Stefan Reinauer (stefan.reinauer@coreboot.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/9561
commit f1156e389082ec109c742f91e5c3d30aa72771cb Author: Vadim Bendebury vbendeb@chromium.org Date: Sat Jan 10 23:11:43 2015 -0800
vbnv flash: use proper SPI flash offset for NVRAM
The current vbnv flash code mistakenly uses the offset into the NVRAM area as the absolute offset into the SPI NOR. This causes overwrites RO section of the flash (when it is not protected) and causes failures to retrieve the NVRAM contents by the user space apps.
This patch makes sure that the correct offset is used when accessing NVRAM area in the SPI flash.
BRANCH=storm BUG=chrome-os-partner:35316 TEST=run the update code on storm. - no more RO section corruption observed - running 'crossystem recovery_request=1' at Linux prompt causes the next boot happen in recovery mode
Change-Id: Iba96cd2e0e5e01c990f8c1de8d2a2233cd9e9bc9 Signed-off-by: Stefan Reinauer reinauer@chromium.org Original-Commit-Id: 9fd15ff4b7aa77536723edbb94fa81f0ae767aed Original-Change-Id: I86fe4b9a35f7c16b72abf49cfbfcd42cc87937e3 Original-Signed-off-by: Vadim Bendebury vbendeb@chromium.org Original-Reviewed-on: https://chromium-review.googlesource.com/240143 Original-Reviewed-by: Daisuke Nojiri dnojiri@chromium.org --- src/vendorcode/google/chromeos/vbnv_flash.c | 45 +++++++++++++++-------------- 1 file changed, 24 insertions(+), 21 deletions(-)
diff --git a/src/vendorcode/google/chromeos/vbnv_flash.c b/src/vendorcode/google/chromeos/vbnv_flash.c index 3d4581f..e880ed4 100644 --- a/src/vendorcode/google/chromeos/vbnv_flash.c +++ b/src/vendorcode/google/chromeos/vbnv_flash.c @@ -37,9 +37,12 @@ /* FMAP descriptor of the NVRAM area */ static struct vboot_region nvram_region;
-/* offset of the current nvdata in nvram */ +/* offset of the current nvdata in SPI flash */ static int blob_offset = -1;
+/* Offset of the topmost nvdata blob in SPI flash */ +static int top_offset; + /* cache of the current nvdata */ static uint8_t cache[BLOB_SIZE];
@@ -83,13 +86,16 @@ static int init_vbnv(void) for (i = 0; i < BLOB_SIZE; i++) empty_blob[i] = erase_value();
+ offset = nvram_region.offset_addr; + top_offset = nvram_region.offset_addr + nvram_region.size - BLOB_SIZE; + /* - * after the loop, offset is supposed to point the blob right before the - * first empty blob, the last blob in the nvram if there is no empty - * blob, or 0 if the nvram has never been used. + * after the loop, offset is supposed to point the blob right before + * the first empty blob, the last blob in the nvram if there is no + * empty blob, or the base of the region if the nvram has never been + * used. */ - for (i = 0, offset = 0; i <= nvram_region.size - BLOB_SIZE; - i += BLOB_SIZE) { + for (i = offset; i <= top_offset; i += BLOB_SIZE) { if (vboot_get_region(i, BLOB_SIZE, buf) == NULL) { printk(BIOS_ERR, "failed to read nvdata\n"); return 1; @@ -147,7 +153,7 @@ void read_vbnv(uint8_t *vbnv_copy)
void save_vbnv(const uint8_t *vbnv_copy) { - int new_offset = blob_offset; + int new_offset; int i;
if (!is_initialized()) @@ -158,31 +164,28 @@ void save_vbnv(const uint8_t *vbnv_copy) if (!memcmp(vbnv_copy, cache, BLOB_SIZE)) return;
+ new_offset = blob_offset; + /* See if we can overwrite the current blob with the new one */ for (i = 0; i < BLOB_SIZE; i++) { if (!can_overwrite(cache[i], vbnv_copy[i])) { /* unable to overwrite. need to use the next blob */ new_offset += BLOB_SIZE; - if (new_offset > nvram_region.size - BLOB_SIZE) { + if (new_offset > top_offset) { if (erase_nvram()) return; /* error */ - new_offset = 0; + new_offset = nvram_region.offset_addr; } break; } }
- if (vbnv_flash_probe()) - return; /* error */ - - if (spi_flash->write(spi_flash, new_offset, BLOB_SIZE, vbnv_copy)) { - printk(BIOS_ERR, "failed to write nvdata\n"); - return; /* error */ + if (!vbnv_flash_probe() && + !spi_flash->write(spi_flash, new_offset, BLOB_SIZE, vbnv_copy)) { + /* write was successful. safely move pointer forward */ + blob_offset = new_offset; + memcpy(cache, vbnv_copy, BLOB_SIZE); + } else { + printk(BIOS_ERR, "failed to save nvdata\n"); } - - /* write was successful. safely move pointer forward */ - blob_offset = new_offset; - memcpy(cache, vbnv_copy, BLOB_SIZE); - - return; }
