Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/15254
commit 94fba59891fc8235b8f4193b9f480eb52880de81 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Sat Jun 18 17:55:08 2016 +0300
AMD binaryPI: Use common ACPI S3 recovery
Note that no binaryPI board has HAVE_ACPI_RESUME.
Change-Id: Ic7d87aa81c75374dd1570cef412a3ca245285d58 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/cpu/amd/pi/s3_resume.c | 31 ++++++------------------------- 1 file changed, 6 insertions(+), 25 deletions(-)
diff --git a/src/cpu/amd/pi/s3_resume.c b/src/cpu/amd/pi/s3_resume.c index b6d3633..576a208 100644 --- a/src/cpu/amd/pi/s3_resume.c +++ b/src/cpu/amd/pi/s3_resume.c @@ -28,6 +28,7 @@ #include <string.h> #include "Porting.h" #include <northbridge/amd/pi/BiosCallOuts.h> +#include <halt.h> #include "s3_resume.h"
/* The size needs to be 4k aligned, which is the sector size of most flashes. */ @@ -134,24 +135,6 @@ void restore_mtrr(void) }
#ifdef __PRE_RAM__ -static void *backup_resume(void) -{ - void *resume_backup_memory; - - if (cbmem_recovery(1)) - return NULL; - - resume_backup_memory = cbmem_find(CBMEM_ID_RESUME); - if (((u32) resume_backup_memory == 0) - || ((u32) resume_backup_memory == -1)) { - printk(BIOS_ERR, "Error: resume_backup_memory: %x\n", - (u32) resume_backup_memory); - for (;;) ; - } - - return resume_backup_memory; -} - static void move_stack_high_mem(void) { void *high_stack; @@ -289,13 +272,14 @@ static void set_resume_cache(void)
void prepare_for_resume(void) { - printk(BIOS_DEBUG, "Find resume memory location\n"); - void *resume_backup_memory = backup_resume(); + if (cbmem_recovery(1)) { + printk(BIOS_EMERG, "Unable to recover CBMEM\n"); + halt(); + }
post_code(0x62); printk(BIOS_DEBUG, "Move CAR stack.\n"); move_stack_high_mem(); - printk(BIOS_DEBUG, "stack moved to: 0x%x\n", (u32) (resume_backup_memory + HIGH_MEMORY_SAVE));
post_code(0x63); disable_cache_as_ram(); @@ -306,9 +290,6 @@ void prepare_for_resume(void) * Copy the system memory that is in the ramstage area to the * reserved area. */ - if (resume_backup_memory) - memcpy(resume_backup_memory, (void *)(CONFIG_RAMBASE), HIGH_MEMORY_SAVE); - - printk(BIOS_DEBUG, "System memory saved. OK to load ramstage.\n"); + acpi_prepare_for_resume(); } #endif
