Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/22247
Change subject: soc/amd: Pass number of buses to mmio_init ......................................................................
This patch lays the groundwork for a subsequent patch that will eliminate the amdlib functions from fixme.c.
Put the CONFIG value on the stack for amd_initmmio(). Eventually LibAmdBitScanReverse() will be replaced with fms() which doesn't work well with absolute values.
Change-Id: If875f46cff4cd8e63271939e122b22688552c4b4 Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com --- M src/soc/amd/common/agesawrapper.h M src/soc/amd/stoneyridge/bootblock/bootblock.c M src/soc/amd/stoneyridge/fixme.c 3 files changed, 4 insertions(+), 4 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/47/22247/1
diff --git a/src/soc/amd/common/agesawrapper.h b/src/soc/amd/common/agesawrapper.h index b42f531..a9e6209 100644 --- a/src/soc/amd/common/agesawrapper.h +++ b/src/soc/amd/common/agesawrapper.h @@ -51,7 +51,7 @@
VOID OemCustomizeInitEarly(IN OUT AMD_EARLY_PARAMS *InitEarly); VOID amd_initcpuio(void); -VOID amd_initmmio(void); +VOID amd_initmmio(size_t max_bus); const void *agesawrapper_locate_module(const CHAR8 name[8]);
void OemPostParams(AMD_POST_PARAMS *PostParams); diff --git a/src/soc/amd/stoneyridge/bootblock/bootblock.c b/src/soc/amd/stoneyridge/bootblock/bootblock.c index 1712b51..7545a59 100644 --- a/src/soc/amd/stoneyridge/bootblock/bootblock.c +++ b/src/soc/amd/stoneyridge/bootblock/bootblock.c @@ -39,7 +39,7 @@
void bootblock_soc_early_init(void) { - amd_initmmio(); + amd_initmmio(CONFIG_MMCONF_BUS_NUMBER);
if (!boot_cpu()) bootblock_soc_init(); /* APs will not return */ diff --git a/src/soc/amd/stoneyridge/fixme.c b/src/soc/amd/stoneyridge/fixme.c index 60cc2d1..214e7bb 100644 --- a/src/soc/amd/stoneyridge/fixme.c +++ b/src/soc/amd/stoneyridge/fixme.c @@ -63,7 +63,7 @@ LibAmdPciWrite(AccessWidth32, PciAddress, &PciData, &StdHeader); }
-void amd_initmmio(void) +void amd_initmmio(size_t max_bus) { UINT64 MsrReg; AMD_CONFIG_PARAMS StdHeader; @@ -73,7 +73,7 @@ configuration base Address MSR register. */ MsrReg = CONFIG_MMCONF_BASE_ADDRESS | - (LibAmdBitScanReverse(CONFIG_MMCONF_BUS_NUMBER) << 2) + (LibAmdBitScanReverse(max_bus) << 2) | 1; LibAmdMsrWrite(0xc0010058, &MsrReg, &StdHeader);
