Barnali Sarkar (barnali.sarkar@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/17635
commit 8cd0e651f6404b98ceeb786628ae4b4ad8c87fbc Author: Barnali Sarkar barnali.sarkar@intel.com Date: Tue Nov 29 12:05:28 2016 +0530
mainboard/intel/kblrvp: Revert back USB OC pin programming
With commit 2c3054c1(soc/intel/skylake: Add USB Port Over Current (OC) Pin programming) USB OC pin programming is already initiated from devicetree.cb, hence remove it from ramstage.c.
BUG=none BRANCH=none TEST=Built and booted KBLRVP from USB device
Change-Id: Icb47533aa57f208d5a52560db924169b908c7a88 Signed-off-by: Barnali Sarkar barnali.sarkar@intel.com --- src/mainboard/intel/kblrvp/ramstage.c | 11 ----------- 1 file changed, 11 deletions(-)
diff --git a/src/mainboard/intel/kblrvp/ramstage.c b/src/mainboard/intel/kblrvp/ramstage.c index d33c967..bcd72bc 100644 --- a/src/mainboard/intel/kblrvp/ramstage.c +++ b/src/mainboard/intel/kblrvp/ramstage.c @@ -21,21 +21,10 @@
void mainboard_silicon_init_params(FSP_SIL_UPD *params) { - size_t i; /* Configure pads prior to SiliconInit() in case there's any * dependencies during hardware initialization. */ gpio_configure_pads(gpio_table, ARRAY_SIZE(gpio_table)); params->CdClock = 3; - - /* Set proper OC for various USB ports*/ - u8 usb2_oc[] = {0x0, 0x2, 0x8, 0x8, 0x2, 0x8, 0x8, 0x8, 0x1, 0x8}; - u8 usb3_oc[] = {0x0, 0x8, 0x8, 0x1, 0x8, 0x8}; - - for (i = 0; i < ARRAY_SIZE(usb2_oc); i++) - params->Usb2OverCurrentPin[i] = usb2_oc[i]; - - for (i = 0; i < ARRAY_SIZE(usb3_oc); i++) - params->Usb3OverCurrentPin[i] = usb3_oc[i]; }
static void ioexpander_init(void *unused)
