Matt DeVillier (matt.devillier@gmail.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/18249
commit 7b8dd5275f8fd7e39cfd78518370ceb075fe1dda Author: Matt DeVillier matt.devillier@gmail.com Date: Thu Jan 26 10:58:15 2017 -0600
google/jecht: Fix LED for guado/rikku variants
When guado/rikku/tidus were rolled into jecht, an error was made in set_power_led() as guado/rikku set the polarity differently than tidus. Fix the power LED for guado/rikku by setting the polarity correctly.
Test: boot guado/rikku and observe proper function of power LED under S0, S3, and S5 power states.
Change-Id: I23072ac60bc9683776f748ca1326d98257c3c54f Signed-off-by: Matt DeVillier matt.devillier@gmail.com --- src/mainboard/google/jecht/led.c | 10 +++++++++- 1 file changed, 9 insertions(+), 1 deletion(-)
diff --git a/src/mainboard/google/jecht/led.c b/src/mainboard/google/jecht/led.c index 50cf32e..286b65e 100644 --- a/src/mainboard/google/jecht/led.c +++ b/src/mainboard/google/jecht/led.c @@ -19,10 +19,18 @@
void set_power_led(int state) { + int polarity; + + if (IS_ENABLED(CONFIG_BOARD_GOOGLE_TIDUS)) { + polarity = state == LED_OFF ? 0x00 : 0x01; + } else { + polarity = state == LED_BLINK ? 0x01 : 0x00; + } + it8772f_gpio_led(IT8772F_GPIO_DEV, 1, /* set */ 0x01, /* select */ - state == LED_OFF ? 0x00 : 0x01, /* polarity */ + polarity, /* polarity */ state == LED_BLINK ? 0x01 : 0x00, /* pullup/pulldown */ 0x01, /* output */ state == LED_BLINK ? 0x00 : 0x01, /* I/O function */
