Attention is currently required from: Tarun Tuli, Subrata Banik.
Hello build bot (Jenkins), Tarun Tuli, Kapil Porwal, Ivy Jian,
https://review.coreboot.org/c/coreboot/+/69612
Change subject: mb/google/rex: Add `disable_gpio_export_in_crs` for rex ......................................................................
None of the touchscreens (over I2C) used in the rex program requires exporting GPIOs in the ACPI _CRS method.
This can cause i2c devices to malfunction or cause timing sequence violations if ACPI exports a PowerResource for the device that uses GPIOs that are also exported in _CRS.
BUG=none TEST=Able to build and boot Google, Rex platform.
Without this patch:
[ERROR] I2C: 00:10: Exposing GPIOs in Power Resource and _CRS
With this patch:
None
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: I578a60eff27f94d6dc94b900604bc7560337d60b --- M src/mainboard/google/rex/variants/rex0/overridetree.cb 1 file changed, 29 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/12/69612/2
