Keith Hui has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/41561 )
Change subject: mb/asus/p2b: Enable hardware monitor access via ISA bus ......................................................................
Setup a 8-byte I/O range at 0x290-0x297 on PIIX4's generic device 9 which activates a chip select when this range is accessed.
On the P2B family this connects to the W83781D hardware monitor, allowing access to it over the ISA bus, just like vendor firmware.
TEST=lm-sensors can detect chip and get readings over ISA.
Change-Id: Iaed1df7230359e94c580c305f4769c8bb4f5fce0 Signed-off-by: Keith Hui buurin@gmail.com --- A src/mainboard/asus/p2b/mainboard.c 1 file changed, 29 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/61/41561/1
diff --git a/src/mainboard/asus/p2b/mainboard.c b/src/mainboard/asus/p2b/mainboard.c new file mode 100644 index 0000000..ffdc78a --- /dev/null +++ b/src/mainboard/asus/p2b/mainboard.c @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <device/pci_ops.h> +#include <southbridge/intel/i82371eb/i82371eb.h> + +/** + * Mainboard specific enables. + * + * @param chip_info Ignored + */ +static void mainboard_init(void *chip_info) +{ + const pci_devfn_t px43 = PCI_DEV(0, 4, 3); + u32 reg; + /* + * Setup an 8-byte generic I/O decode block at device 9. + * This will be for W83781D hardware monitor. + * Port 0x290 mask 0x007 + * + * This should enable access to W83781D over the ISA bus. + */ + reg = pci_s_read_config32(px43, 0x60); /* DEVRESB */ + reg |= (0x290 | (0xe7 << 16)); + pci_s_write_config32(px43, 0x60, reg); +} + +struct chip_operations mainboard_ops = { + .init = mainboard_init +};
Angel Pons has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41561 )
Patch Set 1: Code-Review+1
https://review.coreboot.org/c/coreboot/+/41561/1/src/mainboard/asus/p2b/main... File src/mainboard/asus/p2b/mainboard.c:
https://review.coreboot.org/c/coreboot/+/41561/1/src/mainboard/asus/p2b/main... PS1, Line 22: 0x60 Maybe #define this register?
Keith Hui has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41561 )
Patch Set 1:
Yes I should, if it's OK to expand my scope for. (I need to edit i82371eb.h for this.)
Patch Set 1:
Yes I should, if it's OK to expand my scope for. (I need to edit i82371eb.h for this. […]
You can make two commits: one that adds register definitions to i82371eb.h, and then have this change use them
Don't worry, I will make sure to review both of them 😊
Paul Menzel has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/41561 )
Patch Set 1:
(2 comments)
Very nice.
https://review.coreboot.org/c/coreboot/+/41561/1//COMMIT_MSG Commit Message:
https://review.coreboot.org/c/coreboot/+/41561/1//COMMIT_MSG@9 PS1, Line 9: Setup Set up
https://review.coreboot.org/c/coreboot/+/41561/1/src/mainboard/asus/p2b/main... PS1, Line 16: Setup The verb is spelled with a space: Set up.
Hello build bot (Jenkins), Angel Pons,
Change subject: mb/asus/p2b: Enable hardware monitor access via I/O on ISA bus ......................................................................
Set up a 8-byte I/O range at 0x290-0x297 as PIIX4's generic device 9, which activates a chip select when this range is accessed.
On the P2B family it connects to the W83781D hardware monitor, allowing access to it over the ISA bus, just like vendor firmware.
Apparently this does not work on p3b-f, but no ill effects observed either.
TEST=On p2b-ls lm-sensors can detect chip and get readings over ISA.
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/61/41561/2
Patch Set 2:
(3 comments)
Set up
Done
Done
You can make two commits: one that adds register definitions to i82371eb. […]
Done
Patch Set 2: Code-Review+1
https://review.coreboot.org/c/coreboot/+/41561/2/src/mainboard/asus/p2b/main... File src/mainboard/asus/p2b/mainboard.c:
https://review.coreboot.org/c/coreboot/+/41561/2/src/mainboard/asus/p2b/main... PS2, Line 24: 0x60 Hmmm, this one slipped through
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/61/41561/3
Patch Set 3: Code-Review+2
Done
Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/41561 )
Change-Id: Iaed1df7230359e94c580c305f4769c8bb4f5fce0 Signed-off-by: Keith Hui buurin@gmail.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/41561 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Angel Pons th3fanbus@gmail.com --- A src/mainboard/asus/p2b/mainboard.c 1 file changed, 29 insertions(+), 0 deletions(-)
diff --git a/src/mainboard/asus/p2b/mainboard.c b/src/mainboard/asus/p2b/mainboard.c new file mode 100644 index 0000000..87838b4 --- /dev/null +++ b/src/mainboard/asus/p2b/mainboard.c @@ -0,0 +1,29 @@ +/* SPDX-License-Identifier: GPL-2.0-only */ + +#include <device/pci_ops.h> +#include <southbridge/intel/i82371eb/i82371eb.h> + +/** + * Mainboard specific enables. + * + * @param chip_info Ignored + */ +static void mainboard_init(void *chip_info) +{ + const pci_devfn_t px43 = PCI_DEV(0, 4, 3); + u32 reg; + /* + * Set up an 8-byte generic I/O decode block at device 9. + * This will be for W83781D hardware monitor. + * Port 0x290 mask 0x007 + * + * This should enable access to W83781D over the ISA bus. + */ + reg = pci_s_read_config32(px43, DEVRESB); + reg |= (0x290 | (0xe7 << 16)); + pci_s_write_config32(px43, DEVRESB, reg); +} + +struct chip_operations mainboard_ops = { + .init = mainboard_init +};
