Attention is currently required from: Hung-Te Lin, Yidi Lin, Yu-Ping Wu.
Yang Wu has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/85890?usp=email )
Change subject: mb/google/corsola/var/wyrdeer: Add STA_2082109QFH040022_50E MIPI panel ......................................................................
Add STA_2082109QFH040022_50E MIPI panel for wyrdeer. Datasheet: 2082109QFH040022-50E-XR109IB5T_Full viewing-300-51PIN-V1.0.pdf
BUG=b:379810871 TEST=emerge-staryu coreboot chromeos-bootimage BRANCH=corsola
Change-Id: I64b907da8ff4e88b9290132033b9300d0b9488cb --- M src/mainboard/google/corsola/Kconfig M src/mainboard/google/corsola/panel_wyrdeer.c 2 files changed, 9 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/90/85890/1
diff --git a/src/mainboard/google/corsola/Kconfig b/src/mainboard/google/corsola/Kconfig index 6977bd4..d8643fd 100644 --- a/src/mainboard/google/corsola/Kconfig +++ b/src/mainboard/google/corsola/Kconfig @@ -74,6 +74,7 @@ select MIPI_PANEL_KD_KD101NE3_40TI if BOARD_GOOGLE_WUGTRIO select MIPI_PANEL_KD_KD110N11_51IE if BOARD_GOOGLE_WYRDEER select MIPI_PANEL_LCE_LMFBX101117480 if BOARD_GOOGLE_WUGTRIO + select MIPI_PANEL_STA_2082109QFH040022_50E if BOARD_GOOGLE_WYRDEER select MIPI_PANEL_STA_ER88577 if BOARD_GOOGLE_WUGTRIO select MIPI_PANEL_STA_HIMAX83102_J02 if BOARD_GOOGLE_STARMIE select MIPI_PANEL_STA_ILI9882T if BOARD_GOOGLE_STARMIE diff --git a/src/mainboard/google/corsola/panel_wyrdeer.c b/src/mainboard/google/corsola/panel_wyrdeer.c index 5ae3120..5d6379d 100644 --- a/src/mainboard/google/corsola/panel_wyrdeer.c +++ b/src/mainboard/google/corsola/panel_wyrdeer.c @@ -25,6 +25,14 @@ .disp_path = DISP_PATH_MIPI, .orientation = LB_FB_ORIENTATION_LEFT_UP, }, + /* STA Technology panel */ + [9] = { + .configure_backlight = backlight_control, + .power_on = mipi_panel_power_on, + .name = "STA_2082109QFH040022_50E", + .disp_path = DISP_PATH_MIPI, + .orientation = LB_FB_ORIENTATION_LEFT_UP, + }, };
struct panel_description *get_panel_description(void)
