Martin Roth (martinroth@google.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13670
commit ef6e4bfb894532c701400e94044b8646b7a29b5b Author: Aaron Durbin adurbin@chromium.org Date: Wed Feb 10 10:56:06 2016 -0600
x86: add coreboot table entry for TSC info
The 8254 (Programmable Interrupt Timer) is becoming optional on x86 platforms -- either from saving power or not including it at all. To allow a payload to still use a TSC without doing calibration provide the TSC frequency information in the coreboot tables. That data is provided by code/logic already employed by platform. If tsc_freq_mhz() returns 0 or CONFIG_TSC_CONSTANT_RATE is not selected the coreboot table record isn't created.
BUG=chrome-os-partner:50214 BRANCH=glados TEST=With all subsequent patches confirmed TSC is picked up in libpayload.
Change-Id: Iaeadb85c2648587debcf55f4fa5351d0c287e971 Signed-off-by: Aaron Durbin adurbin@chromium.org --- src/arch/x86/cpu.c | 18 ++++++++++++++++++ src/commonlib/include/commonlib/coreboot_tables.h | 8 ++++++++ 2 files changed, 26 insertions(+)
diff --git a/src/arch/x86/cpu.c b/src/arch/x86/cpu.c index 5afae8b..cba105a 100644 --- a/src/arch/x86/cpu.c +++ b/src/arch/x86/cpu.c @@ -19,6 +19,7 @@ #include <cpu/x86/mtrr.h> #include <cpu/x86/msr.h> #include <cpu/x86/lapic.h> +#include <cpu/x86/tsc.h> #include <arch/cpu.h> #include <device/path.h> #include <device/device.h> @@ -291,4 +292,21 @@ void cpu_initialize(unsigned int index)
void lb_arch_add_records(struct lb_header *header) { + uint32_t freq_khz; + struct lb_tsc_info *tsc_info; + + /* Don't advertise a TSC rate unless it's constant. */ + if (!IS_ENABLED(CONFIG_TSC_CONSTANT_RATE)) + return; + + freq_khz = tsc_freq_mhz() * 1000; + + /* No use exposing a TSC frequency that is zero. */ + if (freq_khz == 0) + return; + + tsc_info = (void *)lb_new_record(header); + tsc_info->tag = LB_TAG_TSC_INFO; + tsc_info->size = sizeof(*tsc_info); + tsc_info->freq_khz = freq_khz; } diff --git a/src/commonlib/include/commonlib/coreboot_tables.h b/src/commonlib/include/commonlib/coreboot_tables.h index 43adb09..5c28791 100644 --- a/src/commonlib/include/commonlib/coreboot_tables.h +++ b/src/commonlib/include/commonlib/coreboot_tables.h @@ -335,6 +335,14 @@ struct lb_cbmem_entry { uint32_t id; };
+#define LB_TAG_TSC_INFO 0x0032 +struct lb_tsc_info { + uint32_t tag; + uint32_t size; + + uint32_t freq_khz; +}; + #define LB_TAG_SERIALNO 0x002a #define MAX_SERIALNO_LENGTH 32
