Attention is currently required from: David Wu, Karthik Ramasubramanian, Kenneth Chan, Ren Kuo, Shelley Chen.
Hello David Wu, Karthik Ramasubramanian, Kenneth Chan, Shelley Chen, build bot (Jenkins),
https://review.coreboot.org/c/coreboot/+/84413?usp=email
The following approvals got outdated and were removed: Code-Review+2 by Karthik Ramasubramanian, Verified+1 by build bot (Jenkins)
Change subject: mb/google/brox/jubilant: Modify start-up timing for WWAN RW101R-GL ......................................................................
Modify start-up timing for WWAN RW101R-GL to follow spec: PWR_EN H H H FCPO# Tpr H H RESET# L Ton H
Tpr: delay for Power stable (>0ms) Ton: delay for reset time (>10ms)
BUG=b:349698817 BRANCH=None TEST= Build firmware and verify on jubilant with RW101R-GL Measure the start-up timing sequence to meet spec Boot up in OS, and confirm WWAN can connect to cell site
Change-Id: I7aa3e7a172143ff1cebea7f48bda45d4fb2c77f7 Signed-off-by: Ren Kuo ren.kuo@quanta.corp-partner.google.com --- M src/mainboard/google/brox/variants/jubilant/gpio.c 1 file changed, 19 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/13/84413/3
