HAOUAS Elyes (ehaouas@noos.fr) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/16846
commit 068e637d7dc4cf1131539a9b705cf5f31d75e415 Author: Elyes HAOUAS ehaouas@noos.fr Date: Sat Oct 1 15:10:11 2016 +0200
mainboard/amd/torpedo: Improve code formatting
Change-Id: I18de4740e0d3512ec81e10b32d13d07a35791b57 Signed-off-by: Elyes HAOUAS ehaouas@noos.fr --- src/mainboard/amd/torpedo/BiosCallOuts.c | 264 ++++---- src/mainboard/amd/torpedo/OemCustomize.c | 196 +++--- src/mainboard/amd/torpedo/acpi_tables.c | 57 +- src/mainboard/amd/torpedo/buildOpts.c | 40 +- src/mainboard/amd/torpedo/fadt.c | 2 +- src/mainboard/amd/torpedo/gpio.c | 112 ++-- src/mainboard/amd/torpedo/gpio.h | 1074 +++++++++++++++--------------- src/mainboard/amd/torpedo/mainboard.c | 4 +- 8 files changed, 873 insertions(+), 876 deletions(-)
diff --git a/src/mainboard/amd/torpedo/BiosCallOuts.c b/src/mainboard/amd/torpedo/BiosCallOuts.c index b64cef3..0035a27 100644 --- a/src/mainboard/amd/torpedo/BiosCallOuts.c +++ b/src/mainboard/amd/torpedo/BiosCallOuts.c @@ -43,147 +43,147 @@ const int BiosCalloutsLen = ARRAY_SIZE(BiosCallouts); /* Call the host environment interface to provide a user hook opportunity. */ static AGESA_STATUS board_BeforeDramInit (UINT32 Func, UINTN Data, VOID *ConfigPtr) { - AGESA_STATUS Status; - UINTN FcnData; - MEM_DATA_STRUCT *MemData; - UINT32 AcpiMmioAddr; - UINT32 GpioMmioAddr; - UINT8 Data8; - UINT16 Data16; + AGESA_STATUS Status; + UINTN FcnData; + MEM_DATA_STRUCT *MemData; + UINT32 AcpiMmioAddr; + UINT32 GpioMmioAddr; + UINT8 Data8; + UINT16 Data16;
- FcnData = Data; - MemData = ConfigPtr; + FcnData = Data; + MemData = ConfigPtr;
- Status = AGESA_SUCCESS; - /* Get SB MMIO Base (AcpiMmioAddr) */ - WriteIo8 (0xCD6, 0x27); - Data8 = ReadIo8(0xCD7); - Data16 = Data8 << 8; - WriteIo8 (0xCD6, 0x26); - Data8 = ReadIo8(0xCD7); - Data16 |= Data8; - AcpiMmioAddr = (UINT32)Data16 << 16; - GpioMmioAddr = AcpiMmioAddr + GPIO_BASE; + Status = AGESA_SUCCESS; + /* Get SB MMIO Base (AcpiMmioAddr) */ + WriteIo8 (0xCD6, 0x27); + Data8 = ReadIo8(0xCD7); + Data16 = Data8 << 8; + WriteIo8 (0xCD6, 0x26); + Data8 = ReadIo8(0xCD7); + Data16 |= Data8; + AcpiMmioAddr = (UINT32)Data16 << 16; + GpioMmioAddr = AcpiMmioAddr + GPIO_BASE;
- switch(MemData->ParameterListPtr->DDR3Voltage){ - case VOLT1_35: - Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG178); - Data8 &= ~(UINT8)BIT6; - Write64Mem8(GpioMmioAddr+SB_GPIO_REG178, Data8); - Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG179); - Data8 |= (UINT8)BIT6; - Write64Mem8(GpioMmioAddr+SB_GPIO_REG179, Data8); - break; - case VOLT1_25: - Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG178); - Data8 &= ~(UINT8)BIT6; - Write64Mem8(GpioMmioAddr+SB_GPIO_REG178, Data8); - Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG179); - Data8 &= ~(UINT8)BIT6; - Write64Mem8(GpioMmioAddr+SB_GPIO_REG179, Data8); - break; - case VOLT1_5: - default: - Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG178); - Data8 |= (UINT8)BIT6; - Write64Mem8(GpioMmioAddr+SB_GPIO_REG178, Data8); - } - return Status; + switch(MemData->ParameterListPtr->DDR3Voltage){ + case VOLT1_35: + Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG178); + Data8 &= ~(UINT8)BIT6; + Write64Mem8(GpioMmioAddr+SB_GPIO_REG178, Data8); + Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG179); + Data8 |= (UINT8)BIT6; + Write64Mem8(GpioMmioAddr+SB_GPIO_REG179, Data8); + break; + case VOLT1_25: + Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG178); + Data8 &= ~(UINT8)BIT6; + Write64Mem8(GpioMmioAddr+SB_GPIO_REG178, Data8); + Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG179); + Data8 &= ~(UINT8)BIT6; + Write64Mem8(GpioMmioAddr+SB_GPIO_REG179, Data8); + break; + case VOLT1_5: + default: + Data8 = Read64Mem8 (GpioMmioAddr+SB_GPIO_REG178); + Data8 |= (UINT8)BIT6; + Write64Mem8(GpioMmioAddr+SB_GPIO_REG178, Data8); + } + return Status; }
/* PCIE slot reset control */ static AGESA_STATUS board_GnbPcieSlotReset (UINT32 Func, UINTN Data, VOID *ConfigPtr) { - AGESA_STATUS Status; - UINTN FcnData; - PCIe_SLOT_RESET_INFO *ResetInfo; + AGESA_STATUS Status; + UINTN FcnData; + PCIe_SLOT_RESET_INFO *ResetInfo;
- UINT32 GpioMmioAddr; - UINT32 AcpiMmioAddr; - UINT8 Data8; - UINT16 Data16; + UINT32 GpioMmioAddr; + UINT32 AcpiMmioAddr; + UINT8 Data8; + UINT16 Data16;
- FcnData = Data; - ResetInfo = ConfigPtr; - // Get SB MMIO Base (AcpiMmioAddr) - WriteIo8(0xCD6, 0x27); - Data8 = ReadIo8(0xCD7); - Data16 = Data8 << 8; - WriteIo8(0xCD6, 0x26); - Data8 = ReadIo8(0xCD7); - Data16 |= Data8; - AcpiMmioAddr = (UINT32)Data16 << 16; - Status = AGESA_UNSUPPORTED; - GpioMmioAddr = AcpiMmioAddr + GPIO_BASE; + FcnData = Data; + ResetInfo = ConfigPtr; + // Get SB MMIO Base (AcpiMmioAddr) + WriteIo8(0xCD6, 0x27); + Data8 = ReadIo8(0xCD7); + Data16 = Data8 << 8; + WriteIo8(0xCD6, 0x26); + Data8 = ReadIo8(0xCD7); + Data16 |= Data8; + AcpiMmioAddr = (UINT32)Data16 << 16; + Status = AGESA_UNSUPPORTED; + GpioMmioAddr = AcpiMmioAddr + GPIO_BASE;
- if (ResetInfo->ResetControl == DeassertSlotReset) { - if (ResetInfo->ResetId & (BIT2+BIT3)) { //de-assert - // [GPIO] GPIO45: PE_GPIO1 MXM_POWER_ENABLE, SET HIGH - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG45); - if (Data8 & BIT7) { - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG28); - while (!(Data8 & BIT7)) { - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG28); - } - // GPIO44: PE_GPIO0 MXM Reset - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG44); - Data8 |= BIT6 ; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG44, Data8); - Status = AGESA_SUCCESS; - } - } else { - Status = AGESA_UNSUPPORTED; - } - // Travis - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG24); - Data8 |= BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG24, Data8); - //DE-Assert ALL PCIE RESET - // APU GPP0 (Dev 4) - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG25); - Data8 |= BIT6 ; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG25, Data8); - // APU GPP1 (Dev 5) - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG01); - Data8 |= BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG01, Data8); - // APU GPP2 (Dev 6) - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG00); - Data8 |= BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG00, Data8); - // APU GPP3 (Dev 7) - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG27); - Data8 |= BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG27, Data8); - } else { - if (ResetInfo->ResetId & (BIT2+BIT3)) { //Pcie Slot Reset is supported - // GPIO44: PE_GPIO0 MXM Reset - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG44); - Data8 &= ~(UINT8)BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG44, Data8); - Status = AGESA_SUCCESS; - } - // Travis - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG24); - Data8 &= ~(UINT8)BIT6 ; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG24, Data8); - //Assert ALL PCIE RESET - // APU GPP0 (Dev 4) - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG25); - Data8 &= ~(UINT8)BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG25, Data8); - // APU GPP1 (Dev 5) - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG01); - Data8 &= ~(UINT8)BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG01, Data8); - // APU GPP2 (Dev 6) - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG00); - Data8 &= ~(UINT8)BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG00, Data8); - // APU GPP3 (Dev 7) - Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG27); - Data8 &= ~(UINT8)BIT6; - Write64Mem8 (GpioMmioAddr+SB_GPIO_REG27, Data8); - } - return Status; + if (ResetInfo->ResetControl == DeassertSlotReset) { + if (ResetInfo->ResetId & (BIT2+BIT3)) { //de-assert + // [GPIO] GPIO45: PE_GPIO1 MXM_POWER_ENABLE, SET HIGH + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG45); + if (Data8 & BIT7) { + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG28); + while (!(Data8 & BIT7)) { + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG28); + } + // GPIO44: PE_GPIO0 MXM Reset + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG44); + Data8 |= BIT6 ; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG44, Data8); + Status = AGESA_SUCCESS; + } + } else { + Status = AGESA_UNSUPPORTED; + } + // Travis + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG24); + Data8 |= BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG24, Data8); + //DE-Assert ALL PCIE RESET + // APU GPP0 (Dev 4) + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG25); + Data8 |= BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG25, Data8); + // APU GPP1 (Dev 5) + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG01); + Data8 |= BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG01, Data8); + // APU GPP2 (Dev 6) + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG00); + Data8 |= BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG00, Data8); + // APU GPP3 (Dev 7) + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG27); + Data8 |= BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG27, Data8); + } else { + if (ResetInfo->ResetId & (BIT2+BIT3)) { //Pcie Slot Reset is supported + // GPIO44: PE_GPIO0 MXM Reset + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG44); + Data8 &= ~(UINT8)BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG44, Data8); + Status = AGESA_SUCCESS; + } + // Travis + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG24); + Data8 &= ~(UINT8)BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG24, Data8); + //Assert ALL PCIE RESET + // APU GPP0 (Dev 4) + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG25); + Data8 &= ~(UINT8)BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG25, Data8); + // APU GPP1 (Dev 5) + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG01); + Data8 &= ~(UINT8)BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG01, Data8); + // APU GPP2 (Dev 6) + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG00); + Data8 &= ~(UINT8)BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG00, Data8); + // APU GPP3 (Dev 7) + Data8 = Read64Mem8(GpioMmioAddr+SB_GPIO_REG27); + Data8 &= ~(UINT8)BIT6; + Write64Mem8 (GpioMmioAddr+SB_GPIO_REG27, Data8); + } + return Status; } diff --git a/src/mainboard/amd/torpedo/OemCustomize.c b/src/mainboard/amd/torpedo/OemCustomize.c index 2293039..3c20047 100644 --- a/src/mainboard/amd/torpedo/OemCustomize.c +++ b/src/mainboard/amd/torpedo/OemCustomize.c @@ -23,70 +23,70 @@ #define FILECODE PROC_GNB_PCIE_FAMILY_0X12_F12PCIECOMPLEXCONFIG_FILECODE
static const PCIe_PORT_DESCRIPTOR PortList [] = { - // Initialize Port descriptor (PCIe port, Lanes 8:15, PCI Device Number 2, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 8, 15), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 2, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, BIT2) - }, - // Initialize Port descriptor (PCIe port, Lanes 16:19, PCI Device Number 3, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 16, 19), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 3, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, BIT3) - }, - // Initialize Port descriptor (PCIe port, Lanes 4, PCI Device Number 4, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 4, 4), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 4, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) - }, - // Initialize Port descriptor (PCIe port, Lanes 5, PCI Device Number 5, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 5, 5), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 5, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) - }, - // Initialize Port descriptor (PCIe port, Lanes 6, PCI Device Number 6, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 6, 6), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 6, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) - }, - // Initialize Port descriptor (PCIe port, Lanes 7, PCI Device Number 7, ...) - { - DESCRIPTOR_TERMINATE_LIST, - PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 7, 7), - PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 7, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) - } - // Initialize Port descriptor (PCIe port, Lanes 8, PCI Device Number 8, ...) -// { -// DESCRIPTOR_TERMINATE_LIST, -// PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 8, 8), -// PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 8, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) -// } + // Initialize Port descriptor (PCIe port, Lanes 8:15, PCI Device Number 2, ...) + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 8, 15), + PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 2, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, BIT2) + }, + // Initialize Port descriptor (PCIe port, Lanes 16:19, PCI Device Number 3, ...) + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 16, 19), + PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 3, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, BIT3) + }, + // Initialize Port descriptor (PCIe port, Lanes 4, PCI Device Number 4, ...) + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 4, 4), + PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 4, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) + }, + // Initialize Port descriptor (PCIe port, Lanes 5, PCI Device Number 5, ...) + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 5, 5), + PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 5, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) + }, + // Initialize Port descriptor (PCIe port, Lanes 6, PCI Device Number 6, ...) + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 6, 6), + PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 6, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) + }, + // Initialize Port descriptor (PCIe port, Lanes 7, PCI Device Number 7, ...) + { + DESCRIPTOR_TERMINATE_LIST, + PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 7, 7), + PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 7, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) + } + // Initialize Port descriptor (PCIe port, Lanes 8, PCI Device Number 8, ...) +// { +// DESCRIPTOR_TERMINATE_LIST, +// PCIE_ENGINE_DATA_INITIALIZER (PciePortEngine, 8, 8), +// PCIE_PORT_DATA_INITIALIZER (PortEnabled, ChannelTypeExt6db, 8, HotplugDisabled, PcieGenMaxSupported, PcieGenMaxSupported, AspmDisabled, 0) +// } };
static const PCIe_DDI_DESCRIPTOR DdiList [] = { - // Initialize Ddi descriptor (DDI interface Lanes 24:27, DdA, ...) - { - 0, - PCIE_ENGINE_DATA_INITIALIZER (PcieDdiEngine, 24, 27), - PCIE_DDI_DATA_INITIALIZER (ConnectorTypeNutmegDpToVga, Aux2, Hdp2) - }, - // Initialize Ddi descriptor (DDI interface Lanes 28:31, DdB, ...) - { - DESCRIPTOR_TERMINATE_LIST, - PCIE_ENGINE_DATA_INITIALIZER (PcieDdiEngine, 28, 31), - PCIE_DDI_DATA_INITIALIZER (ConnectorTypeEDP, Aux1, Hdp1) - } + // Initialize Ddi descriptor (DDI interface Lanes 24:27, DdA, ...) + { + 0, + PCIE_ENGINE_DATA_INITIALIZER (PcieDdiEngine, 24, 27), + PCIE_DDI_DATA_INITIALIZER (ConnectorTypeNutmegDpToVga, Aux2, Hdp2) + }, + // Initialize Ddi descriptor (DDI interface Lanes 28:31, DdB, ...) + { + DESCRIPTOR_TERMINATE_LIST, + PCIE_ENGINE_DATA_INITIALIZER (PcieDdiEngine, 28, 31), + PCIE_DDI_DATA_INITIALIZER (ConnectorTypeEDP, Aux1, Hdp1) + } };
static const PCIe_COMPLEX_DESCRIPTOR Llano = { - DESCRIPTOR_TERMINATE_LIST, - 0, - &PortList[0], - &DdiList[0] + DESCRIPTOR_TERMINATE_LIST, + 0, + &PortList[0], + &DdiList[0] };
/*---------------------------------------------------------------------------------------*/ @@ -107,58 +107,58 @@ static const PCIe_COMPLEX_DESCRIPTOR Llano = {
static AGESA_STATUS OemInitEarly(AMD_EARLY_PARAMS * InitEarly) { - AGESA_STATUS Status; - VOID *LlanoPcieComplexListPtr; - VOID *LlanoPciePortPtr; - VOID *LlanoPcieDdiPtr; + AGESA_STATUS Status; + VOID *LlanoPcieComplexListPtr; + VOID *LlanoPciePortPtr; + VOID *LlanoPcieDdiPtr;
- ALLOCATE_HEAP_PARAMS AllocHeapParams; + ALLOCATE_HEAP_PARAMS AllocHeapParams;
- // GNB PCIe topology Porting + // GNB PCIe topology Porting
- // - // Allocate buffer for PCIe_COMPLEX_DESCRIPTOR , PCIe_PORT_DESCRIPTOR and PCIe_DDI_DESCRIPTOR - // - AllocHeapParams.RequestedBufferSize = sizeof(Llano) + sizeof(PortList) + sizeof(DdiList); + // + // Allocate buffer for PCIe_COMPLEX_DESCRIPTOR , PCIe_PORT_DESCRIPTOR and PCIe_DDI_DESCRIPTOR + // + AllocHeapParams.RequestedBufferSize = sizeof(Llano) + sizeof(PortList) + sizeof(DdiList);
- AllocHeapParams.BufferHandle = AMD_MEM_MISC_HANDLES_START; - AllocHeapParams.Persist = HEAP_LOCAL_CACHE; - Status = HeapAllocateBuffer (&AllocHeapParams, &InitEarly->StdHeader); + AllocHeapParams.BufferHandle = AMD_MEM_MISC_HANDLES_START; + AllocHeapParams.Persist = HEAP_LOCAL_CACHE; + Status = HeapAllocateBuffer (&AllocHeapParams, &InitEarly->StdHeader); ASSERT(Status == AGESA_SUCCESS);
- LlanoPcieComplexListPtr = (PCIe_COMPLEX_DESCRIPTOR *) AllocHeapParams.BufferPtr; + LlanoPcieComplexListPtr = (PCIe_COMPLEX_DESCRIPTOR *) AllocHeapParams.BufferPtr;
- AllocHeapParams.BufferPtr += sizeof(Llano); - LlanoPciePortPtr = (PCIe_PORT_DESCRIPTOR *)AllocHeapParams.BufferPtr; + AllocHeapParams.BufferPtr += sizeof(Llano); + LlanoPciePortPtr = (PCIe_PORT_DESCRIPTOR *)AllocHeapParams.BufferPtr;
- AllocHeapParams.BufferPtr += sizeof(PortList); - LlanoPcieDdiPtr = (PCIe_DDI_DESCRIPTOR *) AllocHeapParams.BufferPtr; + AllocHeapParams.BufferPtr += sizeof(PortList); + LlanoPcieDdiPtr = (PCIe_DDI_DESCRIPTOR *) AllocHeapParams.BufferPtr;
- LibAmdMemFill (LlanoPcieComplexListPtr, - 0, - sizeof(Llano), - &InitEarly->StdHeader); + LibAmdMemFill (LlanoPcieComplexListPtr, + 0, + sizeof(Llano), + &InitEarly->StdHeader);
- LibAmdMemFill (LlanoPciePortPtr, - 0, - sizeof(PortList), - &InitEarly->StdHeader); + LibAmdMemFill (LlanoPciePortPtr, + 0, + sizeof(PortList), + &InitEarly->StdHeader);
- LibAmdMemFill (LlanoPcieDdiPtr, - 0, - sizeof(DdiList), - &InitEarly->StdHeader); + LibAmdMemFill (LlanoPcieDdiPtr, + 0, + sizeof(DdiList), + &InitEarly->StdHeader);
- LibAmdMemCopy (LlanoPcieComplexListPtr, &Llano, sizeof(Llano), &InitEarly->StdHeader); - LibAmdMemCopy (LlanoPciePortPtr, &PortList[0], sizeof(PortList), &InitEarly->StdHeader); - LibAmdMemCopy (LlanoPcieDdiPtr, &DdiList[0], sizeof(DdiList), &InitEarly->StdHeader); + LibAmdMemCopy (LlanoPcieComplexListPtr, &Llano, sizeof(Llano), &InitEarly->StdHeader); + LibAmdMemCopy (LlanoPciePortPtr, &PortList[0], sizeof(PortList), &InitEarly->StdHeader); + LibAmdMemCopy (LlanoPcieDdiPtr, &DdiList[0], sizeof(DdiList), &InitEarly->StdHeader);
- ((PCIe_COMPLEX_DESCRIPTOR*)LlanoPcieComplexListPtr)->PciePortList = (PCIe_PORT_DESCRIPTOR*)LlanoPciePortPtr; - ((PCIe_COMPLEX_DESCRIPTOR*)LlanoPcieComplexListPtr)->DdiLinkList = (PCIe_DDI_DESCRIPTOR*)LlanoPcieDdiPtr; + ((PCIe_COMPLEX_DESCRIPTOR*)LlanoPcieComplexListPtr)->PciePortList = (PCIe_PORT_DESCRIPTOR*)LlanoPciePortPtr; + ((PCIe_COMPLEX_DESCRIPTOR*)LlanoPcieComplexListPtr)->DdiLinkList = (PCIe_DDI_DESCRIPTOR*)LlanoPcieDdiPtr;
- InitEarly->GnbConfig.PcieComplexList = LlanoPcieComplexListPtr; - InitEarly->GnbConfig.PsppPolicy = 0; + InitEarly->GnbConfig.PcieComplexList = LlanoPcieComplexListPtr; + InitEarly->GnbConfig.PsppPolicy = 0; return AGESA_SUCCESS; }
@@ -174,9 +174,9 @@ static AGESA_STATUS OemInitEarly(AMD_EARLY_PARAMS * InitEarly) * use its default conservative settings. */ CONST PSO_ENTRY ROMDATA DefaultPlatformMemoryConfiguration[] = { - NUMBER_OF_DIMMS_SUPPORTED (ANY_SOCKET, ANY_CHANNEL, 1), - NUMBER_OF_CHANNELS_SUPPORTED (ANY_SOCKET, 2), - PSO_END + NUMBER_OF_DIMMS_SUPPORTED (ANY_SOCKET, ANY_CHANNEL, 1), + NUMBER_OF_CHANNELS_SUPPORTED (ANY_SOCKET, 2), + PSO_END };
const struct OEM_HOOK OemCustomize = { diff --git a/src/mainboard/amd/torpedo/acpi_tables.c b/src/mainboard/amd/torpedo/acpi_tables.c index f014357..fef9156 100644 --- a/src/mainboard/amd/torpedo/acpi_tables.c +++ b/src/mainboard/amd/torpedo/acpi_tables.c @@ -29,33 +29,32 @@ extern u32 apicid_sb900;
unsigned long acpi_fill_madt(unsigned long current) { - - /* create all subtables for processors */ - current += acpi_create_madt_lapic((acpi_madt_lapic_t *)current, 0, 0); - current += acpi_create_madt_lapic((acpi_madt_lapic_t *)current, 1, 1); - current += acpi_create_madt_lapic((acpi_madt_lapic_t *)current, 2, 2); - current += acpi_create_madt_lapic((acpi_madt_lapic_t *)current, 3, 3); - - /* Write SB900 IOAPIC, only one */ - current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, apicid_sb900, - IO_APIC_ADDR, 0); - - current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) - current, 0, 0, 2, 0); - current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) - current, 0, 9, 9, 0xF); - - /* 0: mean bus 0--->ISA */ - /* 0: PIC 0 */ - /* 2: APIC 2 */ - /* 5 mean: 0101 --> Edge-triggered, Active high */ - - /* create all subtables for processors */ - current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 0, 5, 1); - current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 1, 5, 1); - current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 2, 5, 1); - current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 3, 5, 1); - /* 1: LINT1 connect to NMI */ - - return current; + /* create all subtables for processors */ + current += acpi_create_madt_lapic((acpi_madt_lapic_t *)current, 0, 0); + current += acpi_create_madt_lapic((acpi_madt_lapic_t *)current, 1, 1); + current += acpi_create_madt_lapic((acpi_madt_lapic_t *)current, 2, 2); + current += acpi_create_madt_lapic((acpi_madt_lapic_t *)current, 3, 3); + + /* Write SB900 IOAPIC, only one */ + current += acpi_create_madt_ioapic((acpi_madt_ioapic_t *) current, apicid_sb900, + IO_APIC_ADDR, 0); + + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 0, 2, 0); + current += acpi_create_madt_irqoverride((acpi_madt_irqoverride_t *) + current, 0, 9, 9, 0xF); + + /* 0: mean bus 0--->ISA */ + /* 0: PIC 0 */ + /* 2: APIC 2 */ + /* 5 mean: 0101 --> Edge-triggered, Active high */ + + /* create all subtables for processors */ + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 0, 5, 1); + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 1, 5, 1); + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 2, 5, 1); + current += acpi_create_madt_lapic_nmi((acpi_madt_lapic_nmi_t *)current, 3, 5, 1); + /* 1: LINT1 connect to NMI */ + + return current; } diff --git a/src/mainboard/amd/torpedo/buildOpts.c b/src/mainboard/amd/torpedo/buildOpts.c index d81748a..656102d 100644 --- a/src/mainboard/amd/torpedo/buildOpts.c +++ b/src/mainboard/amd/torpedo/buildOpts.c @@ -96,17 +96,19 @@ * version string as appropriate for the release. The trunk copy of this file * should also be updated/incremented for the next expected version, + trailing 'X' ****************************************************************************/ - // This is the delivery package title, "LlanoPI " - // This string MUST be exactly 8 characters long + // This is the delivery package title, "LlanoPI " + // This string MUST be exactly 8 characters long #define AGESA_PACKAGE_STRING {'L', 'l', 'a', 'n', 'o', 'P', 'I', ' '}
- // This is the release version number of the AGESA component - // This string MUST be exactly 12 characters long + // This is the release version number of the AGESA component + // This string MUST be exactly 12 characters long #define AGESA_VERSION_STRING {'V', '1', '.', '1', '.', '0', '.', '0', ' ', ' ', ' ', ' '}
-// The following definitions specify the default values for various parameters in which there are -// no clearly defined defaults to be used in the common file. The values below are based on product -// and BKDG content, please consult the AGESA Memory team for consultation. +/* The following definitions specify the default values for various parameters + * in which there are no clearly defined defaults to be used in the common file. + * The values below are based on product and BKDG content, please consult the + * AGESA Memory team for consultation. + */ #define DFLT_SCRUB_DRAM_RATE (0) #define DFLT_SCRUB_L2_RATE (0) #define DFLT_SCRUB_L3_RATE (0) @@ -185,18 +187,18 @@ */ CONST AP_MTRR_SETTINGS ROMDATA LlanoApMtrrSettingsList[] = { - { AMD_AP_MTRR_FIX64k_00000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX16k_80000, 0x1E1E1E1E1E1E1E1Eull }, - { AMD_AP_MTRR_FIX16k_A0000, 0x0000000000000000ull }, - { AMD_AP_MTRR_FIX4k_C0000, 0x0000000000000000ull }, - { AMD_AP_MTRR_FIX4k_C8000, 0x0000000000000000ull }, - { AMD_AP_MTRR_FIX4k_D0000, 0x0000000000000000ull }, - { AMD_AP_MTRR_FIX4k_D8000, 0x0000000000000000ull }, - { AMD_AP_MTRR_FIX4k_E0000, 0x1818181818181818ull }, - { AMD_AP_MTRR_FIX4k_E8000, 0x1818181818181818ull }, - { AMD_AP_MTRR_FIX4k_F0000, 0x1818181818181818ull }, - { AMD_AP_MTRR_FIX4k_F8000, 0x1818181818181818ull }, - { CPU_LIST_TERMINAL } + { AMD_AP_MTRR_FIX64k_00000, 0x1E1E1E1E1E1E1E1Eull }, + { AMD_AP_MTRR_FIX16k_80000, 0x1E1E1E1E1E1E1E1Eull }, + { AMD_AP_MTRR_FIX16k_A0000, 0x0000000000000000ull }, + { AMD_AP_MTRR_FIX4k_C0000, 0x0000000000000000ull }, + { AMD_AP_MTRR_FIX4k_C8000, 0x0000000000000000ull }, + { AMD_AP_MTRR_FIX4k_D0000, 0x0000000000000000ull }, + { AMD_AP_MTRR_FIX4k_D8000, 0x0000000000000000ull }, + { AMD_AP_MTRR_FIX4k_E0000, 0x1818181818181818ull }, + { AMD_AP_MTRR_FIX4k_E8000, 0x1818181818181818ull }, + { AMD_AP_MTRR_FIX4k_F0000, 0x1818181818181818ull }, + { AMD_AP_MTRR_FIX4k_F8000, 0x1818181818181818ull }, + { CPU_LIST_TERMINAL } };
#define BLDCFG_AP_MTRR_SETTINGS_LIST &LlanoApMtrrSettingsList diff --git a/src/mainboard/amd/torpedo/fadt.c b/src/mainboard/amd/torpedo/fadt.c index b20cfc8..56a90a6 100644 --- a/src/mainboard/amd/torpedo/fadt.c +++ b/src/mainboard/amd/torpedo/fadt.c @@ -52,7 +52,7 @@ void acpi_create_fadt(acpi_fadt_t * fadt, acpi_facs_t * facs, void *dsdt) header->length = 244; header->revision = 1; memcpy(header->oem_id, OEM_ID, 6); - memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); + memcpy(header->oem_table_id, ACPI_TABLE_CREATOR, 8); memcpy(header->asl_compiler_id, ASLC, 4); header->asl_compiler_revision = 0;
diff --git a/src/mainboard/amd/torpedo/gpio.c b/src/mainboard/amd/torpedo/gpio.c index ac98557..03ab409 100644 --- a/src/mainboard/amd/torpedo/gpio.c +++ b/src/mainboard/amd/torpedo/gpio.c @@ -40,25 +40,21 @@ #define SB_GPIO_REG27 27 #endif
-void -gpioEarlyInit( - void - ) -{ - u8 Flags; - u8 Data8 = 0; - u8 StripInfo = 0; - u8 BoardType = 1; - u8 RegIndex8 = 0; - u8 boardRevC = 0x2; - u16 Data16 = 0; - u32 Index = 0; - u32 AcpiMmioAddr = 0; - u32 GpioMmioAddr = 0; - u32 IoMuxMmioAddr = 0; - u32 MiscMmioAddr = 0; - u32 SmiMmioAddr = 0; - u32 andMask32 = 0; +void gpioEarlyInit(void) { + u8 Flags; + u8 Data8 = 0; + u8 StripInfo = 0; + u8 BoardType = 1; + u8 RegIndex8 = 0; + u8 boardRevC = 0x2; + u16 Data16 = 0; + u32 Index = 0; + u32 AcpiMmioAddr = 0; + u32 GpioMmioAddr = 0; + u32 IoMuxMmioAddr = 0; + u32 MiscMmioAddr = 0; + u32 SmiMmioAddr = 0; + u32 andMask32 = 0;
// Enable HUDSON MMIO Base (AcpiMmioAddr) ReadPMIO (SB_PMIOA_REG24, AccWidthUint8, &Data8); @@ -92,9 +88,9 @@ gpioEarlyInit( Mmio8_And_Or (IoMuxMmioAddr, Index, 0x00, (gpio_table[Index].select & ~NonGpio)); } // Configure GPIO - if(!((gpio_table[Index].NonGpioGevent & NonGpio))) { - Mmio8_And_Or (GpioMmioAddr, Index, 0xDF, gpio_table[Index].type); - Mmio8_And_Or (GpioMmioAddr, Index, 0xA3, gpio_table[Index].value); + if(!((gpio_table[Index].NonGpioGevent & NonGpio))) { + Mmio8_And_Or (GpioMmioAddr, Index, 0xDF, gpio_table[Index].type); + Mmio8_And_Or (GpioMmioAddr, Index, 0xA3, gpio_table[Index].value); } if (Index == GPIO_65) { if ( BoardType == 0 ) { @@ -109,32 +105,32 @@ gpioEarlyInit( andMask32 = ~(1 << (Index - GEVENT_00));
//EventEnable: 0-Disable, 1-Enable - Mmio32_And_Or (SmiMmioAddr, SMIREG_EVENT_ENABLE, andMask32, (gevent_table[Index - GEVENT_00].EventEnable << (Index - GEVENT_00))); + Mmio32_And_Or(SmiMmioAddr, SMIREG_EVENT_ENABLE, andMask32, (gevent_table[Index - GEVENT_00].EventEnable << (Index - GEVENT_00)));
//SciTrig: 0-Falling Edge, 1-Rising Edge - Mmio32_And_Or (SmiMmioAddr, SMIREG_SCITRIG, andMask32, (gevent_table[Index - GEVENT_00].SciTrig << (Index - GEVENT_00))); + Mmio32_And_Or(SmiMmioAddr, SMIREG_SCITRIG, andMask32, (gevent_table[Index - GEVENT_00].SciTrig << (Index - GEVENT_00)));
//SciLevl: 0-Edge trigger, 1-Level Trigger - Mmio32_And_Or (SmiMmioAddr, SMIREG_SCILEVEL, andMask32, (gevent_table[Index - GEVENT_00].SciLevl << (Index - GEVENT_00))); + Mmio32_And_Or(SmiMmioAddr, SMIREG_SCILEVEL, andMask32, (gevent_table[Index - GEVENT_00].SciLevl << (Index - GEVENT_00)));
//SmiSciEn: 0-Not send SMI, 1-Send SMI - Mmio32_And_Or (SmiMmioAddr, SMIREG_SMISCIEN, andMask32, (gevent_table[Index - GEVENT_00].SmiSciEn << (Index - GEVENT_00))); + Mmio32_And_Or(SmiMmioAddr, SMIREG_SMISCIEN, andMask32, (gevent_table[Index - GEVENT_00].SmiSciEn << (Index - GEVENT_00)));
//SciS0En: 0-Disable, 1-Enable - Mmio32_And_Or (SmiMmioAddr, SMIREG_SCIS0EN, andMask32, (gevent_table[Index - GEVENT_00].SciS0En << (Index - GEVENT_00))); + Mmio32_And_Or(SmiMmioAddr, SMIREG_SCIS0EN, andMask32, (gevent_table[Index - GEVENT_00].SciS0En << (Index - GEVENT_00)));
//SciMap: 00000b ~ 11111b - RegIndex8=(u8)((Index - GEVENT_00) >> 2); - Data8=(u8)(((Index - GEVENT_00) & 0x3) * 8); - Mmio32_And_Or (SmiMmioAddr, SMIREG_SCIMAP0+RegIndex8, ~(GEVENT_SCIMASK << Data8), (gevent_table[Index - GEVENT_00].SciMap << Data8)); + RegIndex8 = (u8)((Index - GEVENT_00) >> 2); + Data8 = (u8)(((Index - GEVENT_00) & 0x3) * 8); + Mmio32_And_Or(SmiMmioAddr, SMIREG_SCIMAP0+RegIndex8, ~(GEVENT_SCIMASK << Data8), (gevent_table[Index - GEVENT_00].SciMap << Data8));
//SmiTrig: 0-Active Low, 1-Active High - Mmio32_And_Or (SmiMmioAddr, SMIREG_SMITRIG, ~(gevent_table[Index - GEVENT_00].SmiTrig << (Index - GEVENT_00)), (gevent_table[Index - GEVENT_00].SmiTrig << (Index - GEVENT_00))); + Mmio32_And_Or(SmiMmioAddr, SMIREG_SMITRIG, ~(gevent_table[Index - GEVENT_00].SmiTrig << (Index - GEVENT_00)), (gevent_table[Index - GEVENT_00].SmiTrig << (Index - GEVENT_00)));
//SmiControl: 0-Disable, 1-SMI, 2-NMI, 3-IRQ13 - RegIndex8=(u8)((Index - GEVENT_00) >> 4); - Data8=(u8)(((Index - GEVENT_00) & 0xF) * 2); - Mmio32_And_Or (SmiMmioAddr, SMIREG_SMICONTROL0+RegIndex8, ~(SMICONTROL_MASK << Data8), (gevent_table[Index - GEVENT_00].SmiControl << Data8)); + RegIndex8 = (u8)((Index - GEVENT_00) >> 4); + Data8 = (u8)(((Index - GEVENT_00) & 0xF) * 2); + Mmio32_And_Or(SmiMmioAddr, SMIREG_SMICONTROL0+RegIndex8, ~(SMICONTROL_MASK << Data8), (gevent_table[Index - GEVENT_00].SmiControl << Data8)); } }
@@ -205,7 +201,7 @@ gpioEarlyInit( Flags = 1; } } - if ( Flags ) + if (Flags) { // [GPIO] GPIO44: PE_GPIO0 MXM Reset set to 0 for reset, ENH164467 RWMEM (GpioMmioAddr + SB_GPIO_REG44, AccWidthUint8, 0xBF, 0); @@ -228,7 +224,7 @@ gpioEarlyInit( ReadMEM (GpioMmioAddr + SB_GPIO_REG28, AccWidthUint8, &Data8); } // [GPIO] GPIO44: PE_GPIO0 MXM Reset set to 1 for reset - // RWMEM (GpioMmioAddr + SB_GPIO_REG44, AccWidthUint8, 0xBF, BIT6); + //RWMEM (GpioMmioAddr + SB_GPIO_REG44, AccWidthUint8, 0xBF, BIT6); } else { @@ -394,11 +390,11 @@ gpioEarlyInit( // if ((Amd_SystemConfiguration.XhciSwitch == 1) || (SystemConfiguration.amdExternalUSBController == 1)) { // disable Onboard NEC USB3.0 controller if (!CONFIG_ONBOARD_USB30) { - RWMEM (GpioMmioAddr + SB_GPIO_REG200, AccWidthUint8, 0xBF, 0); - RWMEM (GpioMmioAddr + SB_GPIO_REG26, AccWidthUint8, 0xBF, 0); - RWMEM (GpioMmioAddr + SB_GPIO_REG46, AccWidthUint8, 0xFF, BIT3); // PULL_UP DISABLE - RWMEM (MiscMmioAddr + SB_MISC_REG00+3, AccWidthUint8, 0x0F, 0); // DISABLE GPP_CLK7 - RWMEM (GpioMmioAddr + SB_GPIO_REG172, AccWidthUint8, 0xBF, 0); // FCH_USB3.0PORT_EN# 0:ENABLE; 1:DISABLE + RWMEM (GpioMmioAddr + SB_GPIO_REG200, AccWidthUint8, 0xBF, 0); + RWMEM (GpioMmioAddr + SB_GPIO_REG26, AccWidthUint8, 0xBF, 0); + RWMEM (GpioMmioAddr + SB_GPIO_REG46, AccWidthUint8, 0xFF, BIT3); // PULL_UP DISABLE + RWMEM (MiscMmioAddr + SB_MISC_REG00+3, AccWidthUint8, 0x0F, 0); // DISABLE GPP_CLK7 + RWMEM (GpioMmioAddr + SB_GPIO_REG172, AccWidthUint8, 0xBF, 0); // FCH_USB3.0PORT_EN# 0:ENABLE; 1:DISABLE } // }
@@ -407,41 +403,41 @@ gpioEarlyInit( // amdBlueTooth: CMOS, 0 - AUTO, 1 - DISABLE // GPIO07: BT_ON, 0 - OFF, 1 - ON // -if (!CONFIG_ONBOARD_BLUETOOTH) { -//- if (SystemConfiguration.amdBlueTooth == 1) { + if (!CONFIG_ONBOARD_BLUETOOTH) { + //- if (SystemConfiguration.amdBlueTooth == 1) { RWMEM (GpioMmioAddr + SB_GPIO_REG07, AccWidthUint8, 0xBF, 0); -//- } -} + //- } + }
// // WebCam control: // amdWebCam: CMOS, 0 - AUTO, 1 - DISABLE // GPIO34: WEBCAM_ON#, 0 - ON, 1 - OFF // -if (!CONFIG_ONBOARD_WEBCAM) { -//- if (SystemConfiguration.amdWebCam == 1) { + if (!CONFIG_ONBOARD_WEBCAM) { + //- if (SystemConfiguration.amdWebCam == 1) { RWMEM (GpioMmioAddr + SB_GPIO_REG34, AccWidthUint8, 0xBF, BIT6); -//- } -} + //- } + }
// // Travis enable: // amdTravisCtrl: CMOS, 0 - DISABLE, 1 - ENABLE // GPIO66: TRAVIS_EN#, 0 - ENABLE, 1 - DISABLE // -if (!CONFIG_ONBOARD_TRAVIS) { -//- if (SystemConfiguration.amdTravisCtrl == 0) { + if (!CONFIG_ONBOARD_TRAVIS) { + //- if (SystemConfiguration.amdTravisCtrl == 0) { RWMEM (GpioMmioAddr + SB_GPIO_REG66, AccWidthUint8, 0xBF, BIT6); -//- } -} + //- } + }
// // Disable Light Sensor if needed // -if (CONFIG_ONBOARD_LIGHTSENSOR) { -//- if (SystemConfiguration.amdLightSensor == 1) { - RWMEM (IoMuxMmioAddr + SB_GEVENT_REG12, AccWidthUint8, 0x00, 0x1); -//- } -} + if (CONFIG_ONBOARD_LIGHTSENSOR) { + //- if (SystemConfiguration.amdLightSensor == 1) { + RWMEM (IoMuxMmioAddr + SB_GEVENT_REG12, AccWidthUint8, 0x00, 0x1); + //- } + }
} diff --git a/src/mainboard/amd/torpedo/gpio.h b/src/mainboard/amd/torpedo/gpio.h index f2ceb02..0df5d50 100644 --- a/src/mainboard/amd/torpedo/gpio.h +++ b/src/mainboard/amd/torpedo/gpio.h @@ -31,28 +31,28 @@ *Mmio32_Ptr( BaseAddr, Register )
#define Mmio32_And_Or( BaseAddr, Register, AndData, OrData ) \ - Mmio32_G( BaseAddr, Register ) = \ - (u32) ( \ - ( Mmio32_G( BaseAddr, Register ) & \ - (u32)(AndData) \ - ) | \ - (u32)(OrData) \ - ) + Mmio32_G( BaseAddr, Register ) = \ + (u32) ( \ + ( Mmio32_G( BaseAddr, Register ) & \ + (u32)(AndData) \ + ) | \ + (u32)(OrData) \ + )
#define Mmio8_Ptr( BaseAddr, Register ) \ - ( (volatile u8 *)Mmio_Address( BaseAddr, Register ) ) + ( (volatile u8 *)Mmio_Address( BaseAddr, Register ) )
#define Mmio8_G( BaseAddr, Register ) \ - *Mmio8_Ptr( BaseAddr, Register ) + *Mmio8_Ptr( BaseAddr, Register )
#define Mmio8_And_Or( BaseAddr, Register, AndData, OrData ) \ - Mmio8_G( BaseAddr, Register ) = \ - (u8) ( \ - ( Mmio8_G( BaseAddr, Register ) & \ - (u8)(AndData) \ - ) | \ - (u8)(OrData) \ - ) + Mmio8_G( BaseAddr, Register ) = \ + (u8) ( \ + ( Mmio8_G( BaseAddr, Register ) & \ + (u8)(AndData) \ + ) | \ + (u8)(OrData) \ + )
#define SMIREG_EVENT_ENABLE 0x04 #define SMIREG_SCITRIG 0x08 @@ -1750,547 +1750,547 @@
typedef enum _GPIO_COUNT { - GPIO_00 = 0, - GPIO_01, - GPIO_02, - GPIO_03, - GPIO_04, - GPIO_05, - GPIO_06, - GPIO_07, - GPIO_08, - GPIO_09, - GPIO_10, - GPIO_11, - GPIO_12, - GPIO_13, - GPIO_14, - GPIO_15, - GPIO_16, - GPIO_17, - GPIO_18, - GPIO_19, - GPIO_20, - GPIO_21, - GPIO_22, - GPIO_23, - GPIO_24, - GPIO_25, - GPIO_26, - GPIO_27, - GPIO_28, - GPIO_29, - GPIO_30, - GPIO_31, - GPIO_32, - GPIO_33, - GPIO_34, - GPIO_35, - GPIO_36, - GPIO_37, - GPIO_38, - GPIO_39, - GPIO_40, - GPIO_41, - GPIO_42, - GPIO_43, - GPIO_44, - GPIO_45, - GPIO_46, - GPIO_47, - GPIO_48, - GPIO_49, - GPIO_50, - GPIO_51, - GPIO_52, - GPIO_53, - GPIO_54, - GPIO_55, - GPIO_56, - GPIO_57, - GPIO_58, - GPIO_59, - GPIO_60, - GPIO_61, - GPIO_62, - GPIO_63, - GPIO_64, - GPIO_65, - GPIO_66, - GPIO_67, - GPIO_68, - GPIO_69, - GPIO_70, - GPIO_71, - GPIO_72, - GPIO_73, - GPIO_74, - GPIO_75, - GPIO_76, - GPIO_77, - GPIO_78, - GPIO_79, - GPIO_80, - GPIO_81, - GPIO_82, - GPIO_83, - GPIO_84, - GPIO_85, - GPIO_86, - GPIO_87, - GPIO_88, - GPIO_89, - GPIO_90, - GPIO_91, - GPIO_92, - GPIO_93, - GPIO_94, - GPIO_95, - GPIO_96, - GPIO_97, - GPIO_98, - GPIO_99, - GPIO_100, - GPIO_101, - GPIO_102, - GPIO_103, - GPIO_104, - GPIO_105, - GPIO_106, - GPIO_107, - GPIO_108, - GPIO_109, - GPIO_110, - GPIO_111, - GPIO_112, - GPIO_113, - GPIO_114, - GPIO_115, - GPIO_116, - GPIO_117, - GPIO_118, - GPIO_119, - GPIO_120, - GPIO_121, - GPIO_122, - GPIO_123, - GPIO_124, - GPIO_125, - GPIO_126, - GPIO_127, - GPIO_128, - GPIO_129, - GPIO_130, - GPIO_131, - GPIO_132, - GPIO_133, - GPIO_134, - GPIO_135, - GPIO_136, - GPIO_137, - GPIO_138, - GPIO_139, - GPIO_140, - GPIO_141, - GPIO_142, - GPIO_143, - GPIO_144, - GPIO_145, - GPIO_146, - GPIO_147, - GPIO_148, - GPIO_149, - GPIO_150, - GPIO_151, - GPIO_152, - GPIO_153, - GPIO_154, - GPIO_155, - GPIO_156, - GPIO_157, - GPIO_158, - GPIO_159, - GPIO_160, - GPIO_161, - GPIO_162, - GPIO_163, - GPIO_164, - GPIO_165, - GPIO_166, - GPIO_167, - GPIO_168, - GPIO_169, - GPIO_170, - GPIO_171, - GPIO_172, - GPIO_173, - GPIO_174, - GPIO_175, - GPIO_176, - GPIO_177, - GPIO_178, - GPIO_179, - GPIO_180, - GPIO_181, - GPIO_182, - GPIO_183, - GPIO_184, - GPIO_185, - GPIO_186, - GPIO_187, - GPIO_188, - GPIO_189, - GPIO_190, - GPIO_191, - GPIO_192, - GPIO_193, - GPIO_194, - GPIO_195, - GPIO_196, - GPIO_197, - GPIO_198, - GPIO_199, - GPIO_200, - GPIO_201, - GPIO_202, - GPIO_203, - GPIO_204, - GPIO_205, - GPIO_206, - GPIO_207, - GPIO_208, - GPIO_209, - GPIO_210, - GPIO_211, - GPIO_212, - GPIO_213, - GPIO_214, - GPIO_215, - GPIO_216, - GPIO_217, - GPIO_218, - GPIO_219, - GPIO_220, - GPIO_221, - GPIO_222, - GPIO_223, - GPIO_224, - GPIO_225, - GPIO_226, - GPIO_227, - GPIO_228, - GPIO_229, - MAX_GPIO_NO + GPIO_00 = 0, + GPIO_01, + GPIO_02, + GPIO_03, + GPIO_04, + GPIO_05, + GPIO_06, + GPIO_07, + GPIO_08, + GPIO_09, + GPIO_10, + GPIO_11, + GPIO_12, + GPIO_13, + GPIO_14, + GPIO_15, + GPIO_16, + GPIO_17, + GPIO_18, + GPIO_19, + GPIO_20, + GPIO_21, + GPIO_22, + GPIO_23, + GPIO_24, + GPIO_25, + GPIO_26, + GPIO_27, + GPIO_28, + GPIO_29, + GPIO_30, + GPIO_31, + GPIO_32, + GPIO_33, + GPIO_34, + GPIO_35, + GPIO_36, + GPIO_37, + GPIO_38, + GPIO_39, + GPIO_40, + GPIO_41, + GPIO_42, + GPIO_43, + GPIO_44, + GPIO_45, + GPIO_46, + GPIO_47, + GPIO_48, + GPIO_49, + GPIO_50, + GPIO_51, + GPIO_52, + GPIO_53, + GPIO_54, + GPIO_55, + GPIO_56, + GPIO_57, + GPIO_58, + GPIO_59, + GPIO_60, + GPIO_61, + GPIO_62, + GPIO_63, + GPIO_64, + GPIO_65, + GPIO_66, + GPIO_67, + GPIO_68, + GPIO_69, + GPIO_70, + GPIO_71, + GPIO_72, + GPIO_73, + GPIO_74, + GPIO_75, + GPIO_76, + GPIO_77, + GPIO_78, + GPIO_79, + GPIO_80, + GPIO_81, + GPIO_82, + GPIO_83, + GPIO_84, + GPIO_85, + GPIO_86, + GPIO_87, + GPIO_88, + GPIO_89, + GPIO_90, + GPIO_91, + GPIO_92, + GPIO_93, + GPIO_94, + GPIO_95, + GPIO_96, + GPIO_97, + GPIO_98, + GPIO_99, + GPIO_100, + GPIO_101, + GPIO_102, + GPIO_103, + GPIO_104, + GPIO_105, + GPIO_106, + GPIO_107, + GPIO_108, + GPIO_109, + GPIO_110, + GPIO_111, + GPIO_112, + GPIO_113, + GPIO_114, + GPIO_115, + GPIO_116, + GPIO_117, + GPIO_118, + GPIO_119, + GPIO_120, + GPIO_121, + GPIO_122, + GPIO_123, + GPIO_124, + GPIO_125, + GPIO_126, + GPIO_127, + GPIO_128, + GPIO_129, + GPIO_130, + GPIO_131, + GPIO_132, + GPIO_133, + GPIO_134, + GPIO_135, + GPIO_136, + GPIO_137, + GPIO_138, + GPIO_139, + GPIO_140, + GPIO_141, + GPIO_142, + GPIO_143, + GPIO_144, + GPIO_145, + GPIO_146, + GPIO_147, + GPIO_148, + GPIO_149, + GPIO_150, + GPIO_151, + GPIO_152, + GPIO_153, + GPIO_154, + GPIO_155, + GPIO_156, + GPIO_157, + GPIO_158, + GPIO_159, + GPIO_160, + GPIO_161, + GPIO_162, + GPIO_163, + GPIO_164, + GPIO_165, + GPIO_166, + GPIO_167, + GPIO_168, + GPIO_169, + GPIO_170, + GPIO_171, + GPIO_172, + GPIO_173, + GPIO_174, + GPIO_175, + GPIO_176, + GPIO_177, + GPIO_178, + GPIO_179, + GPIO_180, + GPIO_181, + GPIO_182, + GPIO_183, + GPIO_184, + GPIO_185, + GPIO_186, + GPIO_187, + GPIO_188, + GPIO_189, + GPIO_190, + GPIO_191, + GPIO_192, + GPIO_193, + GPIO_194, + GPIO_195, + GPIO_196, + GPIO_197, + GPIO_198, + GPIO_199, + GPIO_200, + GPIO_201, + GPIO_202, + GPIO_203, + GPIO_204, + GPIO_205, + GPIO_206, + GPIO_207, + GPIO_208, + GPIO_209, + GPIO_210, + GPIO_211, + GPIO_212, + GPIO_213, + GPIO_214, + GPIO_215, + GPIO_216, + GPIO_217, + GPIO_218, + GPIO_219, + GPIO_220, + GPIO_221, + GPIO_222, + GPIO_223, + GPIO_224, + GPIO_225, + GPIO_226, + GPIO_227, + GPIO_228, + GPIO_229, + MAX_GPIO_NO } GPIO_COUNT;
typedef struct _GPIO_SETTINGS { - u8 select; - u8 type; - u8 value; - u8 NonGpioGevent; + u8 select; + u8 type; + u8 value; + u8 NonGpioGevent; } GPIO_SETTINGS;
const GPIO_SETTINGS gpio_table[]= { - {GPIO_00_SELECT, GPIO_00_TYPE, GPO_00_LEVEL+GPIO_00_STICKY+GPIO_00_PULLUP+GPIO_00_PULLDOWN, GPIO_00_SELECT}, - {GPIO_01_SELECT, GPIO_01_TYPE, GPO_01_LEVEL+GPIO_01_STICKY+GPIO_01_PULLUP+GPIO_01_PULLDOWN, GPIO_01_SELECT}, - {GPIO_02_SELECT, GPIO_02_TYPE, GPO_02_LEVEL+GPIO_02_STICKY+GPIO_02_PULLUP+GPIO_02_PULLDOWN, GPIO_02_SELECT}, - {GPIO_03_SELECT, GPIO_03_TYPE, GPO_03_LEVEL+GPIO_03_STICKY+GPIO_03_PULLUP+GPIO_03_PULLDOWN, GPIO_03_SELECT}, - {GPIO_04_SELECT, GPIO_04_TYPE, GPO_04_LEVEL+GPIO_04_STICKY+GPIO_04_PULLUP+GPIO_04_PULLDOWN, GPIO_04_SELECT}, - {GPIO_05_SELECT, GPIO_05_TYPE, GPO_05_LEVEL+GPIO_05_STICKY+GPIO_05_PULLUP+GPIO_05_PULLDOWN, GPIO_05_SELECT}, - {GPIO_06_SELECT, GPIO_06_TYPE, GPO_06_LEVEL+GPIO_06_STICKY+GPIO_06_PULLUP+GPIO_06_PULLDOWN, GPIO_06_SELECT}, - {GPIO_07_SELECT, GPIO_07_TYPE, GPO_07_LEVEL+GPIO_07_STICKY+GPIO_07_PULLUP+GPIO_07_PULLDOWN, GPIO_07_SELECT}, - {GPIO_08_SELECT, GPIO_08_TYPE, GPO_08_LEVEL+GPIO_08_STICKY+GPIO_08_PULLUP+GPIO_08_PULLDOWN, GPIO_08_SELECT}, - {GPIO_09_SELECT, GPIO_09_TYPE, GPO_09_LEVEL+GPIO_09_STICKY+GPIO_09_PULLUP+GPIO_09_PULLDOWN, GPIO_09_SELECT}, - {GPIO_10_SELECT, GPIO_10_TYPE, GPO_10_LEVEL+GPIO_10_STICKY+GPIO_10_PULLUP+GPIO_10_PULLDOWN, GPIO_10_SELECT}, - {GPIO_11_SELECT, GPIO_11_TYPE, GPO_11_LEVEL+GPIO_11_STICKY+GPIO_11_PULLUP+GPIO_11_PULLDOWN, GPIO_11_SELECT}, - {GPIO_12_SELECT, GPIO_12_TYPE, GPO_12_LEVEL+GPIO_12_STICKY+GPIO_12_PULLUP+GPIO_12_PULLDOWN, GPIO_12_SELECT}, - {GPIO_13_SELECT, GPIO_13_TYPE, GPO_13_LEVEL+GPIO_13_STICKY+GPIO_13_PULLUP+GPIO_13_PULLDOWN, GPIO_13_SELECT}, - {GPIO_14_SELECT, GPIO_14_TYPE, GPO_14_LEVEL+GPIO_14_STICKY+GPIO_14_PULLUP+GPIO_14_PULLDOWN, GPIO_14_SELECT}, - {GPIO_15_SELECT, GPIO_15_TYPE, GPO_15_LEVEL+GPIO_15_STICKY+GPIO_15_PULLUP+GPIO_15_PULLDOWN, GPIO_15_SELECT}, - {GPIO_16_SELECT, GPIO_16_TYPE, GPO_16_LEVEL+GPIO_16_STICKY+GPIO_16_PULLUP+GPIO_16_PULLDOWN, GPIO_16_SELECT}, - {GPIO_17_SELECT, GPIO_17_TYPE, GPO_17_LEVEL+GPIO_17_STICKY+GPIO_17_PULLUP+GPIO_17_PULLDOWN, GPIO_17_SELECT}, - {GPIO_18_SELECT, GPIO_18_TYPE, GPO_18_LEVEL+GPIO_18_STICKY+GPIO_18_PULLUP+GPIO_18_PULLDOWN, GPIO_18_SELECT}, - {GPIO_19_SELECT, GPIO_19_TYPE, GPO_19_LEVEL+GPIO_19_STICKY+GPIO_19_PULLUP+GPIO_19_PULLDOWN, GPIO_19_SELECT}, - {GPIO_20_SELECT, GPIO_20_TYPE, GPO_20_LEVEL+GPIO_20_STICKY+GPIO_20_PULLUP+GPIO_20_PULLDOWN, GPIO_20_SELECT}, - {GPIO_21_SELECT, GPIO_21_TYPE, GPO_21_LEVEL+GPIO_21_STICKY+GPIO_21_PULLUP+GPIO_21_PULLDOWN, GPIO_21_SELECT}, - {GPIO_22_SELECT, GPIO_22_TYPE, GPO_22_LEVEL+GPIO_22_STICKY+GPIO_22_PULLUP+GPIO_22_PULLDOWN, GPIO_22_SELECT}, - {GPIO_23_SELECT, GPIO_23_TYPE, GPO_23_LEVEL+GPIO_23_STICKY+GPIO_23_PULLUP+GPIO_23_PULLDOWN, GPIO_23_SELECT}, - {GPIO_24_SELECT, GPIO_24_TYPE, GPO_24_LEVEL+GPIO_24_STICKY+GPIO_24_PULLUP+GPIO_24_PULLDOWN, GPIO_24_SELECT}, - {GPIO_25_SELECT, GPIO_25_TYPE, GPO_25_LEVEL+GPIO_25_STICKY+GPIO_25_PULLUP+GPIO_25_PULLDOWN, GPIO_25_SELECT}, - {GPIO_26_SELECT, GPIO_26_TYPE, GPO_26_LEVEL+GPIO_26_STICKY+GPIO_26_PULLUP+GPIO_26_PULLDOWN, GPIO_26_SELECT}, - {GPIO_27_SELECT, GPIO_27_TYPE, GPO_27_LEVEL+GPIO_27_STICKY+GPIO_27_PULLUP+GPIO_27_PULLDOWN, GPIO_27_SELECT}, - {GPIO_28_SELECT, GPIO_28_TYPE, GPO_28_LEVEL+GPIO_28_STICKY+GPIO_28_PULLUP+GPIO_28_PULLDOWN, GPIO_28_SELECT}, - {GPIO_29_SELECT, GPIO_29_TYPE, GPO_29_LEVEL+GPIO_29_STICKY+GPIO_29_PULLUP+GPIO_29_PULLDOWN, GPIO_29_SELECT}, - {GPIO_30_SELECT, GPIO_30_TYPE, GPO_30_LEVEL+GPIO_30_STICKY+GPIO_30_PULLUP+GPIO_30_PULLDOWN, GPIO_30_SELECT}, - {GPIO_31_SELECT, GPIO_31_TYPE, GPO_31_LEVEL+GPIO_31_STICKY+GPIO_31_PULLUP+GPIO_31_PULLDOWN, GPIO_31_SELECT}, - {GPIO_32_SELECT, GPIO_32_TYPE, GPO_32_LEVEL+GPIO_32_STICKY+GPIO_32_PULLUP+GPIO_32_PULLDOWN, GPIO_32_SELECT}, - {GPIO_33_SELECT, GPIO_33_TYPE, GPO_33_LEVEL+GPIO_33_STICKY+GPIO_33_PULLUP+GPIO_33_PULLDOWN, GPIO_33_SELECT}, - {GPIO_34_SELECT, GPIO_34_TYPE, GPO_34_LEVEL+GPIO_34_STICKY+GPIO_34_PULLUP+GPIO_34_PULLDOWN, GPIO_34_SELECT}, - {GPIO_35_SELECT, GPIO_35_TYPE, GPO_35_LEVEL+GPIO_35_STICKY+GPIO_35_PULLUP+GPIO_35_PULLDOWN, GPIO_35_SELECT}, - {GPIO_36_SELECT, GPIO_36_TYPE, GPO_36_LEVEL+GPIO_36_STICKY+GPIO_36_PULLUP+GPIO_36_PULLDOWN, GPIO_36_SELECT}, - {GPIO_37_SELECT, GPIO_37_TYPE, GPO_37_LEVEL+GPIO_37_STICKY+GPIO_37_PULLUP+GPIO_37_PULLDOWN, GPIO_37_SELECT}, - {GPIO_38_SELECT, GPIO_38_TYPE, GPO_38_LEVEL+GPIO_38_STICKY+GPIO_38_PULLUP+GPIO_38_PULLDOWN, GPIO_38_SELECT}, - {GPIO_39_SELECT, GPIO_39_TYPE, GPO_39_LEVEL+GPIO_39_STICKY+GPIO_39_PULLUP+GPIO_39_PULLDOWN, GPIO_39_SELECT}, - {GPIO_40_SELECT, GPIO_40_TYPE, GPO_40_LEVEL+GPIO_40_STICKY+GPIO_40_PULLUP+GPIO_40_PULLDOWN, GPIO_40_SELECT}, - {GPIO_41_SELECT, GPIO_41_TYPE, GPO_41_LEVEL+GPIO_41_STICKY+GPIO_41_PULLUP+GPIO_41_PULLDOWN, GPIO_41_SELECT}, - {GPIO_42_SELECT, GPIO_42_TYPE, GPO_42_LEVEL+GPIO_42_STICKY+GPIO_42_PULLUP+GPIO_42_PULLDOWN, GPIO_42_SELECT}, - {GPIO_43_SELECT, GPIO_43_TYPE, GPO_43_LEVEL+GPIO_43_STICKY+GPIO_43_PULLUP+GPIO_43_PULLDOWN, GPIO_43_SELECT}, - {GPIO_44_SELECT, GPIO_44_TYPE, GPO_44_LEVEL+GPIO_44_STICKY+GPIO_44_PULLUP+GPIO_44_PULLDOWN, GPIO_44_SELECT}, - {GPIO_45_SELECT, GPIO_45_TYPE, GPO_45_LEVEL+GPIO_45_STICKY+GPIO_45_PULLUP+GPIO_45_PULLDOWN, GPIO_45_SELECT}, - {GPIO_46_SELECT, GPIO_46_TYPE, GPO_46_LEVEL+GPIO_46_STICKY+GPIO_46_PULLUP+GPIO_46_PULLDOWN, GPIO_46_SELECT}, - {GPIO_47_SELECT, GPIO_47_TYPE, GPO_47_LEVEL+GPIO_47_STICKY+GPIO_47_PULLUP+GPIO_47_PULLDOWN, GPIO_47_SELECT}, - {GPIO_48_SELECT, GPIO_48_TYPE, GPO_48_LEVEL+GPIO_48_STICKY+GPIO_48_PULLUP+GPIO_48_PULLDOWN, GPIO_48_SELECT}, - {GPIO_49_SELECT, GPIO_49_TYPE, GPO_49_LEVEL+GPIO_49_STICKY+GPIO_49_PULLUP+GPIO_49_PULLDOWN, GPIO_49_SELECT}, - {GPIO_50_SELECT, GPIO_50_TYPE, GPO_50_LEVEL+GPIO_50_STICKY+GPIO_50_PULLUP+GPIO_50_PULLDOWN, GPIO_50_SELECT}, - {GPIO_51_SELECT, GPIO_51_TYPE, GPO_51_LEVEL+GPIO_51_STICKY+GPIO_51_PULLUP+GPIO_51_PULLDOWN, GPIO_51_SELECT}, - {GPIO_52_SELECT, GPIO_52_TYPE, GPO_52_LEVEL+GPIO_52_STICKY+GPIO_52_PULLUP+GPIO_52_PULLDOWN, GPIO_52_SELECT}, - {GPIO_53_SELECT, GPIO_53_TYPE, GPO_53_LEVEL+GPIO_53_STICKY+GPIO_53_PULLUP+GPIO_53_PULLDOWN, GPIO_53_SELECT}, - {GPIO_54_SELECT, GPIO_54_TYPE, GPO_54_LEVEL+GPIO_54_STICKY+GPIO_54_PULLUP+GPIO_54_PULLDOWN, GPIO_54_SELECT}, - {GPIO_55_SELECT, GPIO_55_TYPE, GPO_55_LEVEL+GPIO_55_STICKY+GPIO_55_PULLUP+GPIO_55_PULLDOWN, GPIO_55_SELECT}, - {GPIO_56_SELECT, GPIO_56_TYPE, GPO_56_LEVEL+GPIO_56_STICKY+GPIO_56_PULLUP+GPIO_56_PULLDOWN, GPIO_56_SELECT}, - {GPIO_57_SELECT, GPIO_57_TYPE, GPO_57_LEVEL+GPIO_57_STICKY+GPIO_57_PULLUP+GPIO_57_PULLDOWN, GPIO_57_SELECT}, - {GPIO_58_SELECT, GPIO_58_TYPE, GPO_58_LEVEL+GPIO_58_STICKY+GPIO_58_PULLUP+GPIO_58_PULLDOWN, GPIO_58_SELECT}, - {GPIO_59_SELECT, GPIO_59_TYPE, GPO_59_LEVEL+GPIO_59_STICKY+GPIO_59_PULLUP+GPIO_59_PULLDOWN, GPIO_59_SELECT}, - {GPIO_60_SELECT, GPIO_60_TYPE, GPO_60_LEVEL+GPIO_60_STICKY+GPIO_60_PULLUP+GPIO_60_PULLDOWN, GPIO_60_SELECT}, - {GPIO_61_SELECT, GPIO_61_TYPE, GPO_61_LEVEL+GPIO_61_STICKY+GPIO_61_PULLUP+GPIO_61_PULLDOWN, GPIO_61_SELECT}, - {GPIO_62_SELECT, GPIO_62_TYPE, GPO_62_LEVEL+GPIO_62_STICKY+GPIO_62_PULLUP+GPIO_62_PULLDOWN, GPIO_62_SELECT}, - {GPIO_63_SELECT, GPIO_63_TYPE, GPO_63_LEVEL+GPIO_63_STICKY+GPIO_63_PULLUP+GPIO_63_PULLDOWN, GPIO_63_SELECT}, - {GPIO_64_SELECT, GPIO_64_TYPE, GPO_64_LEVEL+GPIO_64_STICKY+GPIO_64_PULLUP+GPIO_64_PULLDOWN, GPIO_64_SELECT}, - {GPIO_65_SELECT, GPIO_65_TYPE, GPO_65_LEVEL+GPIO_65_STICKY+GPIO_65_PULLUP+GPIO_65_PULLDOWN, GPIO_65_SELECT}, - {GPIO_66_SELECT, GPIO_66_TYPE, GPO_66_LEVEL+GPIO_66_STICKY+GPIO_66_PULLUP+GPIO_66_PULLDOWN, GPIO_66_SELECT}, - {GPIO_67_SELECT, GPIO_67_TYPE, GPO_67_LEVEL+GPIO_67_STICKY+GPIO_67_PULLUP+GPIO_67_PULLDOWN, GPIO_67_SELECT}, - {GPIO_68_SELECT, GPIO_68_TYPE, GPO_68_LEVEL+GPIO_68_STICKY+GPIO_68_PULLUP+GPIO_68_PULLDOWN, GPIO_68_SELECT}, - {GPIO_69_SELECT, GPIO_69_TYPE, GPO_69_LEVEL+GPIO_69_STICKY+GPIO_69_PULLUP+GPIO_69_PULLDOWN, GPIO_69_SELECT}, - {GPIO_70_SELECT, GPIO_70_TYPE, GPO_70_LEVEL+GPIO_70_STICKY+GPIO_70_PULLUP+GPIO_70_PULLDOWN, GPIO_70_SELECT}, - {GPIO_71_SELECT, GPIO_71_TYPE, GPO_71_LEVEL+GPIO_71_STICKY+GPIO_71_PULLUP+GPIO_71_PULLDOWN, GPIO_71_SELECT}, - {GPIO_72_SELECT, GPIO_72_TYPE, GPO_72_LEVEL+GPIO_72_STICKY+GPIO_72_PULLUP+GPIO_72_PULLDOWN, GPIO_72_SELECT}, - {GPIO_73_SELECT, GPIO_73_TYPE, GPO_73_LEVEL+GPIO_73_STICKY+GPIO_73_PULLUP+GPIO_73_PULLDOWN, GPIO_73_SELECT}, - {GPIO_74_SELECT, GPIO_74_TYPE, GPO_74_LEVEL+GPIO_74_STICKY+GPIO_74_PULLUP+GPIO_74_PULLDOWN, GPIO_74_SELECT}, - {GPIO_75_SELECT, GPIO_75_TYPE, GPO_75_LEVEL+GPIO_75_STICKY+GPIO_75_PULLUP+GPIO_75_PULLDOWN, GPIO_75_SELECT}, - {GPIO_76_SELECT, GPIO_76_TYPE, GPO_76_LEVEL+GPIO_76_STICKY+GPIO_76_PULLUP+GPIO_76_PULLDOWN, GPIO_76_SELECT}, - {GPIO_77_SELECT, GPIO_77_TYPE, GPO_77_LEVEL+GPIO_77_STICKY+GPIO_77_PULLUP+GPIO_77_PULLDOWN, GPIO_77_SELECT}, - {GPIO_78_SELECT, GPIO_78_TYPE, GPO_78_LEVEL+GPIO_78_STICKY+GPIO_78_PULLUP+GPIO_78_PULLDOWN, GPIO_78_SELECT}, - {GPIO_79_SELECT, GPIO_79_TYPE, GPO_79_LEVEL+GPIO_79_STICKY+GPIO_79_PULLUP+GPIO_79_PULLDOWN, GPIO_79_SELECT}, - {GPIO_80_SELECT, GPIO_80_TYPE, GPO_80_LEVEL+GPIO_80_STICKY+GPIO_80_PULLUP+GPIO_80_PULLDOWN, GPIO_80_SELECT}, - {GPIO_81_SELECT, GPIO_81_TYPE, GPO_81_LEVEL+GPIO_81_STICKY+GPIO_81_PULLUP+GPIO_81_PULLDOWN, GPIO_81_SELECT}, - {GPIO_82_SELECT, GPIO_82_TYPE, GPO_82_LEVEL+GPIO_82_STICKY+GPIO_82_PULLUP+GPIO_82_PULLDOWN, GPIO_82_SELECT}, - {GPIO_83_SELECT, GPIO_83_TYPE, GPO_83_LEVEL+GPIO_83_STICKY+GPIO_83_PULLUP+GPIO_83_PULLDOWN, GPIO_83_SELECT}, - {GPIO_84_SELECT, GPIO_84_TYPE, GPO_84_LEVEL+GPIO_84_STICKY+GPIO_84_PULLUP+GPIO_84_PULLDOWN, GPIO_84_SELECT}, - {GPIO_85_SELECT, GPIO_85_TYPE, GPO_85_LEVEL+GPIO_85_STICKY+GPIO_85_PULLUP+GPIO_85_PULLDOWN, GPIO_85_SELECT}, - {GPIO_86_SELECT, GPIO_86_TYPE, GPO_86_LEVEL+GPIO_86_STICKY+GPIO_86_PULLUP+GPIO_86_PULLDOWN, GPIO_86_SELECT}, - {GPIO_87_SELECT, GPIO_87_TYPE, GPO_87_LEVEL+GPIO_87_STICKY+GPIO_87_PULLUP+GPIO_87_PULLDOWN, GPIO_87_SELECT}, - {GPIO_88_SELECT, GPIO_88_TYPE, GPO_88_LEVEL+GPIO_88_STICKY+GPIO_88_PULLUP+GPIO_88_PULLDOWN, GPIO_88_SELECT}, - {GPIO_89_SELECT, GPIO_89_TYPE, GPO_89_LEVEL+GPIO_89_STICKY+GPIO_89_PULLUP+GPIO_89_PULLDOWN, GPIO_89_SELECT}, - {GPIO_90_SELECT, GPIO_90_TYPE, GPO_90_LEVEL+GPIO_90_STICKY+GPIO_90_PULLUP+GPIO_90_PULLDOWN, GPIO_90_SELECT}, - {GPIO_91_SELECT, GPIO_91_TYPE, GPO_91_LEVEL+GPIO_91_STICKY+GPIO_91_PULLUP+GPIO_91_PULLDOWN, GPIO_91_SELECT}, - {GPIO_92_SELECT, GPIO_92_TYPE, GPO_92_LEVEL+GPIO_92_STICKY+GPIO_92_PULLUP+GPIO_92_PULLDOWN, GPIO_92_SELECT}, - {GPIO_93_SELECT, GPIO_93_TYPE, GPO_93_LEVEL+GPIO_93_STICKY+GPIO_93_PULLUP+GPIO_93_PULLDOWN, GPIO_93_SELECT}, - {GPIO_94_SELECT, GPIO_94_TYPE, GPO_94_LEVEL+GPIO_94_STICKY+GPIO_94_PULLUP+GPIO_94_PULLDOWN, GPIO_94_SELECT}, - {GPIO_95_SELECT, GPIO_95_TYPE, GPO_95_LEVEL+GPIO_95_STICKY+GPIO_95_PULLUP+GPIO_95_PULLDOWN, GPIO_95_SELECT}, - {GPIO_96_SELECT, GPIO_96_TYPE, GPO_96_LEVEL+GPIO_96_STICKY+GPIO_96_PULLUP+GPIO_96_PULLDOWN, GPIO_96_SELECT}, - {GPIO_97_SELECT, GPIO_97_TYPE, GPO_97_LEVEL+GPIO_97_STICKY+GPIO_97_PULLUP+GPIO_97_PULLDOWN, GPIO_97_SELECT}, - {GPIO_98_SELECT, GPIO_98_TYPE, GPO_98_LEVEL+GPIO_98_STICKY+GPIO_98_PULLUP+GPIO_98_PULLDOWN, GPIO_98_SELECT}, - {GPIO_99_SELECT, GPIO_99_TYPE, GPO_99_LEVEL+GPIO_99_STICKY+GPIO_99_PULLUP+GPIO_99_PULLDOWN, GPIO_99_SELECT}, - {GPIO_100_SELECT, GPIO_100_TYPE, GPO_100_LEVEL+GPIO_100_STICKY+GPIO_100_PULLUP+GPIO_100_PULLDOWN, GPIO_100_SELECT}, - {GPIO_101_SELECT, GPIO_101_TYPE, GPO_101_LEVEL+GPIO_101_STICKY+GPIO_101_PULLUP+GPIO_101_PULLDOWN, GPIO_101_SELECT}, - {GPIO_102_SELECT, GPIO_102_TYPE, GPO_102_LEVEL+GPIO_102_STICKY+GPIO_102_PULLUP+GPIO_102_PULLDOWN, GPIO_102_SELECT}, - {GPIO_103_SELECT, GPIO_103_TYPE, GPO_103_LEVEL+GPIO_103_STICKY+GPIO_103_PULLUP+GPIO_103_PULLDOWN, GPIO_103_SELECT}, - {GPIO_104_SELECT, GPIO_104_TYPE, GPO_104_LEVEL+GPIO_104_STICKY+GPIO_104_PULLUP+GPIO_104_PULLDOWN, GPIO_104_SELECT}, - {GPIO_105_SELECT, GPIO_105_TYPE, GPO_105_LEVEL+GPIO_105_STICKY+GPIO_105_PULLUP+GPIO_105_PULLDOWN, GPIO_105_SELECT}, - {GPIO_106_SELECT, GPIO_106_TYPE, GPO_106_LEVEL+GPIO_106_STICKY+GPIO_106_PULLUP+GPIO_106_PULLDOWN, GPIO_106_SELECT}, - {GPIO_107_SELECT, GPIO_107_TYPE, GPO_107_LEVEL+GPIO_107_STICKY+GPIO_107_PULLUP+GPIO_107_PULLDOWN, GPIO_107_SELECT}, - {GPIO_108_SELECT, GPIO_108_TYPE, GPO_108_LEVEL+GPIO_108_STICKY+GPIO_108_PULLUP+GPIO_108_PULLDOWN, GPIO_108_SELECT}, - {GPIO_109_SELECT, GPIO_109_TYPE, GPO_109_LEVEL+GPIO_109_STICKY+GPIO_109_PULLUP+GPIO_109_PULLDOWN, GPIO_109_SELECT}, - {GPIO_110_SELECT, GPIO_110_TYPE, GPO_110_LEVEL+GPIO_110_STICKY+GPIO_110_PULLUP+GPIO_110_PULLDOWN, GPIO_110_SELECT}, - {GPIO_111_SELECT, GPIO_111_TYPE, GPO_111_LEVEL+GPIO_111_STICKY+GPIO_111_PULLUP+GPIO_111_PULLDOWN, GPIO_111_SELECT}, - {GPIO_112_SELECT, GPIO_112_TYPE, GPO_112_LEVEL+GPIO_112_STICKY+GPIO_112_PULLUP+GPIO_112_PULLDOWN, GPIO_112_SELECT}, - {GPIO_113_SELECT, GPIO_113_TYPE, GPO_113_LEVEL+GPIO_113_STICKY+GPIO_113_PULLUP+GPIO_113_PULLDOWN, GPIO_113_SELECT}, - {GPIO_114_SELECT, GPIO_114_TYPE, GPO_114_LEVEL+GPIO_114_STICKY+GPIO_114_PULLUP+GPIO_114_PULLDOWN, GPIO_114_SELECT}, - {GPIO_115_SELECT, GPIO_115_TYPE, GPO_115_LEVEL+GPIO_115_STICKY+GPIO_115_PULLUP+GPIO_115_PULLDOWN, GPIO_115_SELECT}, - {GPIO_116_SELECT, GPIO_116_TYPE, GPO_116_LEVEL+GPIO_116_STICKY+GPIO_116_PULLUP+GPIO_116_PULLDOWN, GPIO_116_SELECT}, - {GPIO_117_SELECT, GPIO_117_TYPE, GPO_117_LEVEL+GPIO_117_STICKY+GPIO_117_PULLUP+GPIO_117_PULLDOWN, GPIO_117_SELECT}, - {GPIO_118_SELECT, GPIO_118_TYPE, GPO_118_LEVEL+GPIO_118_STICKY+GPIO_118_PULLUP+GPIO_118_PULLDOWN, GPIO_118_SELECT}, - {GPIO_119_SELECT, GPIO_119_TYPE, GPO_119_LEVEL+GPIO_119_STICKY+GPIO_119_PULLUP+GPIO_119_PULLDOWN, GPIO_119_SELECT}, - {GPIO_120_SELECT, GPIO_120_TYPE, GPO_120_LEVEL+GPIO_120_STICKY+GPIO_120_PULLUP+GPIO_120_PULLDOWN, GPIO_120_SELECT}, - {GPIO_121_SELECT, GPIO_121_TYPE, GPO_121_LEVEL+GPIO_121_STICKY+GPIO_121_PULLUP+GPIO_121_PULLDOWN, GPIO_121_SELECT}, - {GPIO_122_SELECT, GPIO_122_TYPE, GPO_122_LEVEL+GPIO_122_STICKY+GPIO_122_PULLUP+GPIO_122_PULLDOWN, GPIO_122_SELECT}, - {GPIO_123_SELECT, GPIO_123_TYPE, GPO_123_LEVEL+GPIO_123_STICKY+GPIO_123_PULLUP+GPIO_123_PULLDOWN, GPIO_123_SELECT}, - {GPIO_124_SELECT, GPIO_124_TYPE, GPO_124_LEVEL+GPIO_124_STICKY+GPIO_124_PULLUP+GPIO_124_PULLDOWN, GPIO_124_SELECT}, - {GPIO_125_SELECT, GPIO_125_TYPE, GPO_125_LEVEL+GPIO_125_STICKY+GPIO_125_PULLUP+GPIO_125_PULLDOWN, GPIO_125_SELECT}, - {GPIO_126_SELECT, GPIO_126_TYPE, GPO_126_LEVEL+GPIO_126_STICKY+GPIO_126_PULLUP+GPIO_126_PULLDOWN, GPIO_126_SELECT}, - {GPIO_127_SELECT, GPIO_127_TYPE, GPO_127_LEVEL+GPIO_127_STICKY+GPIO_127_PULLUP+GPIO_127_PULLDOWN, GPIO_127_SELECT}, - {GPIO_128_SELECT, GPIO_128_TYPE, GPO_128_LEVEL+GPIO_128_STICKY+GPIO_128_PULLUP+GPIO_128_PULLDOWN, GPIO_128_SELECT}, - {GPIO_129_SELECT, GPIO_129_TYPE, GPO_129_LEVEL+GPIO_129_STICKY+GPIO_129_PULLUP+GPIO_129_PULLDOWN, GPIO_129_SELECT}, - {GPIO_130_SELECT, GPIO_130_TYPE, GPO_130_LEVEL+GPIO_130_STICKY+GPIO_130_PULLUP+GPIO_130_PULLDOWN, GPIO_130_SELECT}, - {GPIO_131_SELECT, GPIO_131_TYPE, GPO_131_LEVEL+GPIO_131_STICKY+GPIO_131_PULLUP+GPIO_131_PULLDOWN, GPIO_131_SELECT}, - {GPIO_132_SELECT, GPIO_132_TYPE, GPO_132_LEVEL+GPIO_132_STICKY+GPIO_132_PULLUP+GPIO_132_PULLDOWN, GPIO_132_SELECT}, - {GPIO_133_SELECT, GPIO_133_TYPE, GPO_133_LEVEL+GPIO_133_STICKY+GPIO_133_PULLUP+GPIO_133_PULLDOWN, GPIO_133_SELECT}, - {GPIO_134_SELECT, GPIO_134_TYPE, GPO_134_LEVEL+GPIO_134_STICKY+GPIO_134_PULLUP+GPIO_134_PULLDOWN, GPIO_134_SELECT}, - {GPIO_135_SELECT, GPIO_135_TYPE, GPO_135_LEVEL+GPIO_135_STICKY+GPIO_135_PULLUP+GPIO_135_PULLDOWN, GPIO_135_SELECT}, - {GPIO_136_SELECT, GPIO_136_TYPE, GPO_136_LEVEL+GPIO_136_STICKY+GPIO_136_PULLUP+GPIO_136_PULLDOWN, GPIO_136_SELECT}, - {GPIO_137_SELECT, GPIO_137_TYPE, GPO_137_LEVEL+GPIO_137_STICKY+GPIO_137_PULLUP+GPIO_137_PULLDOWN, GPIO_137_SELECT}, - {GPIO_138_SELECT, GPIO_138_TYPE, GPO_138_LEVEL+GPIO_138_STICKY+GPIO_138_PULLUP+GPIO_138_PULLDOWN, GPIO_138_SELECT}, - {GPIO_139_SELECT, GPIO_139_TYPE, GPO_139_LEVEL+GPIO_139_STICKY+GPIO_139_PULLUP+GPIO_139_PULLDOWN, GPIO_139_SELECT}, - {GPIO_140_SELECT, GPIO_140_TYPE, GPO_140_LEVEL+GPIO_140_STICKY+GPIO_140_PULLUP+GPIO_140_PULLDOWN, GPIO_140_SELECT}, - {GPIO_141_SELECT, GPIO_141_TYPE, GPO_141_LEVEL+GPIO_141_STICKY+GPIO_141_PULLUP+GPIO_141_PULLDOWN, GPIO_141_SELECT}, - {GPIO_142_SELECT, GPIO_142_TYPE, GPO_142_LEVEL+GPIO_142_STICKY+GPIO_142_PULLUP+GPIO_142_PULLDOWN, GPIO_142_SELECT}, - {GPIO_143_SELECT, GPIO_143_TYPE, GPO_143_LEVEL+GPIO_143_STICKY+GPIO_143_PULLUP+GPIO_143_PULLDOWN, GPIO_143_SELECT}, - {GPIO_144_SELECT, GPIO_144_TYPE, GPO_144_LEVEL+GPIO_144_STICKY+GPIO_144_PULLUP+GPIO_144_PULLDOWN, GPIO_144_SELECT}, - {GPIO_145_SELECT, GPIO_145_TYPE, GPO_145_LEVEL+GPIO_145_STICKY+GPIO_145_PULLUP+GPIO_145_PULLDOWN, GPIO_145_SELECT}, - {GPIO_146_SELECT, GPIO_146_TYPE, GPO_146_LEVEL+GPIO_146_STICKY+GPIO_146_PULLUP+GPIO_146_PULLDOWN, GPIO_146_SELECT}, - {GPIO_147_SELECT, GPIO_147_TYPE, GPO_147_LEVEL+GPIO_147_STICKY+GPIO_147_PULLUP+GPIO_147_PULLDOWN, GPIO_147_SELECT}, - {GPIO_148_SELECT, GPIO_148_TYPE, GPO_148_LEVEL+GPIO_148_STICKY+GPIO_148_PULLUP+GPIO_148_PULLDOWN, GPIO_148_SELECT}, - {GPIO_149_SELECT, GPIO_149_TYPE, GPO_149_LEVEL+GPIO_149_STICKY+GPIO_149_PULLUP+GPIO_149_PULLDOWN, GPIO_149_SELECT}, - {GPIO_150_SELECT, GPIO_150_TYPE, GPO_150_LEVEL+GPIO_150_STICKY+GPIO_150_PULLUP+GPIO_150_PULLDOWN, GPIO_150_SELECT}, - {GPIO_151_SELECT, GPIO_151_TYPE, GPO_151_LEVEL+GPIO_151_STICKY+GPIO_151_PULLUP+GPIO_151_PULLDOWN, GPIO_151_SELECT}, - {GPIO_152_SELECT, GPIO_152_TYPE, GPO_152_LEVEL+GPIO_152_STICKY+GPIO_152_PULLUP+GPIO_152_PULLDOWN, GPIO_152_SELECT}, - {GPIO_153_SELECT, GPIO_153_TYPE, GPO_153_LEVEL+GPIO_153_STICKY+GPIO_153_PULLUP+GPIO_153_PULLDOWN, GPIO_153_SELECT}, - {GPIO_154_SELECT, GPIO_154_TYPE, GPO_154_LEVEL+GPIO_154_STICKY+GPIO_154_PULLUP+GPIO_154_PULLDOWN, GPIO_154_SELECT}, - {GPIO_155_SELECT, GPIO_155_TYPE, GPO_155_LEVEL+GPIO_155_STICKY+GPIO_155_PULLUP+GPIO_155_PULLDOWN, GPIO_155_SELECT}, - {GPIO_156_SELECT, GPIO_156_TYPE, GPO_156_LEVEL+GPIO_156_STICKY+GPIO_156_PULLUP+GPIO_156_PULLDOWN, GPIO_156_SELECT}, - {GPIO_157_SELECT, GPIO_157_TYPE, GPO_157_LEVEL+GPIO_157_STICKY+GPIO_157_PULLUP+GPIO_157_PULLDOWN, GPIO_157_SELECT}, - {GPIO_158_SELECT, GPIO_158_TYPE, GPO_158_LEVEL+GPIO_158_STICKY+GPIO_158_PULLUP+GPIO_158_PULLDOWN, GPIO_158_SELECT}, - {GPIO_159_SELECT, GPIO_159_TYPE, GPO_159_LEVEL+GPIO_159_STICKY+GPIO_159_PULLUP+GPIO_159_PULLDOWN, GPIO_159_SELECT}, - {GPIO_160_SELECT, GPIO_160_TYPE, GPO_160_LEVEL+GPIO_160_STICKY+GPIO_160_PULLUP+GPIO_160_PULLDOWN, GPIO_160_SELECT}, - {GPIO_161_SELECT, GPIO_161_TYPE, GPO_161_LEVEL+GPIO_161_STICKY+GPIO_161_PULLUP+GPIO_161_PULLDOWN, GPIO_161_SELECT}, - {GPIO_162_SELECT, GPIO_162_TYPE, GPO_162_LEVEL+GPIO_162_STICKY+GPIO_162_PULLUP+GPIO_162_PULLDOWN, GPIO_162_SELECT}, - {GPIO_163_SELECT, GPIO_163_TYPE, GPO_163_LEVEL+GPIO_163_STICKY+GPIO_163_PULLUP+GPIO_163_PULLDOWN, GPIO_163_SELECT}, - {GPIO_164_SELECT, GPIO_164_TYPE, GPO_164_LEVEL+GPIO_164_STICKY+GPIO_164_PULLUP+GPIO_164_PULLDOWN, GPIO_164_SELECT}, - {GPIO_165_SELECT, GPIO_165_TYPE, GPO_165_LEVEL+GPIO_165_STICKY+GPIO_165_PULLUP+GPIO_165_PULLDOWN, GPIO_165_SELECT}, - {GPIO_166_SELECT, GPIO_166_TYPE, GPO_166_LEVEL+GPIO_166_STICKY+GPIO_166_PULLUP+GPIO_166_PULLDOWN, GPIO_166_SELECT}, - {GPIO_167_SELECT, GPIO_167_TYPE, GPO_167_LEVEL+GPIO_167_STICKY+GPIO_167_PULLUP+GPIO_167_PULLDOWN, GPIO_167_SELECT}, - {GPIO_168_SELECT, GPIO_168_TYPE, GPO_168_LEVEL+GPIO_168_STICKY+GPIO_168_PULLUP+GPIO_168_PULLDOWN, GPIO_168_SELECT}, - {GPIO_169_SELECT, GPIO_169_TYPE, GPO_169_LEVEL+GPIO_169_STICKY+GPIO_169_PULLUP+GPIO_169_PULLDOWN, GPIO_169_SELECT}, - {GPIO_170_SELECT, GPIO_170_TYPE, GPO_170_LEVEL+GPIO_170_STICKY+GPIO_170_PULLUP+GPIO_170_PULLDOWN, GPIO_170_SELECT}, - {GPIO_171_SELECT, GPIO_171_TYPE, GPO_171_LEVEL+GPIO_171_STICKY+GPIO_171_PULLUP+GPIO_171_PULLDOWN, GPIO_171_SELECT}, - {GPIO_172_SELECT, GPIO_172_TYPE, GPO_172_LEVEL+GPIO_172_STICKY+GPIO_172_PULLUP+GPIO_172_PULLDOWN, GPIO_172_SELECT}, - {GPIO_173_SELECT, GPIO_173_TYPE, GPO_173_LEVEL+GPIO_173_STICKY+GPIO_173_PULLUP+GPIO_173_PULLDOWN, GPIO_173_SELECT}, - {GPIO_174_SELECT, GPIO_174_TYPE, GPO_174_LEVEL+GPIO_174_STICKY+GPIO_174_PULLUP+GPIO_174_PULLDOWN, GPIO_174_SELECT}, - {GPIO_175_SELECT, GPIO_175_TYPE, GPO_175_LEVEL+GPIO_175_STICKY+GPIO_175_PULLUP+GPIO_175_PULLDOWN, GPIO_175_SELECT}, - {GPIO_176_SELECT, GPIO_176_TYPE, GPO_176_LEVEL+GPIO_176_STICKY+GPIO_176_PULLUP+GPIO_176_PULLDOWN, GPIO_176_SELECT}, - {GPIO_177_SELECT, GPIO_177_TYPE, GPO_177_LEVEL+GPIO_177_STICKY+GPIO_177_PULLUP+GPIO_177_PULLDOWN, GPIO_177_SELECT}, - {GPIO_178_SELECT, GPIO_178_TYPE, GPO_178_LEVEL+GPIO_178_STICKY+GPIO_178_PULLUP+GPIO_178_PULLDOWN, GPIO_178_SELECT}, - {GPIO_179_SELECT, GPIO_179_TYPE, GPO_179_LEVEL+GPIO_179_STICKY+GPIO_179_PULLUP+GPIO_179_PULLDOWN, GPIO_179_SELECT}, - {GPIO_180_SELECT, GPIO_180_TYPE, GPO_180_LEVEL+GPIO_180_STICKY+GPIO_180_PULLUP+GPIO_180_PULLDOWN, GPIO_180_SELECT}, - {GPIO_181_SELECT, GPIO_181_TYPE, GPO_181_LEVEL+GPIO_181_STICKY+GPIO_181_PULLUP+GPIO_181_PULLDOWN, GPIO_181_SELECT}, - {GPIO_182_SELECT, GPIO_182_TYPE, GPO_182_LEVEL+GPIO_182_STICKY+GPIO_182_PULLUP+GPIO_182_PULLDOWN, GPIO_182_SELECT}, - {GPIO_183_SELECT, GPIO_183_TYPE, GPO_183_LEVEL+GPIO_183_STICKY+GPIO_183_PULLUP+GPIO_183_PULLDOWN, GPIO_183_SELECT}, - {GPIO_184_SELECT, GPIO_184_TYPE, GPO_184_LEVEL+GPIO_184_STICKY+GPIO_184_PULLUP+GPIO_184_PULLDOWN, GPIO_184_SELECT}, - {GPIO_185_SELECT, GPIO_185_TYPE, GPO_185_LEVEL+GPIO_185_STICKY+GPIO_185_PULLUP+GPIO_185_PULLDOWN, GPIO_185_SELECT}, - {GPIO_186_SELECT, GPIO_186_TYPE, GPO_186_LEVEL+GPIO_186_STICKY+GPIO_186_PULLUP+GPIO_186_PULLDOWN, GPIO_186_SELECT}, - {GPIO_187_SELECT, GPIO_187_TYPE, GPO_187_LEVEL+GPIO_187_STICKY+GPIO_187_PULLUP+GPIO_187_PULLDOWN, GPIO_187_SELECT}, - {GPIO_188_SELECT, GPIO_188_TYPE, GPO_188_LEVEL+GPIO_188_STICKY+GPIO_188_PULLUP+GPIO_188_PULLDOWN, GPIO_188_SELECT}, - {GPIO_189_SELECT, GPIO_189_TYPE, GPO_189_LEVEL+GPIO_189_STICKY+GPIO_189_PULLUP+GPIO_189_PULLDOWN, GPIO_189_SELECT}, - {GPIO_190_SELECT, GPIO_190_TYPE, GPO_190_LEVEL+GPIO_190_STICKY+GPIO_190_PULLUP+GPIO_190_PULLDOWN, GPIO_190_SELECT}, - {GPIO_191_SELECT, GPIO_191_TYPE, GPO_191_LEVEL+GPIO_191_STICKY+GPIO_191_PULLUP+GPIO_191_PULLDOWN, GPIO_191_SELECT}, - {GPIO_192_SELECT, GPIO_192_TYPE, GPO_192_LEVEL+GPIO_192_STICKY+GPIO_192_PULLUP+GPIO_192_PULLDOWN, GPIO_192_SELECT}, - {GPIO_193_SELECT, GPIO_193_TYPE, GPO_193_LEVEL+GPIO_193_STICKY+GPIO_193_PULLUP+GPIO_193_PULLDOWN, GPIO_193_SELECT}, - {GPIO_194_SELECT, GPIO_194_TYPE, GPO_194_LEVEL+GPIO_194_STICKY+GPIO_194_PULLUP+GPIO_194_PULLDOWN, GPIO_194_SELECT}, - {GPIO_195_SELECT, GPIO_195_TYPE, GPO_195_LEVEL+GPIO_195_STICKY+GPIO_195_PULLUP+GPIO_195_PULLDOWN, GPIO_195_SELECT}, - {GPIO_196_SELECT, GPIO_196_TYPE, GPO_196_LEVEL+GPIO_196_STICKY+GPIO_196_PULLUP+GPIO_196_PULLDOWN, GPIO_196_SELECT}, - {GPIO_197_SELECT, GPIO_197_TYPE, GPO_197_LEVEL+GPIO_197_STICKY+GPIO_197_PULLUP+GPIO_197_PULLDOWN, GPIO_197_SELECT}, - {GPIO_198_SELECT, GPIO_198_TYPE, GPO_198_LEVEL+GPIO_198_STICKY+GPIO_198_PULLUP+GPIO_198_PULLDOWN, GPIO_198_SELECT}, - {GPIO_199_SELECT, GPIO_199_TYPE, GPO_199_LEVEL+GPIO_199_STICKY+GPIO_199_PULLUP+GPIO_199_PULLDOWN, GPIO_199_SELECT}, - {GPIO_200_SELECT, GPIO_200_TYPE, GPO_200_LEVEL+GPIO_200_STICKY+GPIO_200_PULLUP+GPIO_200_PULLDOWN, GPIO_200_SELECT}, - {GPIO_201_SELECT, GPIO_201_TYPE, GPO_201_LEVEL+GPIO_201_STICKY+GPIO_201_PULLUP+GPIO_201_PULLDOWN, GPIO_201_SELECT}, - {GPIO_202_SELECT, GPIO_202_TYPE, GPO_202_LEVEL+GPIO_202_STICKY+GPIO_202_PULLUP+GPIO_202_PULLDOWN, GPIO_202_SELECT}, - {GPIO_203_SELECT, GPIO_203_TYPE, GPO_203_LEVEL+GPIO_203_STICKY+GPIO_203_PULLUP+GPIO_203_PULLDOWN, GPIO_203_SELECT}, - {GPIO_204_SELECT, GPIO_204_TYPE, GPO_204_LEVEL+GPIO_204_STICKY+GPIO_204_PULLUP+GPIO_204_PULLDOWN, GPIO_204_SELECT}, - {GPIO_205_SELECT, GPIO_205_TYPE, GPO_205_LEVEL+GPIO_205_STICKY+GPIO_205_PULLUP+GPIO_205_PULLDOWN, GPIO_205_SELECT}, - {GPIO_206_SELECT, GPIO_206_TYPE, GPO_206_LEVEL+GPIO_206_STICKY+GPIO_206_PULLUP+GPIO_206_PULLDOWN, GPIO_206_SELECT}, - {GPIO_207_SELECT, GPIO_207_TYPE, GPO_207_LEVEL+GPIO_207_STICKY+GPIO_207_PULLUP+GPIO_207_PULLDOWN, GPIO_207_SELECT}, - {GPIO_208_SELECT, GPIO_208_TYPE, GPO_208_LEVEL+GPIO_208_STICKY+GPIO_208_PULLUP+GPIO_208_PULLDOWN, GPIO_208_SELECT}, - {GPIO_209_SELECT, GPIO_209_TYPE, GPO_209_LEVEL+GPIO_209_STICKY+GPIO_209_PULLUP+GPIO_209_PULLDOWN, GPIO_209_SELECT}, - {GPIO_210_SELECT, GPIO_210_TYPE, GPO_210_LEVEL+GPIO_210_STICKY+GPIO_210_PULLUP+GPIO_210_PULLDOWN, GPIO_210_SELECT}, - {GPIO_211_SELECT, GPIO_211_TYPE, GPO_211_LEVEL+GPIO_211_STICKY+GPIO_211_PULLUP+GPIO_211_PULLDOWN, GPIO_211_SELECT}, - {GPIO_212_SELECT, GPIO_212_TYPE, GPO_212_LEVEL+GPIO_212_STICKY+GPIO_212_PULLUP+GPIO_212_PULLDOWN, GPIO_212_SELECT}, - {GPIO_213_SELECT, GPIO_213_TYPE, GPO_213_LEVEL+GPIO_213_STICKY+GPIO_213_PULLUP+GPIO_213_PULLDOWN, GPIO_213_SELECT}, - {GPIO_214_SELECT, GPIO_214_TYPE, GPO_214_LEVEL+GPIO_214_STICKY+GPIO_214_PULLUP+GPIO_214_PULLDOWN, GPIO_214_SELECT}, - {GPIO_215_SELECT, GPIO_215_TYPE, GPO_215_LEVEL+GPIO_215_STICKY+GPIO_215_PULLUP+GPIO_215_PULLDOWN, GPIO_215_SELECT}, - {GPIO_216_SELECT, GPIO_216_TYPE, GPO_216_LEVEL+GPIO_216_STICKY+GPIO_216_PULLUP+GPIO_216_PULLDOWN, GPIO_216_SELECT}, - {GPIO_217_SELECT, GPIO_217_TYPE, GPO_217_LEVEL+GPIO_217_STICKY+GPIO_217_PULLUP+GPIO_217_PULLDOWN, GPIO_217_SELECT}, - {GPIO_218_SELECT, GPIO_218_TYPE, GPO_218_LEVEL+GPIO_218_STICKY+GPIO_218_PULLUP+GPIO_218_PULLDOWN, GPIO_218_SELECT}, - {GPIO_219_SELECT, GPIO_219_TYPE, GPO_219_LEVEL+GPIO_219_STICKY+GPIO_219_PULLUP+GPIO_219_PULLDOWN, GPIO_219_SELECT}, - {GPIO_220_SELECT, GPIO_220_TYPE, GPO_220_LEVEL+GPIO_220_STICKY+GPIO_220_PULLUP+GPIO_220_PULLDOWN, GPIO_220_SELECT}, - {GPIO_221_SELECT, GPIO_221_TYPE, GPO_221_LEVEL+GPIO_221_STICKY+GPIO_221_PULLUP+GPIO_221_PULLDOWN, GPIO_221_SELECT}, - {GPIO_222_SELECT, GPIO_222_TYPE, GPO_222_LEVEL+GPIO_222_STICKY+GPIO_222_PULLUP+GPIO_222_PULLDOWN, GPIO_222_SELECT}, - {GPIO_223_SELECT, GPIO_223_TYPE, GPO_223_LEVEL+GPIO_223_STICKY+GPIO_223_PULLUP+GPIO_223_PULLDOWN, GPIO_223_SELECT}, - {GPIO_224_SELECT, GPIO_224_TYPE, GPO_224_LEVEL+GPIO_224_STICKY+GPIO_224_PULLUP+GPIO_224_PULLDOWN, GPIO_224_SELECT}, - {GPIO_225_SELECT, GPIO_225_TYPE, GPO_225_LEVEL+GPIO_225_STICKY+GPIO_225_PULLUP+GPIO_225_PULLDOWN, GPIO_225_SELECT}, - {GPIO_226_SELECT, GPIO_226_TYPE, GPO_226_LEVEL+GPIO_226_STICKY+GPIO_226_PULLUP+GPIO_226_PULLDOWN, GPIO_226_SELECT}, - {GPIO_227_SELECT, GPIO_227_TYPE, GPO_227_LEVEL+GPIO_227_STICKY+GPIO_227_PULLUP+GPIO_227_PULLDOWN, GPIO_227_SELECT}, - {GPIO_228_SELECT, GPIO_228_TYPE, GPO_228_LEVEL+GPIO_228_STICKY+GPIO_228_PULLUP+GPIO_228_PULLDOWN, GPIO_228_SELECT}, - {GPIO_229_SELECT, GPIO_229_TYPE, GPO_229_LEVEL+GPIO_229_STICKY+GPIO_229_PULLUP+GPIO_229_PULLDOWN, GPIO_229_SELECT}, + {GPIO_00_SELECT, GPIO_00_TYPE, GPO_00_LEVEL+GPIO_00_STICKY+GPIO_00_PULLUP+GPIO_00_PULLDOWN, GPIO_00_SELECT}, + {GPIO_01_SELECT, GPIO_01_TYPE, GPO_01_LEVEL+GPIO_01_STICKY+GPIO_01_PULLUP+GPIO_01_PULLDOWN, GPIO_01_SELECT}, + {GPIO_02_SELECT, GPIO_02_TYPE, GPO_02_LEVEL+GPIO_02_STICKY+GPIO_02_PULLUP+GPIO_02_PULLDOWN, GPIO_02_SELECT}, + {GPIO_03_SELECT, GPIO_03_TYPE, GPO_03_LEVEL+GPIO_03_STICKY+GPIO_03_PULLUP+GPIO_03_PULLDOWN, GPIO_03_SELECT}, + {GPIO_04_SELECT, GPIO_04_TYPE, GPO_04_LEVEL+GPIO_04_STICKY+GPIO_04_PULLUP+GPIO_04_PULLDOWN, GPIO_04_SELECT}, + {GPIO_05_SELECT, GPIO_05_TYPE, GPO_05_LEVEL+GPIO_05_STICKY+GPIO_05_PULLUP+GPIO_05_PULLDOWN, GPIO_05_SELECT}, + {GPIO_06_SELECT, GPIO_06_TYPE, GPO_06_LEVEL+GPIO_06_STICKY+GPIO_06_PULLUP+GPIO_06_PULLDOWN, GPIO_06_SELECT}, + {GPIO_07_SELECT, GPIO_07_TYPE, GPO_07_LEVEL+GPIO_07_STICKY+GPIO_07_PULLUP+GPIO_07_PULLDOWN, GPIO_07_SELECT}, + {GPIO_08_SELECT, GPIO_08_TYPE, GPO_08_LEVEL+GPIO_08_STICKY+GPIO_08_PULLUP+GPIO_08_PULLDOWN, GPIO_08_SELECT}, + {GPIO_09_SELECT, GPIO_09_TYPE, GPO_09_LEVEL+GPIO_09_STICKY+GPIO_09_PULLUP+GPIO_09_PULLDOWN, GPIO_09_SELECT}, + {GPIO_10_SELECT, GPIO_10_TYPE, GPO_10_LEVEL+GPIO_10_STICKY+GPIO_10_PULLUP+GPIO_10_PULLDOWN, GPIO_10_SELECT}, + {GPIO_11_SELECT, GPIO_11_TYPE, GPO_11_LEVEL+GPIO_11_STICKY+GPIO_11_PULLUP+GPIO_11_PULLDOWN, GPIO_11_SELECT}, + {GPIO_12_SELECT, GPIO_12_TYPE, GPO_12_LEVEL+GPIO_12_STICKY+GPIO_12_PULLUP+GPIO_12_PULLDOWN, GPIO_12_SELECT}, + {GPIO_13_SELECT, GPIO_13_TYPE, GPO_13_LEVEL+GPIO_13_STICKY+GPIO_13_PULLUP+GPIO_13_PULLDOWN, GPIO_13_SELECT}, + {GPIO_14_SELECT, GPIO_14_TYPE, GPO_14_LEVEL+GPIO_14_STICKY+GPIO_14_PULLUP+GPIO_14_PULLDOWN, GPIO_14_SELECT}, + {GPIO_15_SELECT, GPIO_15_TYPE, GPO_15_LEVEL+GPIO_15_STICKY+GPIO_15_PULLUP+GPIO_15_PULLDOWN, GPIO_15_SELECT}, + {GPIO_16_SELECT, GPIO_16_TYPE, GPO_16_LEVEL+GPIO_16_STICKY+GPIO_16_PULLUP+GPIO_16_PULLDOWN, GPIO_16_SELECT}, + {GPIO_17_SELECT, GPIO_17_TYPE, GPO_17_LEVEL+GPIO_17_STICKY+GPIO_17_PULLUP+GPIO_17_PULLDOWN, GPIO_17_SELECT}, + {GPIO_18_SELECT, GPIO_18_TYPE, GPO_18_LEVEL+GPIO_18_STICKY+GPIO_18_PULLUP+GPIO_18_PULLDOWN, GPIO_18_SELECT}, + {GPIO_19_SELECT, GPIO_19_TYPE, GPO_19_LEVEL+GPIO_19_STICKY+GPIO_19_PULLUP+GPIO_19_PULLDOWN, GPIO_19_SELECT}, + {GPIO_20_SELECT, GPIO_20_TYPE, GPO_20_LEVEL+GPIO_20_STICKY+GPIO_20_PULLUP+GPIO_20_PULLDOWN, GPIO_20_SELECT}, + {GPIO_21_SELECT, GPIO_21_TYPE, GPO_21_LEVEL+GPIO_21_STICKY+GPIO_21_PULLUP+GPIO_21_PULLDOWN, GPIO_21_SELECT}, + {GPIO_22_SELECT, GPIO_22_TYPE, GPO_22_LEVEL+GPIO_22_STICKY+GPIO_22_PULLUP+GPIO_22_PULLDOWN, GPIO_22_SELECT}, + {GPIO_23_SELECT, GPIO_23_TYPE, GPO_23_LEVEL+GPIO_23_STICKY+GPIO_23_PULLUP+GPIO_23_PULLDOWN, GPIO_23_SELECT}, + {GPIO_24_SELECT, GPIO_24_TYPE, GPO_24_LEVEL+GPIO_24_STICKY+GPIO_24_PULLUP+GPIO_24_PULLDOWN, GPIO_24_SELECT}, + {GPIO_25_SELECT, GPIO_25_TYPE, GPO_25_LEVEL+GPIO_25_STICKY+GPIO_25_PULLUP+GPIO_25_PULLDOWN, GPIO_25_SELECT}, + {GPIO_26_SELECT, GPIO_26_TYPE, GPO_26_LEVEL+GPIO_26_STICKY+GPIO_26_PULLUP+GPIO_26_PULLDOWN, GPIO_26_SELECT}, + {GPIO_27_SELECT, GPIO_27_TYPE, GPO_27_LEVEL+GPIO_27_STICKY+GPIO_27_PULLUP+GPIO_27_PULLDOWN, GPIO_27_SELECT}, + {GPIO_28_SELECT, GPIO_28_TYPE, GPO_28_LEVEL+GPIO_28_STICKY+GPIO_28_PULLUP+GPIO_28_PULLDOWN, GPIO_28_SELECT}, + {GPIO_29_SELECT, GPIO_29_TYPE, GPO_29_LEVEL+GPIO_29_STICKY+GPIO_29_PULLUP+GPIO_29_PULLDOWN, GPIO_29_SELECT}, + {GPIO_30_SELECT, GPIO_30_TYPE, GPO_30_LEVEL+GPIO_30_STICKY+GPIO_30_PULLUP+GPIO_30_PULLDOWN, GPIO_30_SELECT}, + {GPIO_31_SELECT, GPIO_31_TYPE, GPO_31_LEVEL+GPIO_31_STICKY+GPIO_31_PULLUP+GPIO_31_PULLDOWN, GPIO_31_SELECT}, + {GPIO_32_SELECT, GPIO_32_TYPE, GPO_32_LEVEL+GPIO_32_STICKY+GPIO_32_PULLUP+GPIO_32_PULLDOWN, GPIO_32_SELECT}, + {GPIO_33_SELECT, GPIO_33_TYPE, GPO_33_LEVEL+GPIO_33_STICKY+GPIO_33_PULLUP+GPIO_33_PULLDOWN, GPIO_33_SELECT}, + {GPIO_34_SELECT, GPIO_34_TYPE, GPO_34_LEVEL+GPIO_34_STICKY+GPIO_34_PULLUP+GPIO_34_PULLDOWN, GPIO_34_SELECT}, + {GPIO_35_SELECT, GPIO_35_TYPE, GPO_35_LEVEL+GPIO_35_STICKY+GPIO_35_PULLUP+GPIO_35_PULLDOWN, GPIO_35_SELECT}, + {GPIO_36_SELECT, GPIO_36_TYPE, GPO_36_LEVEL+GPIO_36_STICKY+GPIO_36_PULLUP+GPIO_36_PULLDOWN, GPIO_36_SELECT}, + {GPIO_37_SELECT, GPIO_37_TYPE, GPO_37_LEVEL+GPIO_37_STICKY+GPIO_37_PULLUP+GPIO_37_PULLDOWN, GPIO_37_SELECT}, + {GPIO_38_SELECT, GPIO_38_TYPE, GPO_38_LEVEL+GPIO_38_STICKY+GPIO_38_PULLUP+GPIO_38_PULLDOWN, GPIO_38_SELECT}, + {GPIO_39_SELECT, GPIO_39_TYPE, GPO_39_LEVEL+GPIO_39_STICKY+GPIO_39_PULLUP+GPIO_39_PULLDOWN, GPIO_39_SELECT}, + {GPIO_40_SELECT, GPIO_40_TYPE, GPO_40_LEVEL+GPIO_40_STICKY+GPIO_40_PULLUP+GPIO_40_PULLDOWN, GPIO_40_SELECT}, + {GPIO_41_SELECT, GPIO_41_TYPE, GPO_41_LEVEL+GPIO_41_STICKY+GPIO_41_PULLUP+GPIO_41_PULLDOWN, GPIO_41_SELECT}, + {GPIO_42_SELECT, GPIO_42_TYPE, GPO_42_LEVEL+GPIO_42_STICKY+GPIO_42_PULLUP+GPIO_42_PULLDOWN, GPIO_42_SELECT}, + {GPIO_43_SELECT, GPIO_43_TYPE, GPO_43_LEVEL+GPIO_43_STICKY+GPIO_43_PULLUP+GPIO_43_PULLDOWN, GPIO_43_SELECT}, + {GPIO_44_SELECT, GPIO_44_TYPE, GPO_44_LEVEL+GPIO_44_STICKY+GPIO_44_PULLUP+GPIO_44_PULLDOWN, GPIO_44_SELECT}, + {GPIO_45_SELECT, GPIO_45_TYPE, GPO_45_LEVEL+GPIO_45_STICKY+GPIO_45_PULLUP+GPIO_45_PULLDOWN, GPIO_45_SELECT}, + {GPIO_46_SELECT, GPIO_46_TYPE, GPO_46_LEVEL+GPIO_46_STICKY+GPIO_46_PULLUP+GPIO_46_PULLDOWN, GPIO_46_SELECT}, + {GPIO_47_SELECT, GPIO_47_TYPE, GPO_47_LEVEL+GPIO_47_STICKY+GPIO_47_PULLUP+GPIO_47_PULLDOWN, GPIO_47_SELECT}, + {GPIO_48_SELECT, GPIO_48_TYPE, GPO_48_LEVEL+GPIO_48_STICKY+GPIO_48_PULLUP+GPIO_48_PULLDOWN, GPIO_48_SELECT}, + {GPIO_49_SELECT, GPIO_49_TYPE, GPO_49_LEVEL+GPIO_49_STICKY+GPIO_49_PULLUP+GPIO_49_PULLDOWN, GPIO_49_SELECT}, + {GPIO_50_SELECT, GPIO_50_TYPE, GPO_50_LEVEL+GPIO_50_STICKY+GPIO_50_PULLUP+GPIO_50_PULLDOWN, GPIO_50_SELECT}, + {GPIO_51_SELECT, GPIO_51_TYPE, GPO_51_LEVEL+GPIO_51_STICKY+GPIO_51_PULLUP+GPIO_51_PULLDOWN, GPIO_51_SELECT}, + {GPIO_52_SELECT, GPIO_52_TYPE, GPO_52_LEVEL+GPIO_52_STICKY+GPIO_52_PULLUP+GPIO_52_PULLDOWN, GPIO_52_SELECT}, + {GPIO_53_SELECT, GPIO_53_TYPE, GPO_53_LEVEL+GPIO_53_STICKY+GPIO_53_PULLUP+GPIO_53_PULLDOWN, GPIO_53_SELECT}, + {GPIO_54_SELECT, GPIO_54_TYPE, GPO_54_LEVEL+GPIO_54_STICKY+GPIO_54_PULLUP+GPIO_54_PULLDOWN, GPIO_54_SELECT}, + {GPIO_55_SELECT, GPIO_55_TYPE, GPO_55_LEVEL+GPIO_55_STICKY+GPIO_55_PULLUP+GPIO_55_PULLDOWN, GPIO_55_SELECT}, + {GPIO_56_SELECT, GPIO_56_TYPE, GPO_56_LEVEL+GPIO_56_STICKY+GPIO_56_PULLUP+GPIO_56_PULLDOWN, GPIO_56_SELECT}, + {GPIO_57_SELECT, GPIO_57_TYPE, GPO_57_LEVEL+GPIO_57_STICKY+GPIO_57_PULLUP+GPIO_57_PULLDOWN, GPIO_57_SELECT}, + {GPIO_58_SELECT, GPIO_58_TYPE, GPO_58_LEVEL+GPIO_58_STICKY+GPIO_58_PULLUP+GPIO_58_PULLDOWN, GPIO_58_SELECT}, + {GPIO_59_SELECT, GPIO_59_TYPE, GPO_59_LEVEL+GPIO_59_STICKY+GPIO_59_PULLUP+GPIO_59_PULLDOWN, GPIO_59_SELECT}, + {GPIO_60_SELECT, GPIO_60_TYPE, GPO_60_LEVEL+GPIO_60_STICKY+GPIO_60_PULLUP+GPIO_60_PULLDOWN, GPIO_60_SELECT}, + {GPIO_61_SELECT, GPIO_61_TYPE, GPO_61_LEVEL+GPIO_61_STICKY+GPIO_61_PULLUP+GPIO_61_PULLDOWN, GPIO_61_SELECT}, + {GPIO_62_SELECT, GPIO_62_TYPE, GPO_62_LEVEL+GPIO_62_STICKY+GPIO_62_PULLUP+GPIO_62_PULLDOWN, GPIO_62_SELECT}, + {GPIO_63_SELECT, GPIO_63_TYPE, GPO_63_LEVEL+GPIO_63_STICKY+GPIO_63_PULLUP+GPIO_63_PULLDOWN, GPIO_63_SELECT}, + {GPIO_64_SELECT, GPIO_64_TYPE, GPO_64_LEVEL+GPIO_64_STICKY+GPIO_64_PULLUP+GPIO_64_PULLDOWN, GPIO_64_SELECT}, + {GPIO_65_SELECT, GPIO_65_TYPE, GPO_65_LEVEL+GPIO_65_STICKY+GPIO_65_PULLUP+GPIO_65_PULLDOWN, GPIO_65_SELECT}, + {GPIO_66_SELECT, GPIO_66_TYPE, GPO_66_LEVEL+GPIO_66_STICKY+GPIO_66_PULLUP+GPIO_66_PULLDOWN, GPIO_66_SELECT}, + {GPIO_67_SELECT, GPIO_67_TYPE, GPO_67_LEVEL+GPIO_67_STICKY+GPIO_67_PULLUP+GPIO_67_PULLDOWN, GPIO_67_SELECT}, + {GPIO_68_SELECT, GPIO_68_TYPE, GPO_68_LEVEL+GPIO_68_STICKY+GPIO_68_PULLUP+GPIO_68_PULLDOWN, GPIO_68_SELECT}, + {GPIO_69_SELECT, GPIO_69_TYPE, GPO_69_LEVEL+GPIO_69_STICKY+GPIO_69_PULLUP+GPIO_69_PULLDOWN, GPIO_69_SELECT}, + {GPIO_70_SELECT, GPIO_70_TYPE, GPO_70_LEVEL+GPIO_70_STICKY+GPIO_70_PULLUP+GPIO_70_PULLDOWN, GPIO_70_SELECT}, + {GPIO_71_SELECT, GPIO_71_TYPE, GPO_71_LEVEL+GPIO_71_STICKY+GPIO_71_PULLUP+GPIO_71_PULLDOWN, GPIO_71_SELECT}, + {GPIO_72_SELECT, GPIO_72_TYPE, GPO_72_LEVEL+GPIO_72_STICKY+GPIO_72_PULLUP+GPIO_72_PULLDOWN, GPIO_72_SELECT}, + {GPIO_73_SELECT, GPIO_73_TYPE, GPO_73_LEVEL+GPIO_73_STICKY+GPIO_73_PULLUP+GPIO_73_PULLDOWN, GPIO_73_SELECT}, + {GPIO_74_SELECT, GPIO_74_TYPE, GPO_74_LEVEL+GPIO_74_STICKY+GPIO_74_PULLUP+GPIO_74_PULLDOWN, GPIO_74_SELECT}, + {GPIO_75_SELECT, GPIO_75_TYPE, GPO_75_LEVEL+GPIO_75_STICKY+GPIO_75_PULLUP+GPIO_75_PULLDOWN, GPIO_75_SELECT}, + {GPIO_76_SELECT, GPIO_76_TYPE, GPO_76_LEVEL+GPIO_76_STICKY+GPIO_76_PULLUP+GPIO_76_PULLDOWN, GPIO_76_SELECT}, + {GPIO_77_SELECT, GPIO_77_TYPE, GPO_77_LEVEL+GPIO_77_STICKY+GPIO_77_PULLUP+GPIO_77_PULLDOWN, GPIO_77_SELECT}, + {GPIO_78_SELECT, GPIO_78_TYPE, GPO_78_LEVEL+GPIO_78_STICKY+GPIO_78_PULLUP+GPIO_78_PULLDOWN, GPIO_78_SELECT}, + {GPIO_79_SELECT, GPIO_79_TYPE, GPO_79_LEVEL+GPIO_79_STICKY+GPIO_79_PULLUP+GPIO_79_PULLDOWN, GPIO_79_SELECT}, + {GPIO_80_SELECT, GPIO_80_TYPE, GPO_80_LEVEL+GPIO_80_STICKY+GPIO_80_PULLUP+GPIO_80_PULLDOWN, GPIO_80_SELECT}, + {GPIO_81_SELECT, GPIO_81_TYPE, GPO_81_LEVEL+GPIO_81_STICKY+GPIO_81_PULLUP+GPIO_81_PULLDOWN, GPIO_81_SELECT}, + {GPIO_82_SELECT, GPIO_82_TYPE, GPO_82_LEVEL+GPIO_82_STICKY+GPIO_82_PULLUP+GPIO_82_PULLDOWN, GPIO_82_SELECT}, + {GPIO_83_SELECT, GPIO_83_TYPE, GPO_83_LEVEL+GPIO_83_STICKY+GPIO_83_PULLUP+GPIO_83_PULLDOWN, GPIO_83_SELECT}, + {GPIO_84_SELECT, GPIO_84_TYPE, GPO_84_LEVEL+GPIO_84_STICKY+GPIO_84_PULLUP+GPIO_84_PULLDOWN, GPIO_84_SELECT}, + {GPIO_85_SELECT, GPIO_85_TYPE, GPO_85_LEVEL+GPIO_85_STICKY+GPIO_85_PULLUP+GPIO_85_PULLDOWN, GPIO_85_SELECT}, + {GPIO_86_SELECT, GPIO_86_TYPE, GPO_86_LEVEL+GPIO_86_STICKY+GPIO_86_PULLUP+GPIO_86_PULLDOWN, GPIO_86_SELECT}, + {GPIO_87_SELECT, GPIO_87_TYPE, GPO_87_LEVEL+GPIO_87_STICKY+GPIO_87_PULLUP+GPIO_87_PULLDOWN, GPIO_87_SELECT}, + {GPIO_88_SELECT, GPIO_88_TYPE, GPO_88_LEVEL+GPIO_88_STICKY+GPIO_88_PULLUP+GPIO_88_PULLDOWN, GPIO_88_SELECT}, + {GPIO_89_SELECT, GPIO_89_TYPE, GPO_89_LEVEL+GPIO_89_STICKY+GPIO_89_PULLUP+GPIO_89_PULLDOWN, GPIO_89_SELECT}, + {GPIO_90_SELECT, GPIO_90_TYPE, GPO_90_LEVEL+GPIO_90_STICKY+GPIO_90_PULLUP+GPIO_90_PULLDOWN, GPIO_90_SELECT}, + {GPIO_91_SELECT, GPIO_91_TYPE, GPO_91_LEVEL+GPIO_91_STICKY+GPIO_91_PULLUP+GPIO_91_PULLDOWN, GPIO_91_SELECT}, + {GPIO_92_SELECT, GPIO_92_TYPE, GPO_92_LEVEL+GPIO_92_STICKY+GPIO_92_PULLUP+GPIO_92_PULLDOWN, GPIO_92_SELECT}, + {GPIO_93_SELECT, GPIO_93_TYPE, GPO_93_LEVEL+GPIO_93_STICKY+GPIO_93_PULLUP+GPIO_93_PULLDOWN, GPIO_93_SELECT}, + {GPIO_94_SELECT, GPIO_94_TYPE, GPO_94_LEVEL+GPIO_94_STICKY+GPIO_94_PULLUP+GPIO_94_PULLDOWN, GPIO_94_SELECT}, + {GPIO_95_SELECT, GPIO_95_TYPE, GPO_95_LEVEL+GPIO_95_STICKY+GPIO_95_PULLUP+GPIO_95_PULLDOWN, GPIO_95_SELECT}, + {GPIO_96_SELECT, GPIO_96_TYPE, GPO_96_LEVEL+GPIO_96_STICKY+GPIO_96_PULLUP+GPIO_96_PULLDOWN, GPIO_96_SELECT}, + {GPIO_97_SELECT, GPIO_97_TYPE, GPO_97_LEVEL+GPIO_97_STICKY+GPIO_97_PULLUP+GPIO_97_PULLDOWN, GPIO_97_SELECT}, + {GPIO_98_SELECT, GPIO_98_TYPE, GPO_98_LEVEL+GPIO_98_STICKY+GPIO_98_PULLUP+GPIO_98_PULLDOWN, GPIO_98_SELECT}, + {GPIO_99_SELECT, GPIO_99_TYPE, GPO_99_LEVEL+GPIO_99_STICKY+GPIO_99_PULLUP+GPIO_99_PULLDOWN, GPIO_99_SELECT}, + {GPIO_100_SELECT, GPIO_100_TYPE, GPO_100_LEVEL+GPIO_100_STICKY+GPIO_100_PULLUP+GPIO_100_PULLDOWN, GPIO_100_SELECT}, + {GPIO_101_SELECT, GPIO_101_TYPE, GPO_101_LEVEL+GPIO_101_STICKY+GPIO_101_PULLUP+GPIO_101_PULLDOWN, GPIO_101_SELECT}, + {GPIO_102_SELECT, GPIO_102_TYPE, GPO_102_LEVEL+GPIO_102_STICKY+GPIO_102_PULLUP+GPIO_102_PULLDOWN, GPIO_102_SELECT}, + {GPIO_103_SELECT, GPIO_103_TYPE, GPO_103_LEVEL+GPIO_103_STICKY+GPIO_103_PULLUP+GPIO_103_PULLDOWN, GPIO_103_SELECT}, + {GPIO_104_SELECT, GPIO_104_TYPE, GPO_104_LEVEL+GPIO_104_STICKY+GPIO_104_PULLUP+GPIO_104_PULLDOWN, GPIO_104_SELECT}, + {GPIO_105_SELECT, GPIO_105_TYPE, GPO_105_LEVEL+GPIO_105_STICKY+GPIO_105_PULLUP+GPIO_105_PULLDOWN, GPIO_105_SELECT}, + {GPIO_106_SELECT, GPIO_106_TYPE, GPO_106_LEVEL+GPIO_106_STICKY+GPIO_106_PULLUP+GPIO_106_PULLDOWN, GPIO_106_SELECT}, + {GPIO_107_SELECT, GPIO_107_TYPE, GPO_107_LEVEL+GPIO_107_STICKY+GPIO_107_PULLUP+GPIO_107_PULLDOWN, GPIO_107_SELECT}, + {GPIO_108_SELECT, GPIO_108_TYPE, GPO_108_LEVEL+GPIO_108_STICKY+GPIO_108_PULLUP+GPIO_108_PULLDOWN, GPIO_108_SELECT}, + {GPIO_109_SELECT, GPIO_109_TYPE, GPO_109_LEVEL+GPIO_109_STICKY+GPIO_109_PULLUP+GPIO_109_PULLDOWN, GPIO_109_SELECT}, + {GPIO_110_SELECT, GPIO_110_TYPE, GPO_110_LEVEL+GPIO_110_STICKY+GPIO_110_PULLUP+GPIO_110_PULLDOWN, GPIO_110_SELECT}, + {GPIO_111_SELECT, GPIO_111_TYPE, GPO_111_LEVEL+GPIO_111_STICKY+GPIO_111_PULLUP+GPIO_111_PULLDOWN, GPIO_111_SELECT}, + {GPIO_112_SELECT, GPIO_112_TYPE, GPO_112_LEVEL+GPIO_112_STICKY+GPIO_112_PULLUP+GPIO_112_PULLDOWN, GPIO_112_SELECT}, + {GPIO_113_SELECT, GPIO_113_TYPE, GPO_113_LEVEL+GPIO_113_STICKY+GPIO_113_PULLUP+GPIO_113_PULLDOWN, GPIO_113_SELECT}, + {GPIO_114_SELECT, GPIO_114_TYPE, GPO_114_LEVEL+GPIO_114_STICKY+GPIO_114_PULLUP+GPIO_114_PULLDOWN, GPIO_114_SELECT}, + {GPIO_115_SELECT, GPIO_115_TYPE, GPO_115_LEVEL+GPIO_115_STICKY+GPIO_115_PULLUP+GPIO_115_PULLDOWN, GPIO_115_SELECT}, + {GPIO_116_SELECT, GPIO_116_TYPE, GPO_116_LEVEL+GPIO_116_STICKY+GPIO_116_PULLUP+GPIO_116_PULLDOWN, GPIO_116_SELECT}, + {GPIO_117_SELECT, GPIO_117_TYPE, GPO_117_LEVEL+GPIO_117_STICKY+GPIO_117_PULLUP+GPIO_117_PULLDOWN, GPIO_117_SELECT}, + {GPIO_118_SELECT, GPIO_118_TYPE, GPO_118_LEVEL+GPIO_118_STICKY+GPIO_118_PULLUP+GPIO_118_PULLDOWN, GPIO_118_SELECT}, + {GPIO_119_SELECT, GPIO_119_TYPE, GPO_119_LEVEL+GPIO_119_STICKY+GPIO_119_PULLUP+GPIO_119_PULLDOWN, GPIO_119_SELECT}, + {GPIO_120_SELECT, GPIO_120_TYPE, GPO_120_LEVEL+GPIO_120_STICKY+GPIO_120_PULLUP+GPIO_120_PULLDOWN, GPIO_120_SELECT}, + {GPIO_121_SELECT, GPIO_121_TYPE, GPO_121_LEVEL+GPIO_121_STICKY+GPIO_121_PULLUP+GPIO_121_PULLDOWN, GPIO_121_SELECT}, + {GPIO_122_SELECT, GPIO_122_TYPE, GPO_122_LEVEL+GPIO_122_STICKY+GPIO_122_PULLUP+GPIO_122_PULLDOWN, GPIO_122_SELECT}, + {GPIO_123_SELECT, GPIO_123_TYPE, GPO_123_LEVEL+GPIO_123_STICKY+GPIO_123_PULLUP+GPIO_123_PULLDOWN, GPIO_123_SELECT}, + {GPIO_124_SELECT, GPIO_124_TYPE, GPO_124_LEVEL+GPIO_124_STICKY+GPIO_124_PULLUP+GPIO_124_PULLDOWN, GPIO_124_SELECT}, + {GPIO_125_SELECT, GPIO_125_TYPE, GPO_125_LEVEL+GPIO_125_STICKY+GPIO_125_PULLUP+GPIO_125_PULLDOWN, GPIO_125_SELECT}, + {GPIO_126_SELECT, GPIO_126_TYPE, GPO_126_LEVEL+GPIO_126_STICKY+GPIO_126_PULLUP+GPIO_126_PULLDOWN, GPIO_126_SELECT}, + {GPIO_127_SELECT, GPIO_127_TYPE, GPO_127_LEVEL+GPIO_127_STICKY+GPIO_127_PULLUP+GPIO_127_PULLDOWN, GPIO_127_SELECT}, + {GPIO_128_SELECT, GPIO_128_TYPE, GPO_128_LEVEL+GPIO_128_STICKY+GPIO_128_PULLUP+GPIO_128_PULLDOWN, GPIO_128_SELECT}, + {GPIO_129_SELECT, GPIO_129_TYPE, GPO_129_LEVEL+GPIO_129_STICKY+GPIO_129_PULLUP+GPIO_129_PULLDOWN, GPIO_129_SELECT}, + {GPIO_130_SELECT, GPIO_130_TYPE, GPO_130_LEVEL+GPIO_130_STICKY+GPIO_130_PULLUP+GPIO_130_PULLDOWN, GPIO_130_SELECT}, + {GPIO_131_SELECT, GPIO_131_TYPE, GPO_131_LEVEL+GPIO_131_STICKY+GPIO_131_PULLUP+GPIO_131_PULLDOWN, GPIO_131_SELECT}, + {GPIO_132_SELECT, GPIO_132_TYPE, GPO_132_LEVEL+GPIO_132_STICKY+GPIO_132_PULLUP+GPIO_132_PULLDOWN, GPIO_132_SELECT}, + {GPIO_133_SELECT, GPIO_133_TYPE, GPO_133_LEVEL+GPIO_133_STICKY+GPIO_133_PULLUP+GPIO_133_PULLDOWN, GPIO_133_SELECT}, + {GPIO_134_SELECT, GPIO_134_TYPE, GPO_134_LEVEL+GPIO_134_STICKY+GPIO_134_PULLUP+GPIO_134_PULLDOWN, GPIO_134_SELECT}, + {GPIO_135_SELECT, GPIO_135_TYPE, GPO_135_LEVEL+GPIO_135_STICKY+GPIO_135_PULLUP+GPIO_135_PULLDOWN, GPIO_135_SELECT}, + {GPIO_136_SELECT, GPIO_136_TYPE, GPO_136_LEVEL+GPIO_136_STICKY+GPIO_136_PULLUP+GPIO_136_PULLDOWN, GPIO_136_SELECT}, + {GPIO_137_SELECT, GPIO_137_TYPE, GPO_137_LEVEL+GPIO_137_STICKY+GPIO_137_PULLUP+GPIO_137_PULLDOWN, GPIO_137_SELECT}, + {GPIO_138_SELECT, GPIO_138_TYPE, GPO_138_LEVEL+GPIO_138_STICKY+GPIO_138_PULLUP+GPIO_138_PULLDOWN, GPIO_138_SELECT}, + {GPIO_139_SELECT, GPIO_139_TYPE, GPO_139_LEVEL+GPIO_139_STICKY+GPIO_139_PULLUP+GPIO_139_PULLDOWN, GPIO_139_SELECT}, + {GPIO_140_SELECT, GPIO_140_TYPE, GPO_140_LEVEL+GPIO_140_STICKY+GPIO_140_PULLUP+GPIO_140_PULLDOWN, GPIO_140_SELECT}, + {GPIO_141_SELECT, GPIO_141_TYPE, GPO_141_LEVEL+GPIO_141_STICKY+GPIO_141_PULLUP+GPIO_141_PULLDOWN, GPIO_141_SELECT}, + {GPIO_142_SELECT, GPIO_142_TYPE, GPO_142_LEVEL+GPIO_142_STICKY+GPIO_142_PULLUP+GPIO_142_PULLDOWN, GPIO_142_SELECT}, + {GPIO_143_SELECT, GPIO_143_TYPE, GPO_143_LEVEL+GPIO_143_STICKY+GPIO_143_PULLUP+GPIO_143_PULLDOWN, GPIO_143_SELECT}, + {GPIO_144_SELECT, GPIO_144_TYPE, GPO_144_LEVEL+GPIO_144_STICKY+GPIO_144_PULLUP+GPIO_144_PULLDOWN, GPIO_144_SELECT}, + {GPIO_145_SELECT, GPIO_145_TYPE, GPO_145_LEVEL+GPIO_145_STICKY+GPIO_145_PULLUP+GPIO_145_PULLDOWN, GPIO_145_SELECT}, + {GPIO_146_SELECT, GPIO_146_TYPE, GPO_146_LEVEL+GPIO_146_STICKY+GPIO_146_PULLUP+GPIO_146_PULLDOWN, GPIO_146_SELECT}, + {GPIO_147_SELECT, GPIO_147_TYPE, GPO_147_LEVEL+GPIO_147_STICKY+GPIO_147_PULLUP+GPIO_147_PULLDOWN, GPIO_147_SELECT}, + {GPIO_148_SELECT, GPIO_148_TYPE, GPO_148_LEVEL+GPIO_148_STICKY+GPIO_148_PULLUP+GPIO_148_PULLDOWN, GPIO_148_SELECT}, + {GPIO_149_SELECT, GPIO_149_TYPE, GPO_149_LEVEL+GPIO_149_STICKY+GPIO_149_PULLUP+GPIO_149_PULLDOWN, GPIO_149_SELECT}, + {GPIO_150_SELECT, GPIO_150_TYPE, GPO_150_LEVEL+GPIO_150_STICKY+GPIO_150_PULLUP+GPIO_150_PULLDOWN, GPIO_150_SELECT}, + {GPIO_151_SELECT, GPIO_151_TYPE, GPO_151_LEVEL+GPIO_151_STICKY+GPIO_151_PULLUP+GPIO_151_PULLDOWN, GPIO_151_SELECT}, + {GPIO_152_SELECT, GPIO_152_TYPE, GPO_152_LEVEL+GPIO_152_STICKY+GPIO_152_PULLUP+GPIO_152_PULLDOWN, GPIO_152_SELECT}, + {GPIO_153_SELECT, GPIO_153_TYPE, GPO_153_LEVEL+GPIO_153_STICKY+GPIO_153_PULLUP+GPIO_153_PULLDOWN, GPIO_153_SELECT}, + {GPIO_154_SELECT, GPIO_154_TYPE, GPO_154_LEVEL+GPIO_154_STICKY+GPIO_154_PULLUP+GPIO_154_PULLDOWN, GPIO_154_SELECT}, + {GPIO_155_SELECT, GPIO_155_TYPE, GPO_155_LEVEL+GPIO_155_STICKY+GPIO_155_PULLUP+GPIO_155_PULLDOWN, GPIO_155_SELECT}, + {GPIO_156_SELECT, GPIO_156_TYPE, GPO_156_LEVEL+GPIO_156_STICKY+GPIO_156_PULLUP+GPIO_156_PULLDOWN, GPIO_156_SELECT}, + {GPIO_157_SELECT, GPIO_157_TYPE, GPO_157_LEVEL+GPIO_157_STICKY+GPIO_157_PULLUP+GPIO_157_PULLDOWN, GPIO_157_SELECT}, + {GPIO_158_SELECT, GPIO_158_TYPE, GPO_158_LEVEL+GPIO_158_STICKY+GPIO_158_PULLUP+GPIO_158_PULLDOWN, GPIO_158_SELECT}, + {GPIO_159_SELECT, GPIO_159_TYPE, GPO_159_LEVEL+GPIO_159_STICKY+GPIO_159_PULLUP+GPIO_159_PULLDOWN, GPIO_159_SELECT}, + {GPIO_160_SELECT, GPIO_160_TYPE, GPO_160_LEVEL+GPIO_160_STICKY+GPIO_160_PULLUP+GPIO_160_PULLDOWN, GPIO_160_SELECT}, + {GPIO_161_SELECT, GPIO_161_TYPE, GPO_161_LEVEL+GPIO_161_STICKY+GPIO_161_PULLUP+GPIO_161_PULLDOWN, GPIO_161_SELECT}, + {GPIO_162_SELECT, GPIO_162_TYPE, GPO_162_LEVEL+GPIO_162_STICKY+GPIO_162_PULLUP+GPIO_162_PULLDOWN, GPIO_162_SELECT}, + {GPIO_163_SELECT, GPIO_163_TYPE, GPO_163_LEVEL+GPIO_163_STICKY+GPIO_163_PULLUP+GPIO_163_PULLDOWN, GPIO_163_SELECT}, + {GPIO_164_SELECT, GPIO_164_TYPE, GPO_164_LEVEL+GPIO_164_STICKY+GPIO_164_PULLUP+GPIO_164_PULLDOWN, GPIO_164_SELECT}, + {GPIO_165_SELECT, GPIO_165_TYPE, GPO_165_LEVEL+GPIO_165_STICKY+GPIO_165_PULLUP+GPIO_165_PULLDOWN, GPIO_165_SELECT}, + {GPIO_166_SELECT, GPIO_166_TYPE, GPO_166_LEVEL+GPIO_166_STICKY+GPIO_166_PULLUP+GPIO_166_PULLDOWN, GPIO_166_SELECT}, + {GPIO_167_SELECT, GPIO_167_TYPE, GPO_167_LEVEL+GPIO_167_STICKY+GPIO_167_PULLUP+GPIO_167_PULLDOWN, GPIO_167_SELECT}, + {GPIO_168_SELECT, GPIO_168_TYPE, GPO_168_LEVEL+GPIO_168_STICKY+GPIO_168_PULLUP+GPIO_168_PULLDOWN, GPIO_168_SELECT}, + {GPIO_169_SELECT, GPIO_169_TYPE, GPO_169_LEVEL+GPIO_169_STICKY+GPIO_169_PULLUP+GPIO_169_PULLDOWN, GPIO_169_SELECT}, + {GPIO_170_SELECT, GPIO_170_TYPE, GPO_170_LEVEL+GPIO_170_STICKY+GPIO_170_PULLUP+GPIO_170_PULLDOWN, GPIO_170_SELECT}, + {GPIO_171_SELECT, GPIO_171_TYPE, GPO_171_LEVEL+GPIO_171_STICKY+GPIO_171_PULLUP+GPIO_171_PULLDOWN, GPIO_171_SELECT}, + {GPIO_172_SELECT, GPIO_172_TYPE, GPO_172_LEVEL+GPIO_172_STICKY+GPIO_172_PULLUP+GPIO_172_PULLDOWN, GPIO_172_SELECT}, + {GPIO_173_SELECT, GPIO_173_TYPE, GPO_173_LEVEL+GPIO_173_STICKY+GPIO_173_PULLUP+GPIO_173_PULLDOWN, GPIO_173_SELECT}, + {GPIO_174_SELECT, GPIO_174_TYPE, GPO_174_LEVEL+GPIO_174_STICKY+GPIO_174_PULLUP+GPIO_174_PULLDOWN, GPIO_174_SELECT}, + {GPIO_175_SELECT, GPIO_175_TYPE, GPO_175_LEVEL+GPIO_175_STICKY+GPIO_175_PULLUP+GPIO_175_PULLDOWN, GPIO_175_SELECT}, + {GPIO_176_SELECT, GPIO_176_TYPE, GPO_176_LEVEL+GPIO_176_STICKY+GPIO_176_PULLUP+GPIO_176_PULLDOWN, GPIO_176_SELECT}, + {GPIO_177_SELECT, GPIO_177_TYPE, GPO_177_LEVEL+GPIO_177_STICKY+GPIO_177_PULLUP+GPIO_177_PULLDOWN, GPIO_177_SELECT}, + {GPIO_178_SELECT, GPIO_178_TYPE, GPO_178_LEVEL+GPIO_178_STICKY+GPIO_178_PULLUP+GPIO_178_PULLDOWN, GPIO_178_SELECT}, + {GPIO_179_SELECT, GPIO_179_TYPE, GPO_179_LEVEL+GPIO_179_STICKY+GPIO_179_PULLUP+GPIO_179_PULLDOWN, GPIO_179_SELECT}, + {GPIO_180_SELECT, GPIO_180_TYPE, GPO_180_LEVEL+GPIO_180_STICKY+GPIO_180_PULLUP+GPIO_180_PULLDOWN, GPIO_180_SELECT}, + {GPIO_181_SELECT, GPIO_181_TYPE, GPO_181_LEVEL+GPIO_181_STICKY+GPIO_181_PULLUP+GPIO_181_PULLDOWN, GPIO_181_SELECT}, + {GPIO_182_SELECT, GPIO_182_TYPE, GPO_182_LEVEL+GPIO_182_STICKY+GPIO_182_PULLUP+GPIO_182_PULLDOWN, GPIO_182_SELECT}, + {GPIO_183_SELECT, GPIO_183_TYPE, GPO_183_LEVEL+GPIO_183_STICKY+GPIO_183_PULLUP+GPIO_183_PULLDOWN, GPIO_183_SELECT}, + {GPIO_184_SELECT, GPIO_184_TYPE, GPO_184_LEVEL+GPIO_184_STICKY+GPIO_184_PULLUP+GPIO_184_PULLDOWN, GPIO_184_SELECT}, + {GPIO_185_SELECT, GPIO_185_TYPE, GPO_185_LEVEL+GPIO_185_STICKY+GPIO_185_PULLUP+GPIO_185_PULLDOWN, GPIO_185_SELECT}, + {GPIO_186_SELECT, GPIO_186_TYPE, GPO_186_LEVEL+GPIO_186_STICKY+GPIO_186_PULLUP+GPIO_186_PULLDOWN, GPIO_186_SELECT}, + {GPIO_187_SELECT, GPIO_187_TYPE, GPO_187_LEVEL+GPIO_187_STICKY+GPIO_187_PULLUP+GPIO_187_PULLDOWN, GPIO_187_SELECT}, + {GPIO_188_SELECT, GPIO_188_TYPE, GPO_188_LEVEL+GPIO_188_STICKY+GPIO_188_PULLUP+GPIO_188_PULLDOWN, GPIO_188_SELECT}, + {GPIO_189_SELECT, GPIO_189_TYPE, GPO_189_LEVEL+GPIO_189_STICKY+GPIO_189_PULLUP+GPIO_189_PULLDOWN, GPIO_189_SELECT}, + {GPIO_190_SELECT, GPIO_190_TYPE, GPO_190_LEVEL+GPIO_190_STICKY+GPIO_190_PULLUP+GPIO_190_PULLDOWN, GPIO_190_SELECT}, + {GPIO_191_SELECT, GPIO_191_TYPE, GPO_191_LEVEL+GPIO_191_STICKY+GPIO_191_PULLUP+GPIO_191_PULLDOWN, GPIO_191_SELECT}, + {GPIO_192_SELECT, GPIO_192_TYPE, GPO_192_LEVEL+GPIO_192_STICKY+GPIO_192_PULLUP+GPIO_192_PULLDOWN, GPIO_192_SELECT}, + {GPIO_193_SELECT, GPIO_193_TYPE, GPO_193_LEVEL+GPIO_193_STICKY+GPIO_193_PULLUP+GPIO_193_PULLDOWN, GPIO_193_SELECT}, + {GPIO_194_SELECT, GPIO_194_TYPE, GPO_194_LEVEL+GPIO_194_STICKY+GPIO_194_PULLUP+GPIO_194_PULLDOWN, GPIO_194_SELECT}, + {GPIO_195_SELECT, GPIO_195_TYPE, GPO_195_LEVEL+GPIO_195_STICKY+GPIO_195_PULLUP+GPIO_195_PULLDOWN, GPIO_195_SELECT}, + {GPIO_196_SELECT, GPIO_196_TYPE, GPO_196_LEVEL+GPIO_196_STICKY+GPIO_196_PULLUP+GPIO_196_PULLDOWN, GPIO_196_SELECT}, + {GPIO_197_SELECT, GPIO_197_TYPE, GPO_197_LEVEL+GPIO_197_STICKY+GPIO_197_PULLUP+GPIO_197_PULLDOWN, GPIO_197_SELECT}, + {GPIO_198_SELECT, GPIO_198_TYPE, GPO_198_LEVEL+GPIO_198_STICKY+GPIO_198_PULLUP+GPIO_198_PULLDOWN, GPIO_198_SELECT}, + {GPIO_199_SELECT, GPIO_199_TYPE, GPO_199_LEVEL+GPIO_199_STICKY+GPIO_199_PULLUP+GPIO_199_PULLDOWN, GPIO_199_SELECT}, + {GPIO_200_SELECT, GPIO_200_TYPE, GPO_200_LEVEL+GPIO_200_STICKY+GPIO_200_PULLUP+GPIO_200_PULLDOWN, GPIO_200_SELECT}, + {GPIO_201_SELECT, GPIO_201_TYPE, GPO_201_LEVEL+GPIO_201_STICKY+GPIO_201_PULLUP+GPIO_201_PULLDOWN, GPIO_201_SELECT}, + {GPIO_202_SELECT, GPIO_202_TYPE, GPO_202_LEVEL+GPIO_202_STICKY+GPIO_202_PULLUP+GPIO_202_PULLDOWN, GPIO_202_SELECT}, + {GPIO_203_SELECT, GPIO_203_TYPE, GPO_203_LEVEL+GPIO_203_STICKY+GPIO_203_PULLUP+GPIO_203_PULLDOWN, GPIO_203_SELECT}, + {GPIO_204_SELECT, GPIO_204_TYPE, GPO_204_LEVEL+GPIO_204_STICKY+GPIO_204_PULLUP+GPIO_204_PULLDOWN, GPIO_204_SELECT}, + {GPIO_205_SELECT, GPIO_205_TYPE, GPO_205_LEVEL+GPIO_205_STICKY+GPIO_205_PULLUP+GPIO_205_PULLDOWN, GPIO_205_SELECT}, + {GPIO_206_SELECT, GPIO_206_TYPE, GPO_206_LEVEL+GPIO_206_STICKY+GPIO_206_PULLUP+GPIO_206_PULLDOWN, GPIO_206_SELECT}, + {GPIO_207_SELECT, GPIO_207_TYPE, GPO_207_LEVEL+GPIO_207_STICKY+GPIO_207_PULLUP+GPIO_207_PULLDOWN, GPIO_207_SELECT}, + {GPIO_208_SELECT, GPIO_208_TYPE, GPO_208_LEVEL+GPIO_208_STICKY+GPIO_208_PULLUP+GPIO_208_PULLDOWN, GPIO_208_SELECT}, + {GPIO_209_SELECT, GPIO_209_TYPE, GPO_209_LEVEL+GPIO_209_STICKY+GPIO_209_PULLUP+GPIO_209_PULLDOWN, GPIO_209_SELECT}, + {GPIO_210_SELECT, GPIO_210_TYPE, GPO_210_LEVEL+GPIO_210_STICKY+GPIO_210_PULLUP+GPIO_210_PULLDOWN, GPIO_210_SELECT}, + {GPIO_211_SELECT, GPIO_211_TYPE, GPO_211_LEVEL+GPIO_211_STICKY+GPIO_211_PULLUP+GPIO_211_PULLDOWN, GPIO_211_SELECT}, + {GPIO_212_SELECT, GPIO_212_TYPE, GPO_212_LEVEL+GPIO_212_STICKY+GPIO_212_PULLUP+GPIO_212_PULLDOWN, GPIO_212_SELECT}, + {GPIO_213_SELECT, GPIO_213_TYPE, GPO_213_LEVEL+GPIO_213_STICKY+GPIO_213_PULLUP+GPIO_213_PULLDOWN, GPIO_213_SELECT}, + {GPIO_214_SELECT, GPIO_214_TYPE, GPO_214_LEVEL+GPIO_214_STICKY+GPIO_214_PULLUP+GPIO_214_PULLDOWN, GPIO_214_SELECT}, + {GPIO_215_SELECT, GPIO_215_TYPE, GPO_215_LEVEL+GPIO_215_STICKY+GPIO_215_PULLUP+GPIO_215_PULLDOWN, GPIO_215_SELECT}, + {GPIO_216_SELECT, GPIO_216_TYPE, GPO_216_LEVEL+GPIO_216_STICKY+GPIO_216_PULLUP+GPIO_216_PULLDOWN, GPIO_216_SELECT}, + {GPIO_217_SELECT, GPIO_217_TYPE, GPO_217_LEVEL+GPIO_217_STICKY+GPIO_217_PULLUP+GPIO_217_PULLDOWN, GPIO_217_SELECT}, + {GPIO_218_SELECT, GPIO_218_TYPE, GPO_218_LEVEL+GPIO_218_STICKY+GPIO_218_PULLUP+GPIO_218_PULLDOWN, GPIO_218_SELECT}, + {GPIO_219_SELECT, GPIO_219_TYPE, GPO_219_LEVEL+GPIO_219_STICKY+GPIO_219_PULLUP+GPIO_219_PULLDOWN, GPIO_219_SELECT}, + {GPIO_220_SELECT, GPIO_220_TYPE, GPO_220_LEVEL+GPIO_220_STICKY+GPIO_220_PULLUP+GPIO_220_PULLDOWN, GPIO_220_SELECT}, + {GPIO_221_SELECT, GPIO_221_TYPE, GPO_221_LEVEL+GPIO_221_STICKY+GPIO_221_PULLUP+GPIO_221_PULLDOWN, GPIO_221_SELECT}, + {GPIO_222_SELECT, GPIO_222_TYPE, GPO_222_LEVEL+GPIO_222_STICKY+GPIO_222_PULLUP+GPIO_222_PULLDOWN, GPIO_222_SELECT}, + {GPIO_223_SELECT, GPIO_223_TYPE, GPO_223_LEVEL+GPIO_223_STICKY+GPIO_223_PULLUP+GPIO_223_PULLDOWN, GPIO_223_SELECT}, + {GPIO_224_SELECT, GPIO_224_TYPE, GPO_224_LEVEL+GPIO_224_STICKY+GPIO_224_PULLUP+GPIO_224_PULLDOWN, GPIO_224_SELECT}, + {GPIO_225_SELECT, GPIO_225_TYPE, GPO_225_LEVEL+GPIO_225_STICKY+GPIO_225_PULLUP+GPIO_225_PULLDOWN, GPIO_225_SELECT}, + {GPIO_226_SELECT, GPIO_226_TYPE, GPO_226_LEVEL+GPIO_226_STICKY+GPIO_226_PULLUP+GPIO_226_PULLDOWN, GPIO_226_SELECT}, + {GPIO_227_SELECT, GPIO_227_TYPE, GPO_227_LEVEL+GPIO_227_STICKY+GPIO_227_PULLUP+GPIO_227_PULLDOWN, GPIO_227_SELECT}, + {GPIO_228_SELECT, GPIO_228_TYPE, GPO_228_LEVEL+GPIO_228_STICKY+GPIO_228_PULLUP+GPIO_228_PULLDOWN, GPIO_228_SELECT}, + {GPIO_229_SELECT, GPIO_229_TYPE, GPO_229_LEVEL+GPIO_229_STICKY+GPIO_229_PULLUP+GPIO_229_PULLDOWN, GPIO_229_SELECT}, };
typedef enum _GEVENT_COUNT { - GEVENT_00 = 0x60, - GEVENT_01, - GEVENT_02, - GEVENT_03, - GEVENT_04, - GEVENT_05, - GEVENT_06, - GEVENT_07, - GEVENT_08, - GEVENT_09, - GEVENT_10, - GEVENT_11, - GEVENT_12, - GEVENT_13, - GEVENT_14, - GEVENT_15, - GEVENT_16, - GEVENT_17, - GEVENT_18, - GEVENT_19, - GEVENT_20, - GEVENT_21, - GEVENT_22, - GEVENT_23 + GEVENT_00 = 0x60, + GEVENT_01, + GEVENT_02, + GEVENT_03, + GEVENT_04, + GEVENT_05, + GEVENT_06, + GEVENT_07, + GEVENT_08, + GEVENT_09, + GEVENT_10, + GEVENT_11, + GEVENT_12, + GEVENT_13, + GEVENT_14, + GEVENT_15, + GEVENT_16, + GEVENT_17, + GEVENT_18, + GEVENT_19, + GEVENT_20, + GEVENT_21, + GEVENT_22, + GEVENT_23 } GEVENT_COUNT;
typedef struct _GEVENT_SETTINGS { - u8 EventEnable; // 0: Disable, 1: Enable - u8 SciTrig; // 0: Falling Edge, 1: Rising Edge - u8 SciLevl; // 0: Edge trigger, 1: Level Trigger - u8 SmiSciEn; // 0: Not send SMI, 1: Send SMI - u8 SciS0En; // 0: Disable, 1: Enable - u8 SciMap; // 0000b->1111b - u8 SmiTrig; // 0: Active Low, 1: Active High - u8 SmiControl; // 0: Disable, 1: SMI 2: NMI 3: IRQ13 + u8 EventEnable; // 0: Disable, 1: Enable + u8 SciTrig; // 0: Falling Edge, 1: Rising Edge + u8 SciLevl; // 0: Edge trigger, 1: Level Trigger + u8 SmiSciEn; // 0: Not send SMI, 1: Send SMI + u8 SciS0En; // 0: Disable, 1: Enable + u8 SciMap; // 0000b->1111b + u8 SmiTrig; // 0: Active Low, 1: Active High + u8 SmiControl; // 0: Disable, 1: SMI 2: NMI 3: IRQ13 } GEVENT_SETTINGS;
const GEVENT_SETTINGS gevent_table[] = { - {GEVENT_00_EVENTENABLE, GEVENT_00_SCITRIG, GEVENT_00_SCILEVEL, GEVENT_00_SMISCIEN, GEVENT_00_SCIS0EN, GEVENT_00_SCIMAP, GEVENT_00_SMITRIG, GEVENT_00_SMICONTROL}, - {GEVENT_01_EVENTENABLE, GEVENT_01_SCITRIG, GEVENT_01_SCILEVEL, GEVENT_01_SMISCIEN, GEVENT_01_SCIS0EN, GEVENT_01_SCIMAP, GEVENT_01_SMITRIG, GEVENT_01_SMICONTROL}, - {GEVENT_02_EVENTENABLE, GEVENT_02_SCITRIG, GEVENT_02_SCILEVEL, GEVENT_02_SMISCIEN, GEVENT_02_SCIS0EN, GEVENT_02_SCIMAP, GEVENT_02_SMITRIG, GEVENT_02_SMICONTROL}, - {GEVENT_03_EVENTENABLE, GEVENT_03_SCITRIG, GEVENT_03_SCILEVEL, GEVENT_03_SMISCIEN, GEVENT_03_SCIS0EN, GEVENT_03_SCIMAP, GEVENT_03_SMITRIG, GEVENT_03_SMICONTROL}, - {GEVENT_04_EVENTENABLE, GEVENT_04_SCITRIG, GEVENT_04_SCILEVEL, GEVENT_04_SMISCIEN, GEVENT_04_SCIS0EN, GEVENT_04_SCIMAP, GEVENT_04_SMITRIG, GEVENT_04_SMICONTROL}, - {GEVENT_05_EVENTENABLE, GEVENT_05_SCITRIG, GEVENT_05_SCILEVEL, GEVENT_05_SMISCIEN, GEVENT_05_SCIS0EN, GEVENT_05_SCIMAP, GEVENT_05_SMITRIG, GEVENT_05_SMICONTROL}, - {GEVENT_06_EVENTENABLE, GEVENT_06_SCITRIG, GEVENT_06_SCILEVEL, GEVENT_06_SMISCIEN, GEVENT_06_SCIS0EN, GEVENT_06_SCIMAP, GEVENT_06_SMITRIG, GEVENT_06_SMICONTROL}, - {GEVENT_07_EVENTENABLE, GEVENT_07_SCITRIG, GEVENT_07_SCILEVEL, GEVENT_07_SMISCIEN, GEVENT_07_SCIS0EN, GEVENT_07_SCIMAP, GEVENT_07_SMITRIG, GEVENT_07_SMICONTROL}, - {GEVENT_08_EVENTENABLE, GEVENT_08_SCITRIG, GEVENT_08_SCILEVEL, GEVENT_08_SMISCIEN, GEVENT_08_SCIS0EN, GEVENT_08_SCIMAP, GEVENT_08_SMITRIG, GEVENT_08_SMICONTROL}, - {GEVENT_09_EVENTENABLE, GEVENT_09_SCITRIG, GEVENT_09_SCILEVEL, GEVENT_09_SMISCIEN, GEVENT_09_SCIS0EN, GEVENT_09_SCIMAP, GEVENT_09_SMITRIG, GEVENT_09_SMICONTROL}, - {GEVENT_10_EVENTENABLE, GEVENT_10_SCITRIG, GEVENT_10_SCILEVEL, GEVENT_10_SMISCIEN, GEVENT_10_SCIS0EN, GEVENT_10_SCIMAP, GEVENT_10_SMITRIG, GEVENT_10_SMICONTROL}, - {GEVENT_11_EVENTENABLE, GEVENT_11_SCITRIG, GEVENT_11_SCILEVEL, GEVENT_11_SMISCIEN, GEVENT_11_SCIS0EN, GEVENT_11_SCIMAP, GEVENT_11_SMITRIG, GEVENT_11_SMICONTROL}, - {GEVENT_12_EVENTENABLE, GEVENT_12_SCITRIG, GEVENT_12_SCILEVEL, GEVENT_12_SMISCIEN, GEVENT_12_SCIS0EN, GEVENT_12_SCIMAP, GEVENT_12_SMITRIG, GEVENT_12_SMICONTROL}, - {GEVENT_13_EVENTENABLE, GEVENT_13_SCITRIG, GEVENT_13_SCILEVEL, GEVENT_13_SMISCIEN, GEVENT_13_SCIS0EN, GEVENT_13_SCIMAP, GEVENT_13_SMITRIG, GEVENT_13_SMICONTROL}, - {GEVENT_14_EVENTENABLE, GEVENT_14_SCITRIG, GEVENT_14_SCILEVEL, GEVENT_14_SMISCIEN, GEVENT_14_SCIS0EN, GEVENT_14_SCIMAP, GEVENT_14_SMITRIG, GEVENT_14_SMICONTROL}, - {GEVENT_15_EVENTENABLE, GEVENT_15_SCITRIG, GEVENT_15_SCILEVEL, GEVENT_15_SMISCIEN, GEVENT_15_SCIS0EN, GEVENT_15_SCIMAP, GEVENT_15_SMITRIG, GEVENT_15_SMICONTROL}, - {GEVENT_16_EVENTENABLE, GEVENT_16_SCITRIG, GEVENT_16_SCILEVEL, GEVENT_16_SMISCIEN, GEVENT_16_SCIS0EN, GEVENT_16_SCIMAP, GEVENT_16_SMITRIG, GEVENT_16_SMICONTROL}, - {GEVENT_17_EVENTENABLE, GEVENT_17_SCITRIG, GEVENT_17_SCILEVEL, GEVENT_17_SMISCIEN, GEVENT_17_SCIS0EN, GEVENT_17_SCIMAP, GEVENT_17_SMITRIG, GEVENT_17_SMICONTROL}, - {GEVENT_18_EVENTENABLE, GEVENT_18_SCITRIG, GEVENT_18_SCILEVEL, GEVENT_18_SMISCIEN, GEVENT_18_SCIS0EN, GEVENT_18_SCIMAP, GEVENT_18_SMITRIG, GEVENT_18_SMICONTROL}, - {GEVENT_19_EVENTENABLE, GEVENT_19_SCITRIG, GEVENT_19_SCILEVEL, GEVENT_19_SMISCIEN, GEVENT_19_SCIS0EN, GEVENT_19_SCIMAP, GEVENT_19_SMITRIG, GEVENT_19_SMICONTROL}, - {GEVENT_20_EVENTENABLE, GEVENT_20_SCITRIG, GEVENT_20_SCILEVEL, GEVENT_20_SMISCIEN, GEVENT_20_SCIS0EN, GEVENT_20_SCIMAP, GEVENT_20_SMITRIG, GEVENT_20_SMICONTROL}, - {GEVENT_21_EVENTENABLE, GEVENT_21_SCITRIG, GEVENT_21_SCILEVEL, GEVENT_21_SMISCIEN, GEVENT_21_SCIS0EN, GEVENT_21_SCIMAP, GEVENT_21_SMITRIG, GEVENT_21_SMICONTROL}, - {GEVENT_22_EVENTENABLE, GEVENT_22_SCITRIG, GEVENT_22_SCILEVEL, GEVENT_22_SMISCIEN, GEVENT_22_SCIS0EN, GEVENT_22_SCIMAP, GEVENT_22_SMITRIG, GEVENT_22_SMICONTROL}, - {GEVENT_23_EVENTENABLE, GEVENT_23_SCITRIG, GEVENT_23_SCILEVEL, GEVENT_23_SMISCIEN, GEVENT_23_SCIS0EN, GEVENT_23_SCIMAP, GEVENT_23_SMITRIG, GEVENT_23_SMICONTROL}, + {GEVENT_00_EVENTENABLE, GEVENT_00_SCITRIG, GEVENT_00_SCILEVEL, GEVENT_00_SMISCIEN, GEVENT_00_SCIS0EN, GEVENT_00_SCIMAP, GEVENT_00_SMITRIG, GEVENT_00_SMICONTROL}, + {GEVENT_01_EVENTENABLE, GEVENT_01_SCITRIG, GEVENT_01_SCILEVEL, GEVENT_01_SMISCIEN, GEVENT_01_SCIS0EN, GEVENT_01_SCIMAP, GEVENT_01_SMITRIG, GEVENT_01_SMICONTROL}, + {GEVENT_02_EVENTENABLE, GEVENT_02_SCITRIG, GEVENT_02_SCILEVEL, GEVENT_02_SMISCIEN, GEVENT_02_SCIS0EN, GEVENT_02_SCIMAP, GEVENT_02_SMITRIG, GEVENT_02_SMICONTROL}, + {GEVENT_03_EVENTENABLE, GEVENT_03_SCITRIG, GEVENT_03_SCILEVEL, GEVENT_03_SMISCIEN, GEVENT_03_SCIS0EN, GEVENT_03_SCIMAP, GEVENT_03_SMITRIG, GEVENT_03_SMICONTROL}, + {GEVENT_04_EVENTENABLE, GEVENT_04_SCITRIG, GEVENT_04_SCILEVEL, GEVENT_04_SMISCIEN, GEVENT_04_SCIS0EN, GEVENT_04_SCIMAP, GEVENT_04_SMITRIG, GEVENT_04_SMICONTROL}, + {GEVENT_05_EVENTENABLE, GEVENT_05_SCITRIG, GEVENT_05_SCILEVEL, GEVENT_05_SMISCIEN, GEVENT_05_SCIS0EN, GEVENT_05_SCIMAP, GEVENT_05_SMITRIG, GEVENT_05_SMICONTROL}, + {GEVENT_06_EVENTENABLE, GEVENT_06_SCITRIG, GEVENT_06_SCILEVEL, GEVENT_06_SMISCIEN, GEVENT_06_SCIS0EN, GEVENT_06_SCIMAP, GEVENT_06_SMITRIG, GEVENT_06_SMICONTROL}, + {GEVENT_07_EVENTENABLE, GEVENT_07_SCITRIG, GEVENT_07_SCILEVEL, GEVENT_07_SMISCIEN, GEVENT_07_SCIS0EN, GEVENT_07_SCIMAP, GEVENT_07_SMITRIG, GEVENT_07_SMICONTROL}, + {GEVENT_08_EVENTENABLE, GEVENT_08_SCITRIG, GEVENT_08_SCILEVEL, GEVENT_08_SMISCIEN, GEVENT_08_SCIS0EN, GEVENT_08_SCIMAP, GEVENT_08_SMITRIG, GEVENT_08_SMICONTROL}, + {GEVENT_09_EVENTENABLE, GEVENT_09_SCITRIG, GEVENT_09_SCILEVEL, GEVENT_09_SMISCIEN, GEVENT_09_SCIS0EN, GEVENT_09_SCIMAP, GEVENT_09_SMITRIG, GEVENT_09_SMICONTROL}, + {GEVENT_10_EVENTENABLE, GEVENT_10_SCITRIG, GEVENT_10_SCILEVEL, GEVENT_10_SMISCIEN, GEVENT_10_SCIS0EN, GEVENT_10_SCIMAP, GEVENT_10_SMITRIG, GEVENT_10_SMICONTROL}, + {GEVENT_11_EVENTENABLE, GEVENT_11_SCITRIG, GEVENT_11_SCILEVEL, GEVENT_11_SMISCIEN, GEVENT_11_SCIS0EN, GEVENT_11_SCIMAP, GEVENT_11_SMITRIG, GEVENT_11_SMICONTROL}, + {GEVENT_12_EVENTENABLE, GEVENT_12_SCITRIG, GEVENT_12_SCILEVEL, GEVENT_12_SMISCIEN, GEVENT_12_SCIS0EN, GEVENT_12_SCIMAP, GEVENT_12_SMITRIG, GEVENT_12_SMICONTROL}, + {GEVENT_13_EVENTENABLE, GEVENT_13_SCITRIG, GEVENT_13_SCILEVEL, GEVENT_13_SMISCIEN, GEVENT_13_SCIS0EN, GEVENT_13_SCIMAP, GEVENT_13_SMITRIG, GEVENT_13_SMICONTROL}, + {GEVENT_14_EVENTENABLE, GEVENT_14_SCITRIG, GEVENT_14_SCILEVEL, GEVENT_14_SMISCIEN, GEVENT_14_SCIS0EN, GEVENT_14_SCIMAP, GEVENT_14_SMITRIG, GEVENT_14_SMICONTROL}, + {GEVENT_15_EVENTENABLE, GEVENT_15_SCITRIG, GEVENT_15_SCILEVEL, GEVENT_15_SMISCIEN, GEVENT_15_SCIS0EN, GEVENT_15_SCIMAP, GEVENT_15_SMITRIG, GEVENT_15_SMICONTROL}, + {GEVENT_16_EVENTENABLE, GEVENT_16_SCITRIG, GEVENT_16_SCILEVEL, GEVENT_16_SMISCIEN, GEVENT_16_SCIS0EN, GEVENT_16_SCIMAP, GEVENT_16_SMITRIG, GEVENT_16_SMICONTROL}, + {GEVENT_17_EVENTENABLE, GEVENT_17_SCITRIG, GEVENT_17_SCILEVEL, GEVENT_17_SMISCIEN, GEVENT_17_SCIS0EN, GEVENT_17_SCIMAP, GEVENT_17_SMITRIG, GEVENT_17_SMICONTROL}, + {GEVENT_18_EVENTENABLE, GEVENT_18_SCITRIG, GEVENT_18_SCILEVEL, GEVENT_18_SMISCIEN, GEVENT_18_SCIS0EN, GEVENT_18_SCIMAP, GEVENT_18_SMITRIG, GEVENT_18_SMICONTROL}, + {GEVENT_19_EVENTENABLE, GEVENT_19_SCITRIG, GEVENT_19_SCILEVEL, GEVENT_19_SMISCIEN, GEVENT_19_SCIS0EN, GEVENT_19_SCIMAP, GEVENT_19_SMITRIG, GEVENT_19_SMICONTROL}, + {GEVENT_20_EVENTENABLE, GEVENT_20_SCITRIG, GEVENT_20_SCILEVEL, GEVENT_20_SMISCIEN, GEVENT_20_SCIS0EN, GEVENT_20_SCIMAP, GEVENT_20_SMITRIG, GEVENT_20_SMICONTROL}, + {GEVENT_21_EVENTENABLE, GEVENT_21_SCITRIG, GEVENT_21_SCILEVEL, GEVENT_21_SMISCIEN, GEVENT_21_SCIS0EN, GEVENT_21_SCIMAP, GEVENT_21_SMITRIG, GEVENT_21_SMICONTROL}, + {GEVENT_22_EVENTENABLE, GEVENT_22_SCITRIG, GEVENT_22_SCILEVEL, GEVENT_22_SMISCIEN, GEVENT_22_SCIS0EN, GEVENT_22_SCIMAP, GEVENT_22_SMITRIG, GEVENT_22_SMICONTROL}, + {GEVENT_23_EVENTENABLE, GEVENT_23_SCITRIG, GEVENT_23_SCILEVEL, GEVENT_23_SMISCIEN, GEVENT_23_SCIS0EN, GEVENT_23_SCIMAP, GEVENT_23_SMITRIG, GEVENT_23_SMICONTROL}, };
#endif /* _GPIO_H_ */ diff --git a/src/mainboard/amd/torpedo/mainboard.c b/src/mainboard/amd/torpedo/mainboard.c index d90cb84..86339ef 100644 --- a/src/mainboard/amd/torpedo/mainboard.c +++ b/src/mainboard/amd/torpedo/mainboard.c @@ -49,9 +49,9 @@ void set_pcie_dereset(void) *************************************************/ static void mainboard_enable(device_t dev) { - printk(BIOS_INFO, "Mainboard " CONFIG_MAINBOARD_PART_NUMBER " Enable. dev=0x%p\n", dev); + printk(BIOS_INFO, "Mainboard " CONFIG_MAINBOARD_PART_NUMBER " Enable. dev=0x%p\n", dev); }
struct chip_operations mainboard_ops = { - .enable_dev = mainboard_enable, + .enable_dev = mainboard_enable, };
