Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/84235?usp=email )
Change subject: mb/google/kahlee: Add Kconfig to set IGD UMA allocation ......................................................................
Add a Kconfig choice to select the IGD UMA allocation. Default to the previous value (32MB).
TEST=build/boot google/liara, verify UMA size changes with selection.
Change-Id: Ia53d6d39d4f06c896ec13808234144b89da101f8 Signed-off-by: Matt DeVillier matt.devillier@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/84235 Reviewed-by: Felix Held felix-coreboot@felixheld.de Tested-by: build bot (Jenkins) no-reply@coreboot.org --- M src/mainboard/google/kahlee/Kconfig M src/mainboard/google/kahlee/variants/baseboard/devicetree.cb 2 files changed, 28 insertions(+), 1 deletion(-)
diff --git a/src/mainboard/google/kahlee/Kconfig b/src/mainboard/google/kahlee/Kconfig index 86632db..60630fe 100644 --- a/src/mainboard/google/kahlee/Kconfig +++ b/src/mainboard/google/kahlee/Kconfig @@ -172,4 +172,31 @@ default n if CHROMEOS default y
+choice + prompt "UMA Memory Allocation" + default KAHLEE_UMA_SIZE_32MB + help + The amount of system memory allocated for the integrated GPU + +config KAHLEE_UMA_SIZE_32MB + bool "32MB" + +config KAHLEE_UMA_SIZE_64MB + bool "64MB" + +config KAHLEE_UMA_SIZE_128MB + bool "128MB" + +config KAHLEE_UMA_SIZE_256MB + bool "256MB" + +endchoice + +config UMA_SIZE_IN_MB + int + default 32 if KAHLEE_UMA_SIZE_32MB + default 64 if KAHLEE_UMA_SIZE_64MB + default 128 if KAHLEE_UMA_SIZE_128MB + default 256 if KAHLEE_UMA_SIZE_256MB + endif # BOARD_GOOGLE_BASEBOARD_KAHLEE diff --git a/src/mainboard/google/kahlee/variants/baseboard/devicetree.cb b/src/mainboard/google/kahlee/variants/baseboard/devicetree.cb index ef7839d..ca8933a 100644 --- a/src/mainboard/google/kahlee/variants/baseboard/devicetree.cb +++ b/src/mainboard/google/kahlee/variants/baseboard/devicetree.cb @@ -8,7 +8,7 @@ }" register "dram_clear_on_reset" = "DRAM_CONTENTS_KEEP" register "uma_mode" = "UMAMODE_SPECIFIED_SIZE" - register "uma_size" = "32 * MiB" + register "uma_size" = "CONFIG_UMA_SIZE_IN_MB * MiB"
register "i2c_scl_reset" = "GPIO_I2C0_SCL | GPIO_I2C1_SCL | GPIO_I2C2_SCL | GPIO_I2C3_SCL"
