Patrick Georgi has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/35805 )
Change subject: Documentation: start documenting our services ......................................................................
Change-Id: I4d687d13e8d47e3e3e6f319b9117d3c4f31caa78 Signed-off-by: Patrick Georgi pgeorgi@google.com --- A Documentation/community/services.md M Documentation/index.md 2 files changed, 36 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/05/35805/1
diff --git a/Documentation/community/services.md b/Documentation/community/services.md new file mode 100644 index 0000000..afdf040 --- /dev/null +++ b/Documentation/community/services.md @@ -0,0 +1,35 @@ +# Accounts on coreboot.org + +There are a number of places where you can benefit from creaating an account +in our community. Since there is no single sign-on system in place (at this +time), they come with their own setup routines. + +## Gerrit code review +We exchange and review patches to the code using the Gerrit code review +system that is available on review.coreboot.org. + +It allows logging in with a Google or GitHub account using OAuth2 as well +as with any OpenID provider that you may already use. + +On https://review.coreboot.org/settings you can register all your email +addresses you intend to use in the context of coreboot development so that +commits with your email address in them are associated with you properly. + +### https push access +When using the https URLs to git repositories, you can push with the "HTTP +Credentials" you can have Gerrit generate for you on that page. By default, +git uses `$HOME/.netrc` for http authentication data, so add a line there +stating: + + machine review.coreboot.org login (your-user-name) password (your-password) + +### Gerrit user avatar +To setup an avatar to show in Gerrit, clone the avatars repository at +https://review.coreboot.org/gerrit-avatars.git and add a file named +$your-user-ID.jpg (the user ID is a number shown on the settings page linked +above). The image must be provided in JPEG format, must be square and at most +50000 bytes. + +After you push for review, the system will automatically verify your change +and, if adhering to these constraints, approve it. You can then immediately +submit it. diff --git a/Documentation/index.md b/Documentation/index.md index 39c8d11..e52c78a 100644 --- a/Documentation/index.md +++ b/Documentation/index.md @@ -166,6 +166,7 @@ * [Project Ideas](contributing/project_ideas.md) * [Code of Conduct](community/code_of_conduct.md) * [Community forums](community/forums.md) +* [Project services](commmunity/services.md) * [coreboot at conferences](community/conferences.md) * [Payloads](payloads.md) * [Distributions](distributions.md)
Patrick Rudolph has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35805 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/35805/1/Documentation/community/ser... File Documentation/community/services.md:
https://review.coreboot.org/c/coreboot/+/35805/1/Documentation/community/ser... PS1, Line 14: On https://review.coreboot.org/settings you can register all your email please make it a clickable hyperlink
Hello Stefan Reinauer, build bot (Jenkins),
Change-Id: I4d687d13e8d47e3e3e6f319b9117d3c4f31caa78 Signed-off-by: Patrick Georgi pgeorgi@google.com --- A Documentation/community/services.md M Documentation/index.md 2 files changed, 37 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/05/35805/2
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/35805 )
Patch Set 2:
Done
Patch Set 2: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/35805 )
Change-Id: I4d687d13e8d47e3e3e6f319b9117d3c4f31caa78 Signed-off-by: Patrick Georgi pgeorgi@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/35805 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Rudolph siro@das-labor.org --- A Documentation/community/services.md M Documentation/index.md 2 files changed, 37 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Patrick Rudolph: Looks good to me, approved
diff --git a/Documentation/community/services.md b/Documentation/community/services.md new file mode 100644 index 0000000..0871cda --- /dev/null +++ b/Documentation/community/services.md @@ -0,0 +1,36 @@ +# Accounts on coreboot.org + +There are a number of places where you can benefit from creaating an account +in our community. Since there is no single sign-on system in place (at this +time), they come with their own setup routines. + +## Gerrit code review +We exchange and review patches to the code using our [Gerrit code review +system](https://review.coreboot.org). + +It allows logging in with a Google or GitHub account using OAuth2 as well +as with any OpenID provider that you may already use. + +On the [settings screen](https://review.coreboot.org/settings) you can register +all your email addresses you intend to use in the context of coreboot +development so that commits with your email address in them are associated with +you properly. + +### https push access +When using the https URLs to git repositories, you can push with the "HTTP +Credentials" you can have Gerrit generate for you on that page. By default, +git uses `$HOME/.netrc` for http authentication data, so add a line there +stating: + + machine review.coreboot.org login $your-user-name password $your-password + +### Gerrit user avatar +To setup an avatar to show in Gerrit, clone the avatars repository at +https://review.coreboot.org/gerrit-avatars.git and add a file named +$your-user-ID.jpg (the user ID is a number shown on the [settings screen](https://review.coreboot.org/settings)). +The image must be provided in JPEG format, must be square and have at most 50000 +bytes. + +After you push for review, the system will automatically verify your change +and, if adhering to these constraints, approve it. You can then immediately +submit it. diff --git a/Documentation/index.md b/Documentation/index.md index 39c8d11..1c04ad3 100644 --- a/Documentation/index.md +++ b/Documentation/index.md @@ -166,6 +166,7 @@ * [Project Ideas](contributing/project_ideas.md) * [Code of Conduct](community/code_of_conduct.md) * [Community forums](community/forums.md) +* [Project services](community/services.md) * [coreboot at conferences](community/conferences.md) * [Payloads](payloads.md) * [Distributions](distributions.md)
