Marc Jones has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/47579 )
Change subject: soc/intel/xeon_sp: Fix skx NVME drive boot issue ......................................................................
Skx FSP doesn't support x2apic setup, but cpx does. The skx DMAR table needs the X2API opt out flag set. This fixes an issue with the NVME driver loading on a kexec'd kernel. The change is easy to see in the coreboot output: [DMA Remapping table] Flags: 0x3 or in the DMAR ACPI table.
Change-Id: Iec977c893b70e30875d9a92f24af009c1e90389e Signed-off-by: Marc Jones marcjones@sysproconsulting.com --- M src/soc/intel/xeon_sp/nb_acpi.c 1 file changed, 6 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/47579/1
diff --git a/src/soc/intel/xeon_sp/nb_acpi.c b/src/soc/intel/xeon_sp/nb_acpi.c index 55c3d82..1b28f2d 100644 --- a/src/soc/intel/xeon_sp/nb_acpi.c +++ b/src/soc/intel/xeon_sp/nb_acpi.c @@ -443,9 +443,13 @@ if (config->vtd_support) { current = ALIGN(current, 8); dmar = (acpi_dmar_t *)current; + enum dmar_flags flags = DMAR_INTR_REMAP; +#if (CONFIG(SOC_INTEL_SKYLAKE_SP)) + flags |= DMAR_X2APIC_OPT_OUT; +#endif printk(BIOS_DEBUG, "ACPI: * DMAR\n"); - printk(BIOS_DEBUG, "[DMA Remapping table] Flags: 0x%x\n", DMAR_INTR_REMAP); - acpi_create_dmar(dmar, DMAR_INTR_REMAP, acpi_fill_dmar); + printk(BIOS_DEBUG, "[DMA Remapping table] Flags: 0x%x\n", flags); + acpi_create_dmar(dmar, flags, acpi_fill_dmar); current += dmar->header.length; current = acpi_align_current(current); acpi_add_table(rsdp, dmar);
Javier Galindo has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
Patch Set 1: Code-Review+1
Jonathan Zhang has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
Patch Set 1: Code-Review+2
Thanks for fixing this, Javier/Marc!
Hello Jonathan Zhang, Jay Talbott, Stefan Reinauer, Angel Pons, Arthur Heymans, Javier Galindo, Patrick Rudolph,
Change subject: soc/intel/xeon_sp: Fix skx SATA drive boot issue ......................................................................
Skx FSP doesn't support x2apic setup, but cpx does. The skx DMAR table needs the X2API opt out flag set. This fixes the hang loading a kexec'd kernel. The change is easy to see in the coreboot output: [DMA Remapping table] Flags: 0x3 or in the DMAR ACPI table.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/47579/2
Jay Talbott has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
Patch Set 2: Code-Review+1
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
https://review.coreboot.org/c/coreboot/+/47579/2//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/47579/2//COMMIT_MSG@10 PS2, Line 10: X2API X2APIC
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
https://review.coreboot.org/c/coreboot/+/47579/2/src/soc/intel/xeon_sp/nb_ac... File src/soc/intel/xeon_sp/nb_acpi.c:
https://review.coreboot.org/c/coreboot/+/47579/2/src/soc/intel/xeon_sp/nb_ac... PS2, Line 447: #if Can you do this with C code and add a comment?
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
(5 comments)
https://review.coreboot.org/c/coreboot/+/47579/2//COMMIT_MSG@9 PS2, Line 9: cpx CPX
https://review.coreboot.org/c/coreboot/+/47579/2//COMMIT_MSG@9 PS2, Line 9: Skx I'd use uppercase: SKX
https://review.coreboot.org/c/coreboot/+/47579/2//COMMIT_MSG@9 PS2, Line 9: x2apic I'd use uppercase: X2APIC
https://review.coreboot.org/c/coreboot/+/47579/2//COMMIT_MSG@9 PS2, Line 9: skx SKX
Definitely:
/* SKX FSP doesn't support X2APIC, but CPX FSP does */ if (CONFIG(SOC_INTEL_SKYLAKE_SP)) flags |= DMAR_X2APIC_OPT_OUT;
Hello build bot (Jenkins), Jonathan Zhang, Jay Talbott, Johnny Lin, Paul Menzel, Stefan Reinauer, Angel Pons, Arthur Heymans, Javier Galindo, Patrick Rudolph,
Change subject: soc/intel/xeon_sp: Fix SKX SATA drive boot issue ......................................................................
SkX FSP doesn't support X2APIC setup, but CPX does. The CPX DMAR table needs the X2API opt out flag set. This fixes the hang loading a kexec'd kernel. The change is easy to see in the coreboot output: [DMA Remapping table] Flags: 0x3 or in the DMAR ACPI table.
Change-Id: Iec977c893b70e30875d9a92f24af009c1e90389e Signed-off-by: Marc Jones marcjones@sysproconsulting.com --- M src/soc/intel/xeon_sp/nb_acpi.c 1 file changed, 8 insertions(+), 2 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/47579/3
Marc Jones has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
Patch Set 3:
(6 comments)
CPX
Done
Done
SKX
Done
Done
X2APIC
Done
Definitely: […]
Done
Stefan Reinauer has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
Patch Set 3: Code-Review+2
Patch Set 3:
(2 comments)
Done
Not Done.
https://review.coreboot.org/c/coreboot/+/47579/3//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/47579/3//COMMIT_MSG@9 PS3, Line 9: SkX SKX
Hello build bot (Jenkins), Jonathan Zhang, Jay Talbott, Johnny Lin, Stefan Reinauer, Paul Menzel, Angel Pons, Arthur Heymans, Javier Galindo, Patrick Rudolph,
SKX FSP doesn't support X2APIC setup, but CPX does. The CPX DMAR table needs the X2APIC opt out flag set. This fixes the hang loading a kexec'd kernel. The change is easy to see in the coreboot output: [DMA Remapping table] Flags: 0x3 or in the DMAR ACPI table.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/79/47579/4
Patch Set 4:
(2 comments)
Not Done.
Done
SKX
Done
Marc Jones has submitted this change. ( https://review.coreboot.org/c/coreboot/+/47579 )
Change-Id: Iec977c893b70e30875d9a92f24af009c1e90389e Signed-off-by: Marc Jones marcjones@sysproconsulting.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/47579 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Stefan Reinauer stefan.reinauer@coreboot.org --- M src/soc/intel/xeon_sp/nb_acpi.c 1 file changed, 8 insertions(+), 2 deletions(-)
Approvals: build bot (Jenkins): Verified Stefan Reinauer: Looks good to me, approved
diff --git a/src/soc/intel/xeon_sp/nb_acpi.c b/src/soc/intel/xeon_sp/nb_acpi.c index 4a44980..6d6eb00 100644 --- a/src/soc/intel/xeon_sp/nb_acpi.c +++ b/src/soc/intel/xeon_sp/nb_acpi.c @@ -434,9 +434,15 @@ if (config->vtd_support) { current = ALIGN(current, 8); dmar = (acpi_dmar_t *)current; + enum dmar_flags flags = DMAR_INTR_REMAP; + + /* SKX FSP doesn't support X2APIC, but CPX FSP does */ + if (CONFIG(SOC_INTEL_SKYLAKE_SP)) + flags |= DMAR_X2APIC_OPT_OUT; + printk(BIOS_DEBUG, "ACPI: * DMAR\n"); - printk(BIOS_DEBUG, "[DMA Remapping table] Flags: 0x%x\n", DMAR_INTR_REMAP); - acpi_create_dmar(dmar, DMAR_INTR_REMAP, acpi_fill_dmar); + printk(BIOS_DEBUG, "[DMA Remapping table] Flags: 0x%x\n", flags); + acpi_create_dmar(dmar, flags, acpi_fill_dmar); current += dmar->header.length; current = acpi_align_current(current); acpi_add_table(rsdp, dmar);
Patch Set 5: Code-Review+1
