Hello Paul Menzel, build bot (Jenkins),
https://review.coreboot.org/18241
Change subject: [WIP] mainboards/hp: Add HP Elitebook 2760p ......................................................................
The code is generated by autoport.
The flash chip is socketed beside the WLAN slot. The EHCI debug port is on right side of the laptop beside the RJ11 connector.
Things that work: - memory: 0+8G, 4G+8G - Linux (Linux Mint 18.1 with Linux 4.4) - native graphics init + SeaBIOS payload with SeaVGABIOS - all 3 USB ports - WLAN - WWAN - expresscard - S3 suspend and resume - internal flashing after IFD is unlocked and coreboot is flashed - keyboard, trackpoint and touchpad - fan control
Things that don't work: - AC and battery status - wacom digitizer
Things that are not tested: - WWAN - SD card reader - smart card reader - cable modem
(EC) blobs:
This laptop uses SMSC KBC1126-NU as EC. It needs two blobs in the flash chip. You can use the tools in util/kbc1126 to extract them from OEM firmware, and use the following configuration to insert them to coreboot image:
-> Chipset -> Add firmware images for KBC1126 firmware
Change-Id: I3ffdb9f9c71f6c9a84e896abc3c424c8dd4bed0e Signed-off-by: Iru Cai mytbk920423@gmail.com --- A src/mainboard/hp/2760p/Kconfig A src/mainboard/hp/2760p/Kconfig.name A src/mainboard/hp/2760p/Makefile.inc A src/mainboard/hp/2760p/acpi/ec.asl A src/mainboard/hp/2760p/acpi/platform.asl A src/mainboard/hp/2760p/acpi/superio.asl A src/mainboard/hp/2760p/acpi_tables.c A src/mainboard/hp/2760p/board_info.txt A src/mainboard/hp/2760p/devicetree.cb A src/mainboard/hp/2760p/dsdt.asl A src/mainboard/hp/2760p/gpio.c A src/mainboard/hp/2760p/hda_verb.c A src/mainboard/hp/2760p/mainboard.c A src/mainboard/hp/2760p/romstage.c 14 files changed, 738 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/41/18241/15
