Alexandru Gagniuc (alexandrux.gagniuc@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/14586
commit 7f8fe994ee059de370574917113d5d7338bf189c Author: Alexandru Gagniuc alexandrux.gagniuc@intel.com Date: Mon Apr 4 10:47:49 2016 -0700
soc/apollolake/lpc: Allow configuring SERIRQ in continuous mode
Every other SOC uses a CONFIG_* flag to enable or disable SERIRQ continuous mode. Why they do that is beyond me, but the way we implement it on apollolake is via devicetree.
Change-Id: I6e05758e5e264c6b0015467dd25add3bffe2b040 Signed-off-by: Alexandru Gagniuc alexandrux.gagniuc@intel.com --- src/soc/intel/apollolake/chip.h | 3 +++ src/soc/intel/apollolake/lpc.c | 23 +++++++++++++++++++++++ 2 files changed, 26 insertions(+)
diff --git a/src/soc/intel/apollolake/chip.h b/src/soc/intel/apollolake/chip.h index 9d2bc46..05adef5 100644 --- a/src/soc/intel/apollolake/chip.h +++ b/src/soc/intel/apollolake/chip.h @@ -32,6 +32,9 @@ struct soc_intel_apollolake_config { uint8_t pcie_rp3_clkreq_pin; uint8_t pcie_rp4_clkreq_pin; uint8_t pcie_rp5_clkreq_pin; + + /* Enable continuous mode for LPC SERIRQ line. */ + bool serirq_continuous_mode; };
#endif /* _SOC_APOLLOLAKE_CHIP_H_ */ diff --git a/src/soc/intel/apollolake/lpc.c b/src/soc/intel/apollolake/lpc.c index 58a3cdb..e97f76a 100644 --- a/src/soc/intel/apollolake/lpc.c +++ b/src/soc/intel/apollolake/lpc.c @@ -15,6 +15,7 @@ * GNU General Public License for more details. */
+#include <console/console.h> #include <device/device.h> #include <device/pci.h> #include <device/pci_ids.h> @@ -22,6 +23,8 @@ #include <soc/lpc.h> #include <soc/pci_ids.h>
+#include "chip.h" + /* * SCOPE: * The purpose of this driver is to eliminate manual resource allocation for @@ -40,6 +43,25 @@ * opens up IO and memory windows as needed. */
+static void lpc_init(struct device *dev) +{ + uint8_t scnt; + struct soc_intel_apollolake_config *cfg; + + cfg = dev->chip_info; + if (!cfg) { + printk(BIOS_ERR, "BUG! Could not find SOC devicetree config\n"); + return; + } + + if (cfg->serirq_continuous_mode) { + scnt = pci_read_config8(dev, REG_SERIRQ_CTL); + scnt |= SCNT_EN | SCNT_MODE; + pci_write_config8(dev, REG_SERIRQ_CTL, scnt); + } + +} + static void soc_lpc_add_io_resources(device_t dev) { struct resource *res; @@ -115,6 +137,7 @@ static struct device_operations device_ops = { .enable_resources = &pci_dev_enable_resources, .write_acpi_tables = southbridge_write_acpi_tables, .acpi_inject_dsdt_generator = southbridge_inject_dsdt, + .init = lpc_init, .scan_bus = scan_lpc_bus, };
