Subrata Banik has submitted this change. ( https://review.coreboot.org/c/coreboot/+/83654?usp=email )
Change subject: mb/google/brya: Select USE_UNIFIED_AP_FIRMWARE_FOR_UFS_AND_NON_UFS ......................................................................
This patch selects USE_UNIFIED_AP_FIRMWARE_FOR_UFS_AND_NON_UFS for Google/Trulo variant which intends to achieve a unified AP firmware image across UFS and non-UFS skus.
Note: Enabling this config would introduce an additional warm reset during the cold-reset scenarios due to the function disabling of the UFS controller as results we are expecting ~300ms higher boot time (which might not be user visible because `cbmem -t` can't include impacted boot time due to in-between resets).
BUG=b:355384185 TEST=Able to enter S0ix on Trulo eMMC sku after disabling UFS during boot path.
Able to grep below debug prints while booting the eMMC sku.
[INFO ] FW_CONFIG value from CBI is 0x20000000 [INFO ] Disabling UFS controllers ... [INFO ] fw_config match found: STORAGE=STORAGE_EMMC
Change-Id: I06a84fa8c3843edae5932e19d394b18b72ace422 Signed-off-by: Subrata Banik subratabanik@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/83654 Reviewed-by: David Wu david_wu@quanta.corp-partner.google.com Reviewed-by: Eric Lai ericllai@google.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Dinesh Gehlot digehlot@google.com Reviewed-by: Amanda Hwang amanda_hwang@compal.corp-partner.google.com --- M src/mainboard/google/brya/Kconfig 1 file changed, 1 insertion(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Amanda Hwang: Looks good to me, approved Dinesh Gehlot: Looks good to me, approved Eric Lai: Looks good to me, approved David Wu: Looks good to me, approved
diff --git a/src/mainboard/google/brya/Kconfig b/src/mainboard/google/brya/Kconfig index dfbd291..ec4cab4 100644 --- a/src/mainboard/google/brya/Kconfig +++ b/src/mainboard/google/brya/Kconfig @@ -554,6 +554,7 @@ select SOC_INTEL_TWINLAKE select SOC_INTEL_COMMON_BLOCK_HDA_VERB select SOC_INTEL_TCSS_USE_PDC_PMC_USBC_MUX_CONFIGURATION + select USE_UNIFIED_AP_FIRMWARE_FOR_UFS_AND_NON_UFS
config BOARD_GOOGLE_ULDREN select BOARD_GOOGLE_BASEBOARD_NISSA
