Patrick Rudolph has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/43136 )
Change subject: arch/x86/gdt: Work around assembler bug ......................................................................
The GDT loading did work fine a few month ago, but today it only works in QEMU, but not on real hardware or KVM enabled. This might be related to toolchain changes.
Use 64bit GDT loading on x86_64 and force the assembler to generate a 64bit address load on the GDT. This will make sure no 32bit (signed) displacement op is being generated, which points to the wrong address in longmode.
Veryfied using readelf and made sure no R_X86_64_32S relocation symbol is emitted. Disassembled the romstage ELF and made sure the GDT address is 64bit in size.
Tested on QEMU and KVM enabled QEMU: Doesn't crash any more on KVM.
Signed-off-by: Patrick Rudolph siro@das-labor.org
Change-Id: Ia824f90d9611e6e8db09bd62a05e6f990581f09a --- M src/arch/x86/assembly_entry.S M src/arch/x86/gdt_init.S 2 files changed, 24 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/43136/1
diff --git a/src/arch/x86/assembly_entry.S b/src/arch/x86/assembly_entry.S index fb48469..9ebc09d 100644 --- a/src/arch/x86/assembly_entry.S +++ b/src/arch/x86/assembly_entry.S @@ -15,12 +15,22 @@ #define _STACK_TOP _ecar_stack #endif
+#ifdef __x86_64__ +.code64 +#else +.code32 +#endif + .section ".text._start", "ax", @progbits .global _start _start:
/* Migrate GDT to this text segment */ +#if defined(__x86_64__) + call gdt_init64 +#else call gdt_init +#endif
/* reset stack pointer to CAR/EARLYRAM stack */ mov $_STACK_TOP, %esp diff --git a/src/arch/x86/gdt_init.S b/src/arch/x86/gdt_init.S index 7dd4b94..1558ac6 100644 --- a/src/arch/x86/gdt_init.S +++ b/src/arch/x86/gdt_init.S @@ -20,7 +20,20 @@ .section ".text._gdt64_", "ax", @progbits .globl gdt_init64 gdt_init64: - lgdt gdtptr64 + /* Workaround a bug in the assembler. + * The following code doesn't work: + * lgdt gdtptr64 + * + * The assembler tries to save memory by using 32bit displacement addressing mode. + * Displacements are using signed integers. + * This is fine in protected mode, as the negative address points to the correct + * address > 2GiB, but in long mode this doesn't work at all. + * Tests showed that QEMU can gracefully handle it, but real CPUs can't. + * + * Use the movabs pseudo instruction to force using a 64bit absolute address. + */ + movabs $gdtptr64, %rax + lgdt (%rax) ret
.previous
Patrick Rudolph has uploaded a new patch set (#2). ( https://review.coreboot.org/c/coreboot/+/43136 )
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/43136/2
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43136 )
Patch Set 2:
https://review.coreboot.org/c/coreboot/+/43136/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/43136/2//COMMIT_MSG@25 PS2, Line 25: Please remove the blank line.
Patch Set 2:
Looks like an unrelated build error on *congenialbuilder*:
rm: cannot remove '/cb-build/coreboot-gerrit.0/chromeos/GOOGLE_SWANKY': Directory not empty
Hello build bot (Jenkins), Patrick Georgi, Martin Roth, Angel Pons, Arthur Heymans, Kyösti Mälkki, Aaron Durbin,
The GDT loading did work fine on x86_64 a few month ago, but today it only works in QEMU, but not on real hardware or KVM enabled. This might be related to toolchain changes.
Signed-off-by: Patrick Rudolph siro@das-labor.org Change-Id: Ia824f90d9611e6e8db09bd62a05e6f990581f09a --- M src/arch/x86/assembly_entry.S M src/arch/x86/gdt_init.S 2 files changed, 24 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/43136/3
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43136 )
Patch Set 2:
Done
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43136 )
Patch Set 3: Code-Review+2
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43136 )
(5 comments)
https://review.coreboot.org/c/coreboot/+/43136/3//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/43136/3//COMMIT_MSG@9 PS3, Line 9: month months
https://review.coreboot.org/c/coreboot/+/43136/3//COMMIT_MSG@10 PS3, Line 10: KVM enabled KVM-enabled QEMU
https://review.coreboot.org/c/coreboot/+/43136/3//COMMIT_MSG@18 PS3, Line 18: Veryfied Verified
https://review.coreboot.org/c/coreboot/+/43136/3//COMMIT_MSG@22 PS3, Line 22: KVM enabled QEMU KVM-enabled QEMU
https://review.coreboot.org/c/coreboot/+/43136/3/src/arch/x86/gdt_init.S File src/arch/x86/gdt_init.S:
https://review.coreboot.org/c/coreboot/+/43136/3/src/arch/x86/gdt_init.S@29 PS3, Line 29: protected mode that's 32-bit mode, right?
Patrick Rudolph has uploaded a new patch set (#4) to the change originally created by Patrick Rudolph. ( https://review.coreboot.org/c/coreboot/+/43136 )
The GDT loading did work fine on x86_64 a few months ago, but today it only works in QEMU, but not on real hardware or KVM-enabled QEMU. This might be related to toolchain changes.
Verified using readelf and made sure no R_X86_64_32S relocation symbol is emitted. Disassembled the romstage ELF and made sure the GDT address is 64bit in size.
Tested on QEMU and KVM-enabled QEMU: Doesn't crash any more on KVM.
Signed-off-by: Patrick Rudolph siro@das-labor.org Change-Id: Ia824f90d9611e6e8db09bd62a05e6f990581f09a --- M src/arch/x86/assembly_entry.S M src/arch/x86/gdt_init.S 2 files changed, 39 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/43136/4
Patch Set 4:
(5 comments)
months
Done
KVM-enabled QEMU
Done
Verified
Done
KVM-enabled QEMU
Done
Yes.
Philipp Deppenwiese has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43136 )
Patch Set 4: Code-Review+2
Hello Philipp Deppenwiese, build bot (Jenkins), Patrick Georgi, Martin Roth, Patrick Rudolph, Angel Pons, Arthur Heymans, Aaron Durbin,
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/43136/5
Patch Set 5:
rebased due to merge conflict.
Patch Set 5: Code-Review+2
Patch Set 5:
https://review.coreboot.org/c/coreboot/+/43136/5/src/arch/x86/assembly_entry... File src/arch/x86/assembly_entry.S:
https://review.coreboot.org/c/coreboot/+/43136/5/src/arch/x86/assembly_entry... PS5, Line 29: #if defined(__x86_64__) For consistency with the lines above:
#ifdef __x86_64__
Patrick Rudolph has uploaded a new patch set (#6) to the change originally created by Patrick Rudolph. ( https://review.coreboot.org/c/coreboot/+/43136 )
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/36/43136/6
Patch Set 5:
For consistency with the lines above: […]
Done
Patch Set 6: Code-Review+2
Patrick Rudolph has submitted this change. ( https://review.coreboot.org/c/coreboot/+/43136 )
Signed-off-by: Patrick Rudolph siro@das-labor.org Change-Id: Ia824f90d9611e6e8db09bd62a05e6f990581f09a Reviewed-on: https://review.coreboot.org/c/coreboot/+/43136 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Angel Pons th3fanbus@gmail.com --- M src/arch/x86/assembly_entry.S M src/arch/x86/gdt_init.S 2 files changed, 24 insertions(+), 1 deletion(-)
diff --git a/src/arch/x86/assembly_entry.S b/src/arch/x86/assembly_entry.S index 0d8307b..31670c2 100644 --- a/src/arch/x86/assembly_entry.S +++ b/src/arch/x86/assembly_entry.S @@ -15,12 +15,22 @@ #define _STACK_TOP _ecar_stack #endif
/* Migrate GDT to this text segment */ +#ifdef __x86_64__ + call gdt_init64 +#else call gdt_init +#endif
.previous
9elements QA has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/43136 )
Patch Set 7:
Automatic boot test returned (PASS/FAIL/TOTAL): 6/1/7 "QEMU x86 q35/ich9" (x86_32) using payload TianoCore : SUCCESS : https://lava.9esec.io/r/16076 "QEMU x86 q35/ich9" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/16075 "QEMU x86 i440fx/piix4" (x86_64) using payload SeaBIOS : FAIL : https://lava.9esec.io/r/16074 "QEMU x86 i440fx/piix4" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/16073 "QEMU AArch64" using payload LinuxBoot_u-root_kexec : SUCCESS : https://lava.9esec.io/r/16072 "HP Compaq 8200 Elite SFF PC" (x86_32) using payload TianoCore : SUCCESS : https://lava.9esec.io/r/16078 "HP Compaq 8200 Elite SFF PC" (x86_32) using payload SeaBIOS : SUCCESS : https://lava.9esec.io/r/16077
