Hello build bot (Jenkins), Pratikkumar Prajapati,
https://review.coreboot.org/18557
Change subject: soc/intel/common/block: [WIP]Add Intel common FAST_SPI code ......................................................................
Create Intel Common FAST_SPI Controller code. This code currently only contains the code for SPI initialization required in Bootblock phase, which has the following programming - * Get BIOS Rom Region Size * Enable SPIBAR * Disable the BIOS write protect so write commands are allowed * Enable SPI Prefetching and Caching. * SPI Controller register offsets in the common header fast_spi.h More code will get added up in the subsequent phases.
Change-Id: I046e3b30c8efb172851dd17f49565c9ec4cb38cb Signed-off-by: Barnali Sarkar barnali.sarkar@intel.com --- A src/soc/intel/common/block/fast_spi/Kconfig A src/soc/intel/common/block/fast_spi/Makefile.inc A src/soc/intel/common/block/fast_spi/fast_spi.c A src/soc/intel/common/block/include/intelblocks/fast_spi.h A src/soc/intel/common/block/include/intelblocks/fast_spi_def.h 5 files changed, 370 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/57/18557/15
