Attention is currently required from: Nick Vaccaro, Subrata Banik.
Matt DeVillier has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/80178?usp=email )
Change subject: mb/google/hatch/var/jinlon: Ensure LCD backlight controls generated ......................................................................
Jinlon disables the eps device if no privacy screen is present, so add a second generic gfx device 'no_eps' to handle that case, so that ACPI backlight controls are generated either way. Add logic to ensure only one of the two devices is active.
TEST=build/boot Win11 on google/hatch (jinlon), ensure LCD backlight controls present and functional on device both with and without a privacy screen.
Change-Id: Icf20de97d26c8be76c84e87d5dc6ed1a4b6dbfbc Signed-off-by: Matt DeVillier matt.devillier@gmail.com --- M src/mainboard/google/hatch/variants/jinlon/mainboard.c M src/mainboard/google/hatch/variants/jinlon/overridetree.cb 2 files changed, 9 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/78/80178/1
diff --git a/src/mainboard/google/hatch/variants/jinlon/mainboard.c b/src/mainboard/google/hatch/variants/jinlon/mainboard.c index 51ef346..009a6ad 100644 --- a/src/mainboard/google/hatch/variants/jinlon/mainboard.c +++ b/src/mainboard/google/hatch/variants/jinlon/mainboard.c @@ -21,9 +21,11 @@ static void check_for_eps(uint32_t sku_id) { struct device *eps_dev = DEV_PTR(eps); + struct device *no_eps_dev = DEV_PTR(no_eps);
if (eps_sku(sku_id)) { printk(BIOS_INFO, "SKU ID %u has EPS\n", sku_id); + no_eps_dev->enabled = 0; return; }
diff --git a/src/mainboard/google/hatch/variants/jinlon/overridetree.cb b/src/mainboard/google/hatch/variants/jinlon/overridetree.cb index 82694a0..a4c29ca 100644 --- a/src/mainboard/google/hatch/variants/jinlon/overridetree.cb +++ b/src/mainboard/google/hatch/variants/jinlon/overridetree.cb @@ -70,7 +70,6 @@
device domain 0 on device ref igpu on - register "gfx" = "GMA_DEFAULT_PANEL(0)" chip drivers/gfx/generic register "device_count" = "1" register "device[0].name" = ""LCD0"" @@ -82,6 +81,13 @@ register "device[0].privacy.gpio" = "ACPI_GPIO_OUTPUT_ACTIVE_HIGH(GPP_E0)" device generic 0 alias eps on end end + chip drivers/gfx/generic + register "device_count" = "1" + register "device[0].name" = ""LCD0"" + # Internal panel on the first port of the graphics chip + register "device[0].addr" = "0x80010400" + device generic 1 alias no_eps on end + end end device ref xhci on chip drivers/usb/acpi
