Attention is currently required from: Jason Glenesk, Raul Rangel, Matt DeVillier, Felix Held.
Fred Reitberger has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/69074 )
Change subject: soc/amd/*/data_fabric: Move register offsets to soc ......................................................................
Morgana/Glinda have a different register mapping for data fabric access, although the registers themselves are mostly compatible. The register layouts defined by each soc capture the differences and the common code can use those.
Move the register offsets to soc headers and update the offsets for morgana/glinda per morgana ppr #57396, rev 1.52 and glinda ppr #57254, rev 1.51
Signed-off-by: Fred Reitberger reitbergerfred@gmail.com Change-Id: I9e5e7c85f99a9afa873764ade9734831fb5cfe69 --- M src/soc/amd/cezanne/include/soc/data_fabric.h D src/soc/amd/common/block/data_fabric/data_fabric_def.h M src/soc/amd/common/block/data_fabric/data_fabric_helper.c M src/soc/amd/common/block/include/amdblocks/data_fabric.h M src/soc/amd/glinda/Kconfig M src/soc/amd/glinda/include/soc/data_fabric.h M src/soc/amd/mendocino/include/soc/data_fabric.h M src/soc/amd/morgana/Kconfig M src/soc/amd/morgana/include/soc/data_fabric.h M src/soc/amd/picasso/include/soc/data_fabric.h 10 files changed, 65 insertions(+), 47 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/74/69074/1
diff --git a/src/soc/amd/cezanne/include/soc/data_fabric.h b/src/soc/amd/cezanne/include/soc/data_fabric.h index 0a89971..a1f8b70 100644 --- a/src/soc/amd/cezanne/include/soc/data_fabric.h +++ b/src/soc/amd/cezanne/include/soc/data_fabric.h @@ -5,8 +5,15 @@
#include <types.h>
-/* SoC-specific bits in D18F0_MMIO_CTRL0 */ -#define DF_MMIO_NP BIT(16) +/* D18F0 - Fabric Configuration registers */ +#define D18F0_MMIO_BASE0 0x200 +#define D18F0_MMIO_LIMIT0 0x204 +#define D18F0_MMIO_SHIFT 16 +#define D18F0_MMIO_CTRL0 0x208 + +#define DF_FICAA_BIOS 0x5C +#define DF_FICAD_LO 0x98 +#define DF_FICAD_HI 0x9C
#define IOMS0_FABRIC_ID 10
diff --git a/src/soc/amd/common/block/data_fabric/data_fabric_def.h b/src/soc/amd/common/block/data_fabric/data_fabric_def.h deleted file mode 100644 index 2076d16..0000000 --- a/src/soc/amd/common/block/data_fabric/data_fabric_def.h +++ /dev/null @@ -1,20 +0,0 @@ -/* SPDX-License-Identifier: GPL-2.0-only */ - -#ifndef AMD_BLOCK_DATA_FABRIC_DEF_H -#define AMD_BLOCK_DATA_FABRIC_DEF_H - -#define DF_FICAA_BIOS 0x5C -#define DF_FICAD_LO 0x98 -#define DF_FICAD_HI 0x9C - -#define DF_IND_CFG_INST_ACC_EN (1 << 0) -#define DF_IND_CFG_ACC_REG_SHIFT 2 -#define DF_IND_CFG_ACC_REG_MASK (0x1ff << DF_IND_CFG_ACC_REG_SHIFT) -#define DF_IND_CFG_ACC_FUN_SHIFT 11 -#define DF_IND_CFG_ACC_FUN_MASK (0x7 << DF_IND_CFG_ACC_FUN_SHIFT) -#define DF_IND_CFG_64B_EN_SHIFT 14 -#define DF_IND_CFG_64B_EN (0x1 << DF_IND_CFG_64B_EN_SHIFT) -#define DF_IND_CFG_INST_ID_SHIFT 16 -#define DF_IND_CFG_INST_ID_MASK (0xff << DF_IND_CFG_INST_ID_SHIFT) - -#endif /* AMD_BLOCK_DATA_FABRIC_DEF_H */ diff --git a/src/soc/amd/common/block/data_fabric/data_fabric_helper.c b/src/soc/amd/common/block/data_fabric/data_fabric_helper.c index ac4e31e4..4c9052d 100644 --- a/src/soc/amd/common/block/data_fabric/data_fabric_helper.c +++ b/src/soc/amd/common/block/data_fabric/data_fabric_helper.c @@ -9,7 +9,6 @@ #include <soc/data_fabric.h> #include <soc/pci_devs.h> #include <types.h> -#include "data_fabric_def.h"
static void data_fabric_set_indirect_address(uint8_t func, uint16_t reg, uint8_t instance_id) { diff --git a/src/soc/amd/common/block/include/amdblocks/data_fabric.h b/src/soc/amd/common/block/include/amdblocks/data_fabric.h index 5cc7f48..4f8dcd4 100644 --- a/src/soc/amd/common/block/include/amdblocks/data_fabric.h +++ b/src/soc/amd/common/block/include/amdblocks/data_fabric.h @@ -5,21 +5,12 @@
#include <amdblocks/pci_devs.h> #include <device/pci_ops.h> +#include <soc/data_fabric.h> #include <soc/pci_devs.h> #include <stdint.h>
#define BROADCAST_FABRIC_ID 0xff
-/* D18F0 - Fabric Configuration registers */ -#define D18F0_MMIO_BASE0 0x200 -#define D18F0_MMIO_LIMIT0 0x204 -#define D18F0_MMIO_SHIFT 16 -#define D18F0_MMIO_CTRL0 0x208 -/* The MMIO_NP bit is SoC-specific */ -#define DF_MMIO_DST_FABRIC_ID_SHIFT 4 -#define DF_MMIO_WE BIT(1) -#define DF_MMIO_RE BIT(0) - /* The number of data fabric MMIO registers is SoC-specific */ #define NB_MMIO_BASE(reg) ((reg) * 4 * sizeof(uint32_t) + D18F0_MMIO_BASE0) #define NB_MMIO_LIMIT(reg) ((reg) * 4 * sizeof(uint32_t) + D18F0_MMIO_LIMIT0) diff --git a/src/soc/amd/glinda/Kconfig b/src/soc/amd/glinda/Kconfig index c11ece9..c34bfd0 100644 --- a/src/soc/amd/glinda/Kconfig +++ b/src/soc/amd/glinda/Kconfig @@ -50,7 +50,7 @@ select SOC_AMD_COMMON_BLOCK_APOB # TODO: Check if this is still correct select SOC_AMD_COMMON_BLOCK_APOB_HASH # TODO: Check if this is still correct select SOC_AMD_COMMON_BLOCK_BANKED_GPIOS # TODO: Check if this is still correct - select SOC_AMD_COMMON_BLOCK_DATA_FABRIC # TODO: Check if this is still correct + select SOC_AMD_COMMON_BLOCK_DATA_FABRIC select SOC_AMD_COMMON_BLOCK_EMMC # TODO: Check if this is still correct select SOC_AMD_COMMON_BLOCK_ESPI_EXTENDED_DECODE_RANGES # TODO: Check if this is still correct select SOC_AMD_COMMON_BLOCK_GRAPHICS # TODO: Check if this is still correct diff --git a/src/soc/amd/glinda/include/soc/data_fabric.h b/src/soc/amd/glinda/include/soc/data_fabric.h index 32cbd20..7be4b15 100644 --- a/src/soc/amd/glinda/include/soc/data_fabric.h +++ b/src/soc/amd/glinda/include/soc/data_fabric.h @@ -1,14 +1,19 @@ /* SPDX-License-Identifier: GPL-2.0-only */
-/* TODO: Update for Glinda */ - #ifndef AMD_GLINDA_DATA_FABRIC_H #define AMD_GLINDA_DATA_FABRIC_H
#include <types.h>
-/* SoC-specific bits in D18F0_MMIO_CTRL0 */ -#define DF_MMIO_NP BIT(3) +/* D18F0 - Fabric Configuration registers */ +#define D18F0_MMIO_BASE0 0xD80 +#define D18F0_MMIO_LIMIT0 0xD84 +#define D18F0_MMIO_SHIFT 16 +#define D18F0_MMIO_CTRL0 0xD88 + +#define DF_FICAA_BIOS 0x8C +#define DF_FICAD_LO 0xB8 +#define DF_FICAD_HI 0xBC
#define IOMS0_FABRIC_ID 15
diff --git a/src/soc/amd/mendocino/include/soc/data_fabric.h b/src/soc/amd/mendocino/include/soc/data_fabric.h index a1a1f4e..ae5f267 100644 --- a/src/soc/amd/mendocino/include/soc/data_fabric.h +++ b/src/soc/amd/mendocino/include/soc/data_fabric.h @@ -5,8 +5,15 @@
#include <types.h>
#define IOMS0_FABRIC_ID 9
diff --git a/src/soc/amd/morgana/Kconfig b/src/soc/amd/morgana/Kconfig index a1261c9..053f4e4 100644 --- a/src/soc/amd/morgana/Kconfig +++ b/src/soc/amd/morgana/Kconfig @@ -50,7 +50,7 @@ select SOC_AMD_COMMON_BLOCK_APOB # TODO: Check if this is still correct select SOC_AMD_COMMON_BLOCK_APOB_HASH # TODO: Check if this is still correct select SOC_AMD_COMMON_BLOCK_BANKED_GPIOS # TODO: Check if this is still correct - select SOC_AMD_COMMON_BLOCK_DATA_FABRIC # TODO: Check if this is still correct + select SOC_AMD_COMMON_BLOCK_DATA_FABRIC select SOC_AMD_COMMON_BLOCK_EMMC # TODO: Check if this is still correct select SOC_AMD_COMMON_BLOCK_ESPI_EXTENDED_DECODE_RANGES # TODO: Check if this is still correct select SOC_AMD_COMMON_BLOCK_GRAPHICS # TODO: Check if this is still correct diff --git a/src/soc/amd/morgana/include/soc/data_fabric.h b/src/soc/amd/morgana/include/soc/data_fabric.h index 203ca1c..46070f7 100644 --- a/src/soc/amd/morgana/include/soc/data_fabric.h +++ b/src/soc/amd/morgana/include/soc/data_fabric.h @@ -1,14 +1,19 @@ /* SPDX-License-Identifier: GPL-2.0-only */
-/* TODO: Update for Morgana */ - #ifndef AMD_MORGANA_DATA_FABRIC_H #define AMD_MORGANA_DATA_FABRIC_H
#include <types.h>
#define IOMS0_FABRIC_ID 14
diff --git a/src/soc/amd/picasso/include/soc/data_fabric.h b/src/soc/amd/picasso/include/soc/data_fabric.h index f71abe0..dc77fee 100644 --- a/src/soc/amd/picasso/include/soc/data_fabric.h +++ b/src/soc/amd/picasso/include/soc/data_fabric.h @@ -6,9 +6,14 @@ #include <types.h>
-/* SoC-specific bits in D18F0_MMIO_CTRL0 */ -#define DF_MMIO_NP BIT(12) +#define DF_FICAA_BIOS 0x5C +#define DF_FICAD_LO 0x98 +#define DF_FICAD_HI 0x9C
