Attention is currently required from: Subrata Banik, Maulik V Vaghela, Meera Ravindranath, Patrick Rudolph. Hello build bot (Jenkins), Maulik V Vaghela, Meera Ravindranath, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/60801
Change subject: soc/intel/common/gpio: Perform GPIO PAD lock outside SMM ......................................................................
This patch performs GPIO PAD lock configuration in non-smm mode. Typically, coreboot enables SMI at latest boot phase post FSP-S, hence, FSP-S might get chance to perform GPP lock configuration. With this code changes, coreboot can be able to perform GPIO PAD lock configuration early in the boot flow, prior to calling FSP-S.
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: I71b4e2f24303b6acb56debd581bd6bc818b6f926 --- M src/soc/intel/common/block/gpio/gpio.c 1 file changed, 47 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/01/60801/2
