franlego98 franlego98 has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/34171 )
Change subject: add toshiba satellite u940 initial support ......................................................................
Change-Id: Ibaa45ddeed07c2757876e88e8c3d2f4e50d29d8e --- A src/mainboard/toshiba/Kconfig A src/mainboard/toshiba/Kconfig.name A src/mainboard/toshiba/satellite_u940/Kconfig A src/mainboard/toshiba/satellite_u940/Kconfig.name A src/mainboard/toshiba/satellite_u940/Makefile.inc A src/mainboard/toshiba/satellite_u940/acpi/ec.asl A src/mainboard/toshiba/satellite_u940/acpi/platform.asl A src/mainboard/toshiba/satellite_u940/acpi/superio.asl A src/mainboard/toshiba/satellite_u940/acpi_tables.c A src/mainboard/toshiba/satellite_u940/board_info.txt A src/mainboard/toshiba/satellite_u940/devicetree.cb A src/mainboard/toshiba/satellite_u940/dsdt.asl A src/mainboard/toshiba/satellite_u940/gma-mainboard.ads A src/mainboard/toshiba/satellite_u940/gpio.c A src/mainboard/toshiba/satellite_u940/hda_verb.c A src/mainboard/toshiba/satellite_u940/mainboard.c A src/mainboard/toshiba/satellite_u940/romstage.c 17 files changed, 852 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/71/34171/1
diff --git a/src/mainboard/toshiba/Kconfig b/src/mainboard/toshiba/Kconfig new file mode 100644 index 0000000..1466d64 --- /dev/null +++ b/src/mainboard/toshiba/Kconfig @@ -0,0 +1,16 @@ +if VENDOR_TOSHIBA + +choice + prompt "Mainboard model" + +source "src/mainboard/toshiba/*/Kconfig.name" + +endchoice + +source "src/mainboard/toshiba/*/Kconfig" + +config MAINBOARD_TOSHIBA + string + default "TOSHIBA" + +endif # VENDOR_TOSHIBA diff --git a/src/mainboard/toshiba/Kconfig.name b/src/mainboard/toshiba/Kconfig.name new file mode 100644 index 0000000..47dbb59 --- /dev/null +++ b/src/mainboard/toshiba/Kconfig.name @@ -0,0 +1,2 @@ +config VENDOR_TOSHIBA + bool "TOSHIBA" diff --git a/src/mainboard/toshiba/satellite_u940/Kconfig b/src/mainboard/toshiba/satellite_u940/Kconfig new file mode 100644 index 0000000..9a13486 --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/Kconfig @@ -0,0 +1,48 @@ +if BOARD_TOSHIBA_SATELLITE_U940 + +config BOARD_SPECIFIC_OPTIONS + def_bool y + select BOARD_ROMSIZE_KB_2048 # FIXME: correct this + select EC_ACPI + select HAVE_ACPI_RESUME + select HAVE_ACPI_TABLES + select INTEL_INT15 + select MAINBOARD_HAS_LIBGFXINIT # FIXME: check this + select NORTHBRIDGE_INTEL_SANDYBRIDGE + select SERIRQ_CONTINUOUS_MODE + select SOUTHBRIDGE_INTEL_C216 + select SYSTEM_TYPE_LAPTOP + select USE_NATIVE_RAMINIT + +config MAINBOARD_DIR + string + default toshiba/satellite_u940 + +config MAINBOARD_PART_NUMBER + string + default "SATELLITE U940" + +config MAINBOARD_VENDOR + string + default "TOSHIBA" + +config VGA_BIOS_FILE + string + default "pci8086,0166.rom" + +config VGA_BIOS_ID + string + default "8086,0166" + +config DRAM_RESET_GATE_GPIO # FIXME: check this + int + default 60 + +config MAX_CPUS + int + default 8 + +config USBDEBUG_HCD_INDEX # FIXME: check this + int + default 2 +endif diff --git a/src/mainboard/toshiba/satellite_u940/Kconfig.name b/src/mainboard/toshiba/satellite_u940/Kconfig.name new file mode 100644 index 0000000..d347bc8 --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/Kconfig.name @@ -0,0 +1,2 @@ +config BOARD_TOSHIBA_SATELLITE_U940 + bool "SATELLITE U940" diff --git a/src/mainboard/toshiba/satellite_u940/Makefile.inc b/src/mainboard/toshiba/satellite_u940/Makefile.inc new file mode 100644 index 0000000..ebe01ae --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/Makefile.inc @@ -0,0 +1,2 @@ +romstage-y += gpio.c +ramstage-$(CONFIG_MAINBOARD_USE_LIBGFXINIT) += gma-mainboard.ads diff --git a/src/mainboard/toshiba/satellite_u940/acpi/ec.asl b/src/mainboard/toshiba/satellite_u940/acpi/ec.asl new file mode 100644 index 0000000..8da2182 --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/acpi/ec.asl @@ -0,0 +1,24 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +Device(EC) +{ + Name (_HID, EISAID("PNP0C09")) + Name (_UID, 0) + Name (_GPE, 23) +/* FIXME: EC support */ +} diff --git a/src/mainboard/toshiba/satellite_u940/acpi/platform.asl b/src/mainboard/toshiba/satellite_u940/acpi/platform.asl new file mode 100644 index 0000000..c34ed7d --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/acpi/platform.asl @@ -0,0 +1,27 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +Method(_WAK,1) +{ + /* FIXME: EC support */ + Return(Package(){0,0}) +} + +Method(_PTS,1) +{ + /* FIXME: EC support */ +} diff --git a/src/mainboard/toshiba/satellite_u940/acpi/superio.asl b/src/mainboard/toshiba/satellite_u940/acpi/superio.asl new file mode 100644 index 0000000..4ede634 --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/acpi/superio.asl @@ -0,0 +1,18 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <drivers/pc80/pc/ps2_controller.asl> diff --git a/src/mainboard/toshiba/satellite_u940/acpi_tables.c b/src/mainboard/toshiba/satellite_u940/acpi_tables.c new file mode 100644 index 0000000..6b731cc --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/acpi_tables.c @@ -0,0 +1,36 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <southbridge/intel/bd82x6x/nvs.h> + +/* FIXME: check this function. */ +void acpi_create_gnvs(global_nvs_t *gnvs) +{ + /* Disable USB ports in S3 by default */ + gnvs->s3u0 = 0; + gnvs->s3u1 = 0; + + /* Disable USB ports in S5 by default */ + gnvs->s5u0 = 0; + gnvs->s5u1 = 0; + + // the lid is open by default. + gnvs->lids = 1; + + gnvs->tcrt = 100; + gnvs->tpsv = 90; +} diff --git a/src/mainboard/toshiba/satellite_u940/board_info.txt b/src/mainboard/toshiba/satellite_u940/board_info.txt new file mode 100644 index 0000000..db677c6 --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/board_info.txt @@ -0,0 +1,2 @@ +Category: laptop +FIXME: put ROM package, ROM socketed, ROM protocol, Flashrom support, Release year diff --git a/src/mainboard/toshiba/satellite_u940/devicetree.cb b/src/mainboard/toshiba/satellite_u940/devicetree.cb new file mode 100644 index 0000000..d1b5780 --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/devicetree.cb @@ -0,0 +1,116 @@ +chip northbridge/intel/sandybridge # FIXME: check gfx.ndid and gfx.did + register "gfx.did" = "{ 0x80000100, 0x80000240, 0x80000410 }" + register "gfx.link_frequency_270_mhz" = "0" + register "gfx.ndid" = "3" + register "gfx.use_spread_spectrum_clock" = "0" + register "gpu_cpu_backlight" = "0x00000000" + register "gpu_dp_b_hotplug" = "0" + register "gpu_dp_c_hotplug" = "0" + register "gpu_dp_d_hotplug" = "0" + register "gpu_panel_port_select" = "0" + register "gpu_panel_power_backlight_off_delay" = "0" + register "gpu_panel_power_backlight_on_delay" = "0" + register "gpu_panel_power_cycle_delay" = "0" + register "gpu_panel_power_down_delay" = "0" + register "gpu_panel_power_up_delay" = "0" + register "gpu_pch_backlight" = "0x00000000" + device cpu_cluster 0x0 on + chip cpu/intel/model_206ax # FIXME: check all registers + register "c1_acpower" = "1" + register "c1_battery" = "1" + register "c2_acpower" = "3" + register "c2_battery" = "3" + register "c3_acpower" = "5" + register "c3_battery" = "5" + device lapic 0x0 on + end + device lapic 0xacac off + end + end + end + device domain 0x0 on + chip southbridge/intel/bd82x6x # Intel Series 6 Cougar Point PCH + register "c2_latency" = "0x0065" + register "docking_supported" = "1" + register "gen1_dec" = "0x00040069" + register "gen2_dec" = "0x0004fd61" + register "gen3_dec" = "0x00000000" + register "gen4_dec" = "0x00000000" + register "gpi7_routing" = "2" + register "p_cnt_throttling_supported" = "0" + register "pcie_hotplug_map" = "{ 0, 0, 0, 0, 0, 0, 0, 0 }" + register "pcie_port_coalesce" = "1" + register "sata_interface_speed_support" = "0x3" + register "sata_port_map" = "0x3" + register "spi_lvscc" = "0x0" + register "spi_uvscc" = "0x0" + register "superspeed_capable_ports" = "0x0000000f" + register "xhci_overcurrent_mapping" = "0x08040201" + register "xhci_switchable_ports" = "0x0000000f" + device pci 14.0 on # USB 3.0 Controller + subsystemid 0x1179 0xfb30 + end + device pci 16.0 on # Management Engine Interface 1 + subsystemid 0x1179 0xfb30 + end + device pci 16.1 off # Management Engine Interface 2 + end + device pci 16.2 off # Management Engine IDE-R + end + device pci 16.3 off # Management Engine KT + end + device pci 19.0 off # Intel Gigabit Ethernet + end + device pci 1a.0 on # USB2 EHCI #2 + subsystemid 0x1179 0xfb30 + end + device pci 1b.0 on # High Definition Audio Audio controller + subsystemid 0x1179 0xfb30 + end + device pci 1c.0 on # PCIe Port #1 + subsystemid 0x1179 0xfb30 + end + device pci 1c.1 on # PCIe Port #2 + subsystemid 0x1179 0xfb30 + end + device pci 1c.2 off # PCIe Port #3 + end + device pci 1c.3 off # PCIe Port #4 + end + device pci 1c.4 off # PCIe Port #5 + end + device pci 1c.5 off # PCIe Port #6 + end + device pci 1c.6 off # PCIe Port #7 + end + device pci 1c.7 off # PCIe Port #8 + end + device pci 1d.0 on # USB2 EHCI #1 + subsystemid 0x1179 0xfb30 + end + device pci 1e.0 off # PCI bridge + end + device pci 1f.0 on # LPC bridge PCI-LPC bridge + subsystemid 0x1179 0xfb30 + end + device pci 1f.2 on # SATA Controller 1 Unsupported PCI device 8086:282a + subsystemid 0x1179 0xfb30 + end + device pci 1f.3 on # SMBus + subsystemid 0x1179 0xfb30 + end + device pci 1f.5 off # SATA Controller 2 + end + device pci 1f.6 off # Thermal + end + end + device pci 00.0 on # Host bridge Host bridge + subsystemid 0x1179 0xfb10 + end + device pci 01.0 off # PCIe Bridge for discrete graphics + end + device pci 02.0 on # Internal graphics VGA controller + subsystemid 0x1179 0xfb10 + end + end +end diff --git a/src/mainboard/toshiba/satellite_u940/dsdt.asl b/src/mainboard/toshiba/satellite_u940/dsdt.asl new file mode 100644 index 0000000..cdaf16d --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/dsdt.asl @@ -0,0 +1,46 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#define BRIGHTNESS_UP _SB.PCI0.GFX0.INCB +#define BRIGHTNESS_DOWN _SB.PCI0.GFX0.DECB +#define ACPI_VIDEO_DEVICE _SB.PCI0.GFX0 + +#include <arch/acpi.h> +DefinitionBlock( + "dsdt.aml", + "DSDT", + 0x02, // DSDT revision: ACPI 2.0 and up + OEM_ID, + ACPI_TABLE_CREATOR, + 0x20141018 // OEM revision +) +{ + /* Some generic macros */ + #include "acpi/platform.asl" + #include <cpu/intel/common/acpi/cpu.asl> + #include <southbridge/intel/bd82x6x/acpi/platform.asl> + /* global NVS and variables. */ + #include <southbridge/intel/bd82x6x/acpi/globalnvs.asl> + #include <southbridge/intel/bd82x6x/acpi/sleepstates.asl> + + Device (_SB.PCI0) + { + #include <northbridge/intel/sandybridge/acpi/sandybridge.asl> + #include <drivers/intel/gma/acpi/default_brightness_levels.asl> + #include <southbridge/intel/bd82x6x/acpi/pch.asl> + } +} diff --git a/src/mainboard/toshiba/satellite_u940/gma-mainboard.ads b/src/mainboard/toshiba/satellite_u940/gma-mainboard.ads new file mode 100644 index 0000000..ce27742 --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/gma-mainboard.ads @@ -0,0 +1,35 @@ +-- +-- This file is part of the coreboot project. +-- +-- This program is free software; you can redistribute it and/or modify +-- it under the terms of the GNU General Public License as published by +-- the Free Software Foundation; either version 2 of the License, or +-- (at your option) any later version. +-- +-- This program is distributed in the hope that it will be useful, +-- but WITHOUT ANY WARRANTY; without even the implied warranty of +-- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the +-- GNU General Public License for more details. +-- + +with HW.GFX.GMA; +with HW.GFX.GMA.Display_Probing; + +use HW.GFX.GMA; +use HW.GFX.GMA.Display_Probing; + +private package GMA.Mainboard is + + -- FIXME: check this + ports : constant Port_List := + (DP1, + DP2, + DP3, + HDMI1, + HDMI2, + HDMI3, + Analog, + Internal, + others => Disabled); + +end GMA.Mainboard; diff --git a/src/mainboard/toshiba/satellite_u940/gpio.c b/src/mainboard/toshiba/satellite_u940/gpio.c new file mode 100644 index 0000000..44c67ed --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/gpio.c @@ -0,0 +1,238 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <southbridge/intel/common/gpio.h> + +static const struct pch_gpio_set1 pch_gpio_set1_mode = { + .gpio0 = GPIO_MODE_GPIO, + .gpio1 = GPIO_MODE_GPIO, + .gpio2 = GPIO_MODE_GPIO, + .gpio3 = GPIO_MODE_GPIO, + .gpio4 = GPIO_MODE_GPIO, + .gpio5 = GPIO_MODE_GPIO, + .gpio6 = GPIO_MODE_GPIO, + .gpio7 = GPIO_MODE_GPIO, + .gpio8 = GPIO_MODE_GPIO, + .gpio9 = GPIO_MODE_NATIVE, + .gpio10 = GPIO_MODE_GPIO, + .gpio11 = GPIO_MODE_NATIVE, + .gpio12 = GPIO_MODE_GPIO, + .gpio13 = GPIO_MODE_NATIVE, + .gpio14 = GPIO_MODE_GPIO, + .gpio15 = GPIO_MODE_GPIO, + .gpio16 = GPIO_MODE_NATIVE, + .gpio17 = GPIO_MODE_GPIO, + .gpio18 = GPIO_MODE_NATIVE, + .gpio19 = GPIO_MODE_NATIVE, + .gpio20 = GPIO_MODE_GPIO, + .gpio21 = GPIO_MODE_NATIVE, + .gpio22 = GPIO_MODE_GPIO, + .gpio23 = GPIO_MODE_NATIVE, + .gpio24 = GPIO_MODE_GPIO, + .gpio25 = GPIO_MODE_NATIVE, + .gpio26 = GPIO_MODE_NATIVE, + .gpio27 = GPIO_MODE_GPIO, + .gpio28 = GPIO_MODE_GPIO, + .gpio29 = GPIO_MODE_GPIO, + .gpio30 = GPIO_MODE_NATIVE, + .gpio31 = GPIO_MODE_NATIVE, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_direction = { + .gpio0 = GPIO_DIR_INPUT, + .gpio1 = GPIO_DIR_INPUT, + .gpio2 = GPIO_DIR_INPUT, + .gpio3 = GPIO_DIR_INPUT, + .gpio4 = GPIO_DIR_OUTPUT, + .gpio5 = GPIO_DIR_INPUT, + .gpio6 = GPIO_DIR_INPUT, + .gpio7 = GPIO_DIR_INPUT, + .gpio8 = GPIO_DIR_INPUT, + .gpio10 = GPIO_DIR_INPUT, + .gpio12 = GPIO_DIR_OUTPUT, + .gpio14 = GPIO_DIR_INPUT, + .gpio15 = GPIO_DIR_INPUT, + .gpio17 = GPIO_DIR_INPUT, + .gpio20 = GPIO_DIR_OUTPUT, + .gpio22 = GPIO_DIR_INPUT, + .gpio24 = GPIO_DIR_OUTPUT, + .gpio27 = GPIO_DIR_OUTPUT, + .gpio28 = GPIO_DIR_OUTPUT, + .gpio29 = GPIO_DIR_OUTPUT, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_level = { + .gpio4 = GPIO_LEVEL_LOW, + .gpio12 = GPIO_LEVEL_HIGH, + .gpio20 = GPIO_LEVEL_LOW, + .gpio24 = GPIO_LEVEL_LOW, + .gpio27 = GPIO_LEVEL_LOW, + .gpio28 = GPIO_LEVEL_LOW, + .gpio29 = GPIO_LEVEL_HIGH, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_reset = { + .gpio24 = GPIO_RESET_RSMRST, + .gpio30 = GPIO_RESET_RSMRST, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_invert = { + .gpio1 = GPIO_INVERT, + .gpio3 = GPIO_INVERT, + .gpio7 = GPIO_INVERT, + .gpio8 = GPIO_INVERT, + .gpio10 = GPIO_INVERT, + .gpio14 = GPIO_INVERT, + .gpio15 = GPIO_INVERT, +}; + +static const struct pch_gpio_set1 pch_gpio_set1_blink = { +}; + +static const struct pch_gpio_set2 pch_gpio_set2_mode = { + .gpio32 = GPIO_MODE_NATIVE, + .gpio33 = GPIO_MODE_NATIVE, + .gpio34 = GPIO_MODE_GPIO, + .gpio35 = GPIO_MODE_NATIVE, + .gpio36 = GPIO_MODE_NATIVE, + .gpio37 = GPIO_MODE_GPIO, + .gpio38 = GPIO_MODE_GPIO, + .gpio39 = GPIO_MODE_GPIO, + .gpio40 = GPIO_MODE_NATIVE, + .gpio41 = GPIO_MODE_NATIVE, + .gpio42 = GPIO_MODE_GPIO, + .gpio43 = GPIO_MODE_GPIO, + .gpio44 = GPIO_MODE_NATIVE, + .gpio45 = GPIO_MODE_GPIO, + .gpio46 = GPIO_MODE_GPIO, + .gpio47 = GPIO_MODE_NATIVE, + .gpio48 = GPIO_MODE_GPIO, + .gpio49 = GPIO_MODE_GPIO, + .gpio50 = GPIO_MODE_GPIO, + .gpio51 = GPIO_MODE_GPIO, + .gpio52 = GPIO_MODE_GPIO, + .gpio53 = GPIO_MODE_GPIO, + .gpio54 = GPIO_MODE_GPIO, + .gpio55 = GPIO_MODE_GPIO, + .gpio56 = GPIO_MODE_GPIO, + .gpio57 = GPIO_MODE_GPIO, + .gpio58 = GPIO_MODE_NATIVE, + .gpio59 = GPIO_MODE_NATIVE, + .gpio60 = GPIO_MODE_GPIO, + .gpio61 = GPIO_MODE_NATIVE, + .gpio62 = GPIO_MODE_NATIVE, + .gpio63 = GPIO_MODE_NATIVE, +}; + +static const struct pch_gpio_set2 pch_gpio_set2_direction = { + .gpio34 = GPIO_DIR_OUTPUT, + .gpio37 = GPIO_DIR_OUTPUT, + .gpio38 = GPIO_DIR_INPUT, + .gpio39 = GPIO_DIR_INPUT, + .gpio42 = GPIO_DIR_OUTPUT, + .gpio43 = GPIO_DIR_OUTPUT, + .gpio45 = GPIO_DIR_INPUT, + .gpio46 = GPIO_DIR_INPUT, + .gpio48 = GPIO_DIR_INPUT, + .gpio49 = GPIO_DIR_OUTPUT, + .gpio50 = GPIO_DIR_OUTPUT, + .gpio51 = GPIO_DIR_OUTPUT, + .gpio52 = GPIO_DIR_OUTPUT, + .gpio53 = GPIO_DIR_OUTPUT, + .gpio54 = GPIO_DIR_OUTPUT, + .gpio55 = GPIO_DIR_OUTPUT, + .gpio56 = GPIO_DIR_INPUT, + .gpio57 = GPIO_DIR_INPUT, + .gpio60 = GPIO_DIR_OUTPUT, +}; + +static const struct pch_gpio_set2 pch_gpio_set2_level = { + .gpio34 = GPIO_LEVEL_LOW, + .gpio37 = GPIO_LEVEL_LOW, + .gpio42 = GPIO_LEVEL_LOW, + .gpio43 = GPIO_LEVEL_HIGH, + .gpio49 = GPIO_LEVEL_LOW, + .gpio50 = GPIO_LEVEL_HIGH, + .gpio51 = GPIO_LEVEL_LOW, + .gpio52 = GPIO_LEVEL_HIGH, + .gpio53 = GPIO_LEVEL_HIGH, + .gpio54 = GPIO_LEVEL_HIGH, + .gpio55 = GPIO_LEVEL_HIGH, + .gpio60 = GPIO_LEVEL_HIGH, +}; + +static const struct pch_gpio_set2 pch_gpio_set2_reset = { +}; + +static const struct pch_gpio_set3 pch_gpio_set3_mode = { + .gpio64 = GPIO_MODE_NATIVE, + .gpio65 = GPIO_MODE_NATIVE, + .gpio66 = GPIO_MODE_GPIO, + .gpio67 = GPIO_MODE_GPIO, + .gpio68 = GPIO_MODE_GPIO, + .gpio69 = GPIO_MODE_GPIO, + .gpio70 = GPIO_MODE_GPIO, + .gpio71 = GPIO_MODE_GPIO, + .gpio72 = GPIO_MODE_NATIVE, + .gpio73 = GPIO_MODE_NATIVE, + .gpio74 = GPIO_MODE_GPIO, + .gpio75 = GPIO_MODE_NATIVE, +}; + +static const struct pch_gpio_set3 pch_gpio_set3_direction = { + .gpio66 = GPIO_DIR_OUTPUT, + .gpio67 = GPIO_DIR_INPUT, + .gpio68 = GPIO_DIR_OUTPUT, + .gpio69 = GPIO_DIR_OUTPUT, + .gpio70 = GPIO_DIR_OUTPUT, + .gpio71 = GPIO_DIR_INPUT, + .gpio74 = GPIO_DIR_OUTPUT, +}; + +static const struct pch_gpio_set3 pch_gpio_set3_level = { + .gpio66 = GPIO_LEVEL_LOW, + .gpio68 = GPIO_LEVEL_LOW, + .gpio69 = GPIO_LEVEL_LOW, + .gpio70 = GPIO_LEVEL_LOW, + .gpio74 = GPIO_LEVEL_HIGH, +}; + +static const struct pch_gpio_set3 pch_gpio_set3_reset = { +}; + +const struct pch_gpio_map mainboard_gpio_map = { + .set1 = { + .mode = &pch_gpio_set1_mode, + .direction = &pch_gpio_set1_direction, + .level = &pch_gpio_set1_level, + .blink = &pch_gpio_set1_blink, + .invert = &pch_gpio_set1_invert, + .reset = &pch_gpio_set1_reset, + }, + .set2 = { + .mode = &pch_gpio_set2_mode, + .direction = &pch_gpio_set2_direction, + .level = &pch_gpio_set2_level, + .reset = &pch_gpio_set2_reset, + }, + .set3 = { + .mode = &pch_gpio_set3_mode, + .direction = &pch_gpio_set3_direction, + .level = &pch_gpio_set3_level, + .reset = &pch_gpio_set3_reset, + }, +}; diff --git a/src/mainboard/toshiba/satellite_u940/hda_verb.c b/src/mainboard/toshiba/satellite_u940/hda_verb.c new file mode 100644 index 0000000..d1a1cec --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/hda_verb.c @@ -0,0 +1,76 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <device/azalia_device.h> + +const u32 cim_verb_data[] = { + 0x10ec0269, /* Codec Vendor / Device ID: Realtek */ + 0x1179fb14, /* Subsystem ID */ + + 0x0000000b, /* Number of 4 dword sets */ + /* NID 0x01: Subsystem ID. */ + AZALIA_SUBVENDOR(0x0, 0x1179fb14), + + /* NID 0x12. */ + AZALIA_PIN_CFG(0x0, 0x12, 0x90a60940), + + /* NID 0x14. */ + AZALIA_PIN_CFG(0x0, 0x14, 0x90170110), + + /* NID 0x15. */ + AZALIA_PIN_CFG(0x0, 0x15, 0x0421101f), + + /* NID 0x17. */ + AZALIA_PIN_CFG(0x0, 0x17, 0x411111f0), + + /* NID 0x18. */ + AZALIA_PIN_CFG(0x0, 0x18, 0x04a11830), + + /* NID 0x19. */ + AZALIA_PIN_CFG(0x0, 0x19, 0x411111f0), + + /* NID 0x1a. */ + AZALIA_PIN_CFG(0x0, 0x1a, 0x411111f0), + + /* NID 0x1b. */ + AZALIA_PIN_CFG(0x0, 0x1b, 0x411111f0), + + /* NID 0x1d. */ + AZALIA_PIN_CFG(0x0, 0x1d, 0x4005822d), + + /* NID 0x1e. */ + AZALIA_PIN_CFG(0x0, 0x1e, 0x411111f0), + 0x80862806, /* Codec Vendor / Device ID: Intel */ + 0x1179fb30, /* Subsystem ID */ + + 0x00000004, /* Number of 4 dword sets */ + /* NID 0x01: Subsystem ID. */ + AZALIA_SUBVENDOR(0x3, 0x1179fb30), + + /* NID 0x05. */ + AZALIA_PIN_CFG(0x3, 0x05, 0x18560010), + + /* NID 0x06. */ + AZALIA_PIN_CFG(0x3, 0x06, 0x58560020), + + /* NID 0x07. */ + AZALIA_PIN_CFG(0x3, 0x07, 0x58560030), +}; + +const u32 pc_beep_verbs[0] = {}; + +AZALIA_ARRAY_SIZES; diff --git a/src/mainboard/toshiba/satellite_u940/mainboard.c b/src/mainboard/toshiba/satellite_u940/mainboard.c new file mode 100644 index 0000000..b15efaf --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/mainboard.c @@ -0,0 +1,85 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +#include <device/device.h> +#include <drivers/intel/gma/int15.h> +#include <southbridge/intel/bd82x6x/pch.h> +#include <ec/acpi/ec.h> +#include <console/console.h> +#include <pc80/keyboard.h> + +static void mainboard_init(struct device *dev) +{ + /* FIXME: trim this down or remove if necessary */ + { + int i; + const u8 dmp[256] = { + /* 00 */ 0x1b, 0x00, 0x00, 0x00, 0x10, 0x19, 0x00, 0x20, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 10 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 20 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 30 */ 0x00, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x00, + 0x07, 0x00, 0x04, 0x0a, 0x14, 0x00, 0x00, + /* 40 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 50 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 60 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 70 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 80 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* 90 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* a0 */ 0x00, 0x00, 0x00, 0x84, 0x81, 0x00, 0x00, 0x61, 0x64, + 0x00, 0x00, 0x08, 0x64, 0x19, 0x00, 0x98, + /* b0 */ 0x00, 0x00, 0x00, 0x3a, 0xff, 0x00, 0x00, 0x00, 0x00, + 0x07, 0x00, 0x1f, 0x00, 0x0b, 0x00, 0x00, + /* c0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* d0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xff, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* e0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + /* f0 */ 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, + }; + + printk(BIOS_DEBUG, "Replaying EC dump ..."); + for (i = 0; i < 256; i++) + ec_write (i, dmp[i]); + printk(BIOS_DEBUG, "done\n"); + } + pc_keyboard_init(NO_AUX_DEVICE); +} + +static void mainboard_enable(struct device *dev) +{ + dev->ops->init = mainboard_init; + + /* FIXME: fix those values*/ + install_intel_vga_int15_handler(GMA_INT15_ACTIVE_LFP_INT_LVDS, + GMA_INT15_PANEL_FIT_DEFAULT, + GMA_INT15_BOOT_DISPLAY_DEFAULT, 0); +} + +struct chip_operations mainboard_ops = { + .enable_dev = mainboard_enable, +}; diff --git a/src/mainboard/toshiba/satellite_u940/romstage.c b/src/mainboard/toshiba/satellite_u940/romstage.c new file mode 100644 index 0000000..b90e7bd --- /dev/null +++ b/src/mainboard/toshiba/satellite_u940/romstage.c @@ -0,0 +1,79 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2008-2009 coresystems GmbH + * Copyright (C) 2014 Vladimir Serbinenko + * + * This program is free software; you can redistribute it and/or + * modify it under the terms of the GNU General Public License as + * published by the Free Software Foundation; version 2 of + * the License. + * + * This program is distributed in the hope that it will be useful, + * but WITHOUT ANY WARRANTY; without even the implied warranty of + * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the + * GNU General Public License for more details. + */ + +/* FIXME: Check if all includes are needed. */ + +#include <stdint.h> +#include <string.h> +#include <timestamp.h> +#include <arch/byteorder.h> +#include <device/mmio.h> +#include <device/pci_ops.h> +#include <device/pnp_ops.h> +#include <console/console.h> +#include <northbridge/intel/sandybridge/sandybridge.h> +#include <northbridge/intel/sandybridge/raminit_native.h> +#include <southbridge/intel/bd82x6x/pch.h> +#include <southbridge/intel/common/gpio.h> + +void pch_enable_lpc(void) +{ + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x82, 0x3c00); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x84, 0x00040069); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x88, 0x0004fd61); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x8c, 0x00000000); + pci_write_config32(PCI_DEV(0, 0x1f, 0), 0x90, 0x00000000); + pci_write_config16(PCI_DEV(0, 0x1f, 0), 0x80, 0x0000); +} + +void mainboard_rcba_config(void) +{ +} + +const struct southbridge_usb_port mainboard_usb_ports[] = { + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, + { 1, 0, -1 }, +}; + +void mainboard_early_init(int s3resume) +{ +} + +void mainboard_config_superio(void) +{ +} + +/* FIXME: Put proper SPD map here. */ +void mainboard_get_spd(spd_raw_data *spd, bool id_only) +{ + read_spd(&spd[0], 0x50, id_only); + read_spd(&spd[1], 0x51, id_only); + read_spd(&spd[2], 0x52, id_only); + read_spd(&spd[3], 0x53, id_only); +}
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/34171 )
Patch Set 1:
https://review.coreboot.org/c/coreboot/+/34171/1/src/mainboard/toshiba/satel... File src/mainboard/toshiba/satellite_u940/mainboard.c:
https://review.coreboot.org/c/coreboot/+/34171/1/src/mainboard/toshiba/satel... PS1, Line 67: ec_write (i, dmp[i]); space prohibited between function name and open parenthesis '('
franlego98 franlego98 has abandoned this change. ( https://review.coreboot.org/c/coreboot/+/34171 )
Abandoned
duplicate commit
