Jakub Czapiga has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/80382?usp=email )
Change subject: 3rdparty/cmocka: Update cmocka to latest stable-1.1 ......................................................................
New patches: 8be3737 cmocka: Fix assert_memory_equal() display fb38de9 cmake: disable `-Wdeclaration-after-statement` a74d9cd Sanitize XML strings. 4e92198 Improve c_strreplace implementation ea6ab8b cmake: Set CMOCKA_LIBRARIES in package config for backwards compatibility 53de473 cmocka: Add overflow check for test_calloc() e738d6e tests: Add test for test_calloc() a01cc69 Bump version to 1.1.7 123f00e cpack: Update ignore files for source package generation f1e1615 Bump version 1.1.6 35dd06e tests: The exception handler doesn't work on Windows 9d72cf9 tests: Raise segmantation fault 2b20a4d tests: Rename exceptions tests array 4cd1fda tests: Better match for test_exception_handler 8ad2c4e cmake: Fix path relocation in pkgconfig file for mingw 3137fa5 cmake: Do not use CMAKE_(BINARY|SOURCE)_DIR for compile_commands.json 6e9d32f Improve INSTALL.md c4da7e1 doc: Link to the examples for mocking b13f29b include: Update copyright year info 98c451d include: Define strtok_r with Visual Studio 4aae816 gitlab-ci: Move memory and ub sanitizer to analysis stage 559381b gitlab-ci: Move freebsd to test stage ce43813 examples: Add missing compile and link options 5ead982 gitlab-ci: Introduce stages 5f366b6 gitlab-ci: Fix typo in fedora/mingw32 build 77476f7 gitlab-ci: Use gitlab windows runners 200393b gitlab-ci: Reformat yaml 406591a tests: Initialize 'struct stat' in test_assert_macros.c b201da5 cmake: Fix path where to find cmocka.dll a47b3da include: Improved call ordering documentation 61b1fb9 doc: Remove redundant words 2cc8cba Fix issue with fail_msg
TEST=make unit-tests
Change-Id: I60b37021e2587cc32c755719ef40a650a1c14b59 Signed-off-by: Jakub Czapiga czapiga@google.com --- M 3rdparty/cmocka 1 file changed, 1 insertion(+), 1 deletion(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/82/80382/1
diff --git a/3rdparty/cmocka b/3rdparty/cmocka index 8931845..8be3737 160000 --- a/3rdparty/cmocka +++ b/3rdparty/cmocka @@ -1 +1 @@ -Subproject commit 8931845c35e78b5123d73430b071affd537d5935 +Subproject commit 8be37372097d1aa5e03b565936db7891b6180e73
