Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9479
commit f9091651794f69369a7a7e5050cb42668bf23c7b Author: Wenkai Du wenkai.du@intel.com Date: Fri Dec 5 14:04:10 2014 -0800
broadwell: Fix incorrect SATA port map mask
WPT-LP has 4 SATA ports. Current code assumes 6 SATA ports and as a result, some reserved bits are written with 1. No specific issue has been observed so far.
BUG=None BRANCH=None TEST=Verify SATA PCI configure space dump on Auron
Change-Id: I737719b3d5cd788158cd5b6991405ba098be4078 Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: 2b55587a74ac5d45354dc123937b562290468855 Original-Change-Id: I9c53ac86e2bf72901647bd2cfa48ac0ce31abea0 Original-Signed-off-by: Wenkai Du wenkai.du@intel.com Original-Reviewed-on: https://chromium-review.googlesource.com/233661 Original-Reviewed-by: Duncan Laurie dlaurie@chromium.org --- src/soc/intel/broadwell/sata.c | 6 +++--- 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/src/soc/intel/broadwell/sata.c b/src/soc/intel/broadwell/sata.c index cfb3854..a41e900 100644 --- a/src/soc/intel/broadwell/sata.c +++ b/src/soc/intel/broadwell/sata.c @@ -65,7 +65,7 @@ static void sata_init(struct device *dev)
/* for AHCI, Port Enable is managed in memory mapped space */ reg16 = pci_read_config16(dev, 0x92); - reg16 &= ~0x3f; + reg16 &= ~0xf; reg16 |= 0x8000 | config->sata_port_map; pci_write_config16(dev, 0x92, reg16); udelay(2); @@ -84,7 +84,7 @@ static void sata_init(struct device *dev)
/* SATA Initialization register */ reg32 = 0x183; - reg32 |= (config->sata_port_map ^ 0x3f) << 24; + reg32 |= (config->sata_port_map ^ 0xf) << 24; reg32 |= (config->sata_devslp_mux & 1) << 15; pci_write_config32(dev, 0x94, reg32);
@@ -229,7 +229,7 @@ static void sata_enable(device_t dev) config_t *config = dev->chip_info; u16 map = 0x0060;
- map |= (config->sata_port_map ^ 0x3f) << 8; + map |= (config->sata_port_map ^ 0xf) << 8;
pci_write_config16(dev, 0x90, map); }
