Jonathan Zhang has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/45707 )
Change subject: doc/mb/ocp: update deltalake server documentation ......................................................................
Upon completion of 2nd build/test/release cycle of Deltalake server alternative firmware engineering, update the document.
Signed-off-by: Jonathan Zhang jonzhang@fb.com Change-Id: I1806526bd477ed407bb7fd36c7fe4ce0e57b72f0 --- M Documentation/mainboard/ocp/deltalake.md 1 file changed, 13 insertions(+), 8 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/45707/1
diff --git a/Documentation/mainboard/ocp/deltalake.md b/Documentation/mainboard/ocp/deltalake.md index 0bc5735..a9d44d7 100644 --- a/Documentation/mainboard/ocp/deltalake.md +++ b/Documentation/mainboard/ocp/deltalake.md @@ -14,8 +14,9 @@ Yosemite-V3 has multiple configurations. Depending on configurations, it may host up to 4 Delta Lake servers in one sled.
-Yosemite-V3 and Delta Lake are currently in DVT phase. Facebook, Intel and partners -jointly develop FSP/coreboot/LinuxBoot stack on Delta Lake as an alternative solution. +The Yosemite-V3 program has reached DVT exit. Facebook, Intel and partners +jointly develop FSP/coreboot/LinuxBoot stack on Delta Lake as an alternative +solution. This development is moving toward EVT exit equivalent status.
## Required blobs
@@ -60,7 +61,6 @@ - Type 8 -- Port Connector Information - Type 9 -- PCI Slot Information - Type 11 -- OEM String - - Type 13 -- BIOS Language Information - Type 32 -- System Boot Information - Type 38 -- IPMI Device Information - Type 127 -- End-of-Table @@ -87,12 +87,19 @@ - Power button - localboot - netboot from IPv6 +- TPM
## Stress/performance tests passed -- OS warm reboot overnight (6 hours) +- OS warm reboot (300 cycles) +- DC reboot (300 cycles) +- AC reboot (300 cycle) - Mprime test (6 hours) +- StressAppTest (6 hours) +- Ptugen (6 hours) - MLC (Intel Memory Latency Check) - Linkpack +- Iperf(IPv6) +- FIO
## Firmware configurations [ChromeOS VPD] is used to store most of the firmware configurations. @@ -105,8 +112,6 @@ - DeltaLake specific VPDs: check mb/ocp/deltalake/vpd.h.
## Known issues -- ME based power capping. This is a bug in ME. An IPS ticket is filed - with Intel. - HECI is not set up correctly, so BMC is not able to get PCH and DIMM temperature sensor readings. An IPS ticket is filed.
@@ -116,8 +121,8 @@ - Type 17 -- Memory Device - Type 19 -- Memory Array Mapped Address - Type 41 -- Onboard Devices Extended Information -- Hardware error injection, detection, reporting -- PFR/CBnT +- Verified measurement through CBnT +- Boot guard of CBnT - RO_VPD region as well as other RO regions are not write protected.
## Technology
Hello build bot (Jenkins), Johnny Lin, Stefan Reinauer, Christian Walter, Bryant Ou, Tim Chu,
Signed-off-by: Jonathan Zhang jonzhang@fb.com Change-Id: I1806526bd477ed407bb7fd36c7fe4ce0e57b72f0 --- M Documentation/mainboard/ocp/deltalake.md 1 file changed, 16 insertions(+), 10 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/07/45707/2
Patrick Georgi has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/45707 )
Patch Set 2: Code-Review+2
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/45707 )
Signed-off-by: Jonathan Zhang jonzhang@fb.com Change-Id: I1806526bd477ed407bb7fd36c7fe4ce0e57b72f0 Reviewed-on: https://review.coreboot.org/c/coreboot/+/45707 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Patrick Georgi pgeorgi@google.com --- M Documentation/mainboard/ocp/deltalake.md 1 file changed, 16 insertions(+), 10 deletions(-)
diff --git a/Documentation/mainboard/ocp/deltalake.md b/Documentation/mainboard/ocp/deltalake.md index 0bc5735..57e727f 100644 --- a/Documentation/mainboard/ocp/deltalake.md +++ b/Documentation/mainboard/ocp/deltalake.md @@ -14,8 +14,9 @@ Yosemite-V3 has multiple configurations. Depending on configurations, it may host up to 4 Delta Lake servers in one sled.
## Required blobs
## Firmware configurations [ChromeOS VPD] is used to store most of the firmware configurations. @@ -105,10 +112,9 @@ - DeltaLake specific VPDs: check mb/ocp/deltalake/vpd.h.
## Known issues -- ME based power capping. This is a bug in ME. An IPS ticket is filed - with Intel. -- HECI is not set up correctly, so BMC is not able to get PCH and DIMM - temperature sensor readings. An IPS ticket is filed. +- spsInfoLinux64 command fail to return ME version. +- fwts test failures related to mtrr. +- kernel error message related to SleepButton ACPI event.
## Feature gaps - SMBIOS: @@ -116,8 +122,8 @@ - Type 17 -- Memory Device - Type 19 -- Memory Array Mapped Address - Type 41 -- Onboard Devices Extended Information -- Hardware error injection, detection, reporting -- PFR/CBnT +- Verified measurement through CBnT +- Boot guard of CBnT - RO_VPD region as well as other RO regions are not write protected.
## Technology
