Marshall Dawson has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/33988
Change subject: soc/amd/picasso: Remove SD controller ......................................................................
Change-Id: Ie9cf361ed0caba9c73727453c4a503557edc854d Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com --- M src/soc/amd/picasso/acpi/globalnvs.asl M src/soc/amd/picasso/acpi/sb_pci0_fch.asl M src/soc/amd/picasso/chip.c M src/soc/amd/picasso/include/soc/pci_devs.h M src/soc/amd/picasso/include/soc/southbridge.h M src/soc/amd/picasso/southbridge.c 6 files changed, 3 insertions(+), 64 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/88/33988/1
diff --git a/src/soc/amd/picasso/acpi/globalnvs.asl b/src/soc/amd/picasso/acpi/globalnvs.asl index cdb32cc..cc264e6 100644 --- a/src/soc/amd/picasso/acpi/globalnvs.asl +++ b/src/soc/amd/picasso/acpi/globalnvs.asl @@ -58,9 +58,7 @@ UT1E, 1, // UART1, 12 , 2, ST_E, 1, // SATA, 15 - , 8, - SD_E, 1, // SD, 24 - , 2, + , 11, ESPI, 1, // ESPI, 27 /* ChromeOS stuff (0x100 -> 0xfff, size 0xeff) */ Offset (0x100), diff --git a/src/soc/amd/picasso/acpi/sb_pci0_fch.asl b/src/soc/amd/picasso/acpi/sb_pci0_fch.asl index 8cdb4d2..206fdfd 100644 --- a/src/soc/amd/picasso/acpi/sb_pci0_fch.asl +++ b/src/soc/amd/picasso/acpi/sb_pci0_fch.asl @@ -53,21 +53,6 @@ /* 0:14.3 - LPC */ #include <soc/amd/common/acpi/lpc.asl>
-/* 0:14.7 - SD Controller */ -Device(SDCN) { - Name(_ADR, 0x00140007) - - Method(_PS0) { - FDDC(24, 0) - } - Method(_PS3) { - FDDC(24, 3) - } - Method(_PSC) { - Return(SDTD) - } -} /* end SDCN */ - Name(CRES, ResourceTemplate() { /* Set the Bus number and Secondary Bus number for the PCI0 device * The Secondary bus range for PCI0 lets the system @@ -272,15 +257,6 @@ offset (0x1e6f), /* USB3 D3 State */ U3DS, 3,
- offset (0x1e70), /* SD D3 Control */ - SDTD, 2, - , 1, - SDPD, 1, - , 1, - , 1, - SDRT, 1, - SDSC, 1, - offset (0x1e71), /* SD D3 State */ SDDS, 3,
@@ -421,14 +397,6 @@ } } /* todo Case(15) { STD0()} */ /* SATA */ - Case(24) { /* SD */ - Store(0x00, SDTD) - Store(One, SDPD) - Store(SDDS, Local0) - while(LNotEqual(Local0,0x7)) { - Store(SDDS, Local0) - } - } } } else { /* put device into D3cold */ @@ -482,20 +450,6 @@ Store(0x03, U1TD) } /* todo Case(15) { STD3()} */ /* SATA */ - Case(24) { /* SD */ - Store(Zero, SDPD) - Store(SDDS, Local0) - while(LNotEqual(Local0,0x0)) { - Store(SDDS, Local0) - } - Store(0x03, SDTD) - } - } - /* Turn off Power */ - if(LEqual(I0TD, 3)) { - if(LEqual(SATD, 3)) { - if(LEqual(SDTD, 3)) { Store(Zero, PG1A) } - } } if(LEqual(I1TD, 3)) { if(LEqual(I2TD, 3)) { diff --git a/src/soc/amd/picasso/chip.c b/src/soc/amd/picasso/chip.c index dad9d22..776f328 100644 --- a/src/soc/amd/picasso/chip.c +++ b/src/soc/amd/picasso/chip.c @@ -100,8 +100,6 @@ return "LPCB"; case SATA_DEVFN: return "STCR"; - case SD_DEVFN: - return "SDCN"; case SMBUS_DEVFN: return "SBUS"; case XHCI0_DEVFN: diff --git a/src/soc/amd/picasso/include/soc/pci_devs.h b/src/soc/amd/picasso/include/soc/pci_devs.h index c823fdb..8a885f2 100644 --- a/src/soc/amd/picasso/include/soc/pci_devs.h +++ b/src/soc/amd/picasso/include/soc/pci_devs.h @@ -188,11 +188,4 @@ #define LPC_DEVFN PCI_DEVFN(PCU_DEV, LPC_FUNC) #define SOC_LPC_DEV _SOC_DEV(PCU_DEV, LPC_FUNC)
-/* SD Controller */ -#define SD_DEV 0x14 -#define SD_FUNC 7 -#define SD_DEVID 0x7906 -#define SD_DEVFN PCI_DEVFN(SD_DEV, SD_FUNC) -#define SOC_SD_DEV _SOC_DEV(SD_DEV, SD_FUNC) - #endif /* __PI_PICASSO_PCI_DEVS_H__ */ diff --git a/src/soc/amd/picasso/include/soc/southbridge.h b/src/soc/amd/picasso/include/soc/southbridge.h index 4392e4f..0f72a68 100644 --- a/src/soc/amd/picasso/include/soc/southbridge.h +++ b/src/soc/amd/picasso/include/soc/southbridge.h @@ -303,9 +303,7 @@ unsigned int ut1e:1; /* 12: UART1 */ unsigned int :2; unsigned int st_e:1; /* 15: SATA */ - unsigned int :8; - unsigned int sd_e:1; /* 24: SDIO */ - unsigned int :2; + unsigned int :11; unsigned int espi:1; /* 27: ESPI */ unsigned int :4; } __packed aoac_devs_t; diff --git a/src/soc/amd/picasso/southbridge.c b/src/soc/amd/picasso/southbridge.c index dca3591..87b933e 100644 --- a/src/soc/amd/picasso/southbridge.c +++ b/src/soc/amd/picasso/southbridge.c @@ -578,7 +578,7 @@
static void set_sb_final_nvs(void) { - const struct device *sd, *sata; + const struct device *sata;
struct global_nvs_t *gnvs = cbmem_find(CBMEM_ID_ACPI_GNVS); if (gnvs == NULL) @@ -591,8 +591,6 @@ gnvs->aoac.ut0e = is_aoac_device_enabled(FCH_AOAC_D3_STATE_UART0); gnvs->aoac.ut1e = is_aoac_device_enabled(FCH_AOAC_D3_STATE_UART1); /* Rely on these being in sync with devicetree */ - sd = pcidev_path_on_root(SD_DEVFN); - gnvs->aoac.sd_e = sd && sd->enabled ? 1 : 0; sata = pcidev_path_on_root(SATA_DEVFN); gnvs->aoac.st_e = sata && sata->enabled ? 1 : 0; gnvs->aoac.espi = 1;
Martin Roth has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/33988 )
Patch Set 1: Code-Review+2
Martin Roth has submitted this change and it was merged. ( https://review.coreboot.org/c/coreboot/+/33988 )
Change-Id: Ie9cf361ed0caba9c73727453c4a503557edc854d Signed-off-by: Marshall Dawson marshalldawson3rd@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/33988 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Martin Roth martinroth@google.com --- M src/soc/amd/picasso/acpi/globalnvs.asl M src/soc/amd/picasso/acpi/sb_pci0_fch.asl M src/soc/amd/picasso/chip.c M src/soc/amd/picasso/include/soc/pci_devs.h M src/soc/amd/picasso/include/soc/southbridge.h M src/soc/amd/picasso/southbridge.c 6 files changed, 3 insertions(+), 64 deletions(-)
Approvals: build bot (Jenkins): Verified Martin Roth: Looks good to me, approved
