Duncan Laurie (dlaurie@chromium.org) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16652
commit 97a2a1ece152b6d40a524361721405b77c37959d Author: Duncan Laurie dlaurie@chromium.org Date: Mon Sep 19 16:37:46 2016 -0700
drivers/i2c/tpm/cr50: Reduce max buffer size
Reduce the static buffer size from the generic default 1260 down to 64 to match the max FIFO size for the cr50 hardware and reduce the footprint of the driver.
BUG=chrome-os-partner:53336
Change-Id: Ia88facca607f3fd5072d0d986323fde075f15855 Signed-off-by: Duncan Laurie dlaurie@chromium.org --- src/drivers/i2c/tpm/cr50.c | 11 ++++------- 1 file changed, 4 insertions(+), 7 deletions(-)
diff --git a/src/drivers/i2c/tpm/cr50.c b/src/drivers/i2c/tpm/cr50.c index 419ac1e..1190262 100644 --- a/src/drivers/i2c/tpm/cr50.c +++ b/src/drivers/i2c/tpm/cr50.c @@ -41,19 +41,19 @@ #include <timer.h> #include "tpm.h"
-#define CR50_MAX_BURSTCOUNT 63
#define SLEEP_DURATION 60 /* in usec */ #define SLEEP_DURATION_LONG 210 /* in usec */ #define SLEEP_DURATION_SAFE 750 /* in usec */ #define SLEEP_DURATION_PROBE_MS 1000 /* in msec */
+#define CR50_MAX_BUFSIZE 63 #define CR50_DID_VID 0x00281ae0L
struct tpm_inf_dev { int bus; unsigned int addr; - uint8_t buf[TPM_BUFSIZE + sizeof(uint8_t)]; + uint8_t buf[CR50_MAX_BUFSIZE + sizeof(uint8_t)]; };
static struct tpm_inf_dev g_tpm_dev CAR_GLOBAL; @@ -115,7 +115,7 @@ static int iic_tpm_write(uint8_t addr, uint8_t *buffer, size_t len)
if (tpm_dev->addr == 0) return -1; - if (len > TPM_BUFSIZE) + if (len > CR50_MAX_BUFSIZE) return -1;
/* Prepend the 'register address' to the buffer */ @@ -226,7 +226,7 @@ static int cr50_wait_burst_status(struct tpm_chip *chip, uint8_t mask,
/* Check if mask matches and burst is valid */ if ((*status & mask) == mask && - *burst > 0 && *burst <= CR50_MAX_BURSTCOUNT) + *burst > 0 && *burst <= CR50_MAX_BUFSIZE) return 0;
udelay(SLEEP_DURATION_SAFE); @@ -310,9 +310,6 @@ static int cr50_tis_i2c_send(struct tpm_chip *chip, uint8_t *buf, size_t len) uint8_t tpm_go[4] = { TPM_STS_GO }; struct stopwatch sw;
- if (len > TPM_BUFSIZE) - return -1; - stopwatch_init_msecs_expire(&sw, 2000);
/* Wait until TPM is ready for a command */
