Hello build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/42692
Change subject: soc/amd/common: Avoid aliasing on ACPIMMIO writes ......................................................................
With runtime configuration of base addresses, these pointers are subject to aliasing on write8(). The impact on code size is very small with iomux and biosram regions, there is some unnecessary reloading of base address from memory to register.
Declaring ACPIMMIO banks as arrays appears to sometimes create more dense x86 assembly.
Change-Id: I7369b8b07a23e9b52c2961c527dc8d29ad4b505b Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- M src/soc/amd/common/block/acpimmio/biosram.c M src/soc/amd/common/block/acpimmio/mmio_util.c M src/soc/amd/common/block/gpio_banks/gpio.c M src/soc/amd/common/block/include/amdblocks/acpimmio.h 4 files changed, 40 insertions(+), 22 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/92/42692/6
