Nico Huber (nico.h@gmx.de) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16012
commit 24f5ae8f28e42ffc06357ac611d9f88679690d12 Author: Nico Huber nico.h@gmx.de Date: Mon Aug 1 21:37:42 2016 +0200
cbfstool: Check arguments to strtoul() where appropriate
The interface to strtoul() is a weird mess. It may or may not set errno if no conversion is done. So check for empty strings and trailing characters.
Change-Id: I82373d2a0102fc89144bd12376b5ea3b10c70153 Signed-off-by: Nico Huber nico.h@gmx.de --- util/cbfstool/cbfstool.c | 82 +++++++++++++++++++++++++++++++++++++++++------- 1 file changed, 70 insertions(+), 12 deletions(-)
diff --git a/util/cbfstool/cbfstool.c b/util/cbfstool/cbfstool.c index 7b30ce9..f448acf 100644 --- a/util/cbfstool/cbfstool.c +++ b/util/cbfstool/cbfstool.c @@ -1350,24 +1350,51 @@ int main(int argc, char **argv) param.source_region = optarg; break; case 'b': - param.baseaddress = strtoul(optarg, NULL, 0); + param.baseaddress = strtoul(optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid base address '%s'.\n", + optarg); + return 1; + } // baseaddress may be zero on non-x86, so we // need an explicit "baseaddress_assigned". param.baseaddress_assigned = 1; break; case 'l': - param.loadaddress = strtoul(optarg, NULL, 0); + param.loadaddress = strtoul(optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid load address '%s'.\n", + optarg); + return 1; + } break; case 'e': - param.entrypoint = strtoul(optarg, NULL, 0); + param.entrypoint = strtoul(optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid entry point '%s'.\n", + optarg); + return 1; + } break; case 's': param.size = strtoul(optarg, &suffix, 0); - if (tolower((int)suffix[0])=='k') { - param.size *= 1024; + if (!*optarg) { + ERROR("Empty size specified.\n"); + return 1; } - if (tolower((int)suffix[0])=='m') { + switch (tolower((int)suffix[0])) { + case 'k': + param.size *= 1024; + break; + case 'm': param.size *= 1024 * 1024; + break; + case '0': + break; + default: + ERROR("Invalid suffix for size '%s'.\n", + optarg); + return 1; } break; case 'B': @@ -1375,24 +1402,49 @@ int main(int argc, char **argv) break; case 'H': param.headeroffset = strtoul( - optarg, NULL, 0); + optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid header offset '%s'.\n", + optarg); + return 1; + } param.headeroffset_assigned = 1; break; case 'a': - param.alignment = strtoul(optarg, NULL, 0); + param.alignment = strtoul(optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid alignment '%s'.\n", + optarg); + return 1; + } break; case 'P': - param.pagesize = strtoul(optarg, NULL, 0); + param.pagesize = strtoul(optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid page size '%s'.\n", + optarg); + return 1; + } break; case 'o': - param.cbfsoffset = strtoul(optarg, NULL, 0); + param.cbfsoffset = strtoul(optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid cbfs offset '%s'.\n", + optarg); + return 1; + } param.cbfsoffset_assigned = 1; break; case 'f': param.filename = optarg; break; case 'i': - param.u64val = strtoull(optarg, NULL, 0); + param.u64val = strtoull(optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid int parameter '%s'.\n", + optarg); + return 1; + } break; case 'u': param.fill_partial_upward = true; @@ -1404,7 +1456,13 @@ int main(int argc, char **argv) param.show_immutable = true; break; case 'x': - param.fit_empty_entries = strtol(optarg, NULL, 0); + param.fit_empty_entries = strtol( + optarg, &suffix, 0); + if (!*optarg || (suffix && *suffix)) { + ERROR("Invalid number of fit entries " + "'%s'.\n", optarg); + return 1; + } break; case 'v': verbose++;
