Attention is currently required from: Jason Glenesk, Raul Rangel, ritul guru, Marshall Dawson, Paul Menzel, Angel Pons, Aamir Bohra. Hello build bot (Jenkins), Jason Glenesk, Raul Rangel, Marshall Dawson, Aamir Bohra, Felix Held,
https://review.coreboot.org/c/coreboot/+/60968
Change subject: soc/amd/common/block/psp: Add platform secure boot support ......................................................................
Add Platform Secure Boot (PSB) enablement via the PSP if it is not already enabled. Upon receiving psb command, PSP will program PSB fuses as long as BIOS signing key token is valid.
Change-Id: I30aac29a22a5800d5995a78c50fdecd660a3d4eb Signed-off-by: Ritul Guru ritul.bits@gmail.com --- M src/soc/amd/common/block/psp/Kconfig M src/soc/amd/common/block/psp/Makefile.inc A src/soc/amd/common/block/psp/psb.c M src/soc/amd/common/block/psp/psp_def.h M src/soc/amd/common/block/psp/psp_gen2.c 5 files changed, 241 insertions(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/68/60968/9
