/i945/northbridge.c index 3c5603c..651c3cf 100644 --- a/src/northbridge/intel/i945/northbridge.c +++ b/src/northbridge/intel/i945/northbridge.c @@ -14,7 +14,8 @@
static void mch_domain_read_resources(struct device *dev) { - uint32_t pci_tolm, tseg_sizek, cbmem_topk, delta_cbmem; + uint32_t pci_tolm, cbmem_topk, delta_cbmem; + size_t tseg_sizek; uint8_t tolud; uint16_t reg16; unsigned long long tomk, tomk_stolen; @@ -41,9 +42,9 @@ reg16 = pci_read_config16(d0f0, GGC); if (!(reg16 & 2)) { printk(BIOS_DEBUG, "IGD decoded, subtracting "); - int uma_size = decode_igd_memory_size((reg16 >> 4) & 7); + size_t uma_size = decode_igd_memory_size((reg16 >> 4) & 7);
- printk(BIOS_DEBUG, "%dM UMA\n", uma_size / KiB); + printk(BIOS_DEBUG, "%ld UMA\n", uma_size / KiB); tomk_stolen -= uma_size;
/* For reserving UMA memory in the memory map */ @@ -55,7 +56,7 @@ }
tseg_sizek = decode_tseg_size(pci_read_config8(d0f0, ESMRAMC)) / KiB; - printk(BIOS_DEBUG, "TSEG decoded, subtracting %dM\n", tseg_sizek / KiB); + printk(BIOS_DEBUG, "TSEG decoded, subtracting %ld\n", tseg_sizek / KiB); tomk_stolen -= tseg_sizek; tseg_memory_base = tomk_stolen * 1024ULL; tseg_memory_size = tseg_sizek * 1024ULL;
