Attention is currently required from: Angel Pons, Elyes Haouas, Felix Held, Felix Singer, Frans Hendriks, Jérémy Compostella, Maximilian Brune, Patrick Rudolph, Paul Menzel, Shuo Liu.
yuchi.chen@intel.com has posted comments on this change by yuchi.chen@intel.com. ( https://review.coreboot.org/c/coreboot/+/83321?usp=email )
Change subject: soc/intel/snowridge: Add support for Intel Atom Snow Ridge SoC ......................................................................
Patch Set 63:
(12 comments)
File src/soc/intel/snowridge/Kconfig:
https://review.coreboot.org/c/coreboot/+/83321/comment/7600e5a9_2a17ef32?usp... : PS28, Line 39: select FSP_CAR
Does native CAR work?
As Vasiliy replied to you in another comment, native CAR doesn't works on Snow Ridge.
File src/soc/intel/snowridge/acpi.c:
https://review.coreboot.org/c/coreboot/+/83321/comment/3e267b04_eeeb7607?usp... : PS60, Line 115: intel_write_pci_PRT(scope, pin_irq_map, map_count, &pirq_map);
The scope could be obtained from domain's device path, e.g. […]
Done
File src/soc/intel/snowridge/acpi/pcie.asl:
https://review.coreboot.org/c/coreboot/+/83321/comment/441356a6_519f544b?usp... : PS33, Line 235:
Are RP04, RP05, RP06, RP07 not implemented in Snow Ridge?
Yes in Snow Ridge there are 2 Root Port clusters, cluster 0 and cluster 2. Cluster 0 contains Root Port 0~4 and cluster 2 contains Root Port 8~11. In the latest patch the ACPI PRT method for Root Port is generated dynamically.
File src/soc/intel/snowridge/acpi/southcluster.asl:
https://review.coreboot.org/c/coreboot/+/83321/comment/ca9aee79_cfdec085?usp... : PS28, Line 13: // SATA Controller 0 : Device (SAT0) : { : Name (_ADR, 0x00070000) : Name (_DDN, "SATA Controller 0") : } : : // SATA Controller 2 : Device (SAT2) : { : Name (_ADR, 0x000e0000) : Name (_DDN, "SATA Controller 2") : } :
No SATA Controller 1?
Yes there are only SATA controller 0 and SATA controller 2 in Snow Ridge. They are only place holders thus I deleted them in the latest patch.
File src/soc/intel/snowridge/chip.c:
https://review.coreboot.org/c/coreboot/+/83321/comment/997b32a4_b4fb5643?usp... : PS28, Line 229: die("Please add domain 0 to device tree!\n");
Should be able to guarantee this using a chipset devicetree, btw.
In the latest patch the device tree is moved to `src/soc/intel/snowridge/chipset.cb`, mainboard only contains an empty device tree to pass compilation.
File src/soc/intel/snowridge/common/fsp_hob.h:
https://review.coreboot.org/c/coreboot/+/83321/comment/dfddb3d1_90d0f101?usp... : PS28, Line 10: extern const uint8_t fsp_hob_fia_override_status_guid[16];
Could use `guid_t` I believe: https://github. […]
Done
File src/soc/intel/snowridge/common/hob_display.c:
https://review.coreboot.org/c/coreboot/+/83321/comment/97c02057_13647006?usp... : PS28, Line 12: const void *guid;
Would be nice to use `guid_t` (well, `const guid_t *guid`): https://github. […]
Done
File src/soc/intel/snowridge/common/kti_cache.c:
PS28:
Does KTI refer to UPI (high-speed CPU interconnect links on server platforms), or is it something el […]
yes, in FSP output its call KTI. I think KTI is code name, and UPI is official name.
File src/soc/intel/snowridge/common/reset.c:
https://review.coreboot.org/c/coreboot/+/83321/comment/be381012_780f9544?usp... : PS28, Line 26: do_full_reset();
Does the CSE or SPS need to be notified about the global reset? This feels odd
Actually I'm not very familiar with this. I checked other `do_global_reset()` implementations, they called `cse_request_global_reset()` in `src/soc/intel/common/block/cse/cse.c`, but on Snow Ridge, we didn't use that common code.
File src/soc/intel/snowridge/cpu.c:
https://review.coreboot.org/c/coreboot/+/83321/comment/79a760d7_c7ad3111?usp... : PS28, Line 72: /** : * Skip Pre MP init MTRR programming as MTRRs are mirrored from BSP that are set prior to : * ramstage. Real MTRRs programming are being done after resource allocation. : */
nit: reflow comment to not exceed 96 characters per line […]
Done
File src/soc/intel/snowridge/heci.c:
https://review.coreboot.org/c/coreboot/+/83321/comment/5dd22fc8_795d46c5?usp... : PS28, Line 25: res->flags |= IORESOURCE_MEM;
Wouldn't `IORESOURCE_MEM` be set already? Or is it mutuallyy exclusive with `IORESOURCE_PCI64`?
`IORESOURCE_MEM` is removed.
File src/soc/intel/snowridge/include/soc/iomap.h:
https://review.coreboot.org/c/coreboot/+/83321/comment/e40688ed_3bfe5a0e?usp... : PS28, Line 13: @sa
Does this mean "see also"? Not sure
yes that's a conventional usage of Doxygen.
