Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/83732?usp=email )
Change subject: vc/intel/fsp/fsp2_0/ptl: Add placeholder FSP headers to compile ......................................................................
Details: - Skeleton files to compile google/fatcat mainboard.
BUG=b:348678529 TEST=Build verified on with using PTL SOC and google/fatcat mainboard.
Change-Id: I4c069ba64f487259ce746dc52296618d91209602 Signed-off-by: Saurabh Mishra mishra.saurabh@intel.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/83732 Reviewed-by: Ronak Kanabar ronak.kanabar@intel.com Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Ravishankar Sarawadi ravishankar.sarawadi@intel.com Reviewed-by: Subrata Banik subratabanik@google.com Reviewed-by: Jamie Ryu jamie.m.ryu@intel.com --- A src/vendorcode/intel/fsp/fsp2_0/pantherlake/FirmwareVersionInfo.h A src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspProducerDataHeader.h A src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspUpd.h A src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspmUpd.h A src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspsUpd.h A src/vendorcode/intel/fsp/fsp2_0/pantherlake/MemInfoHob.h 6 files changed, 481 insertions(+), 0 deletions(-)
Approvals: Ravishankar Sarawadi: Looks good to me, but someone else must approve Jamie Ryu: Looks good to me, but someone else must approve build bot (Jenkins): Verified Ronak Kanabar: Looks good to me, approved Subrata Banik: Looks good to me, approved
diff --git a/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FirmwareVersionInfo.h b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FirmwareVersionInfo.h new file mode 100644 index 0000000..ec19ec1 --- /dev/null +++ b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FirmwareVersionInfo.h @@ -0,0 +1,61 @@ +/** @file + Header file for Firmware Version Information + + @copyright + Copyright (c) 2015 - 2024, Intel Corporation. All rights reserved.<BR> + + This program and the accompanying materials are licensed and made available under + the terms and conditions of the BSD License which accompanies this distribution. + The full text of the license may be found at + http://opensource.org/licenses/bsd-license.php + + THE PROGRAM IS DISTRIBUTED UNDER THE BSD LICENSE ON AN "AS IS" BASIS, + WITHOUT WARRANTIES OR REPRESENTATIONS OF ANY KIND, EITHER EXPRESS OR IMPLIED. + + @par Specification Reference: + System Management BIOS (SMBIOS) Reference Specification v3.0.0 dated 2015-Feb-12 + http://www.dmtf.org/sites/default/files/standards/documents/DSP0134_3.0.0.pd... + +**/ + +#ifndef __FIRMWARE_VERSION_INFO_H__ +#define __FIRMWARE_VERSION_INFO_H__ + +#include <IndustryStandard/SmBios.h> + +#define INTEL_FIRMWARE_VERSION_INFO_GROUP_NAME "Firmware Version Info" +#define INTEL_FVI_SMBIOS_TYPE 0xDD + +#pragma pack(1) + +/// +/// Firmware Version Structure +/// +typedef struct { + UINT8 MajorVersion; + UINT8 MinorVersion; + UINT8 Revision; + UINT16 BuildNumber; +} INTEL_FIRMWARE_VERSION; + +/// +/// Firmware Version Info (FVI) Structure +/// +typedef struct { + SMBIOS_TABLE_STRING ComponentName; ///< String Index of Component Name + SMBIOS_TABLE_STRING VersionString; ///< String Index of Version String + INTEL_FIRMWARE_VERSION Version; ///< Firmware version +} INTEL_FIRMWARE_VERSION_INFO; + +/// +/// SMBIOS OEM Type Intel Firmware Version Info (FVI) Structure +/// +typedef struct { + SMBIOS_STRUCTURE Header; ///< SMBIOS structure header + UINT8 Count; ///< Number of FVI entries in this structure + INTEL_FIRMWARE_VERSION_INFO Fvi[1]; ///< FVI structure(s) +} SMBIOS_TABLE_TYPE_OEM_INTEL_FVI; + +#pragma pack() + +#endif diff --git a/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspProducerDataHeader.h b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspProducerDataHeader.h new file mode 100644 index 0000000..d27815c --- /dev/null +++ b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspProducerDataHeader.h @@ -0,0 +1,82 @@ +/** @file + + Copyright (c) 2024, Intel Corporation. All rights reserved.<BR> + This program and the accompanying materials + are licensed and made available under the terms and conditions of the BSD License + which accompanies this distribution. The full text of the license may be found at + http://opensource.org/licenses/bsd-license.php + + THE PROGRAM IS DISTRIBUTED UNDER THE BSD LICENSE ON AN "AS IS" BASIS, + WITHOUT WARRANTIES OR REPRESENTATIONS OF ANY KIND, EITHER EXPRESS OR IMPLIED. +**/ + +#ifndef _FSP_PRODUCER_DATA_HEADER_H_ +#define _FSP_PRODUCER_DATA_HEADER_H_ + +#include <Guid/FspHeaderFile.h> + +#define BUILD_TIME_STAMP_SIZE 12 + +// +// FSP Header Data structure from FspHeader driver. +// +#pragma pack(1) +/// +/// FSP Producer Data Subtype - 1 +/// +typedef struct { + /// + /// Byte 0x00: Length of this FSP producer data type record. + /// + UINT16 Length; + /// + /// Byte 0x02: FSP producer data type. + /// + UINT8 Type; + /// + /// Byte 0x03: Revision of this FSP producer data type. + /// + UINT8 Revision; + /// + /// Byte 0x04: 4 byte field of RC version which is used to build this FSP image. + /// + UINT32 RcVersion; + /// + /// Byte 0x08: Represents the build time stamp "YYYYMMDDHHMM". + /// + UINT8 BuildTimeStamp[BUILD_TIME_STAMP_SIZE]; +} FSP_PRODUCER_DATA_TYPE1; + +/// +/// FSP Producer Data Subtype - 2 +/// +typedef struct { + /// + /// Byte 0x00: Length of this FSP producer data type record. + /// + UINT16 Length; + /// + /// Byte 0x02: FSP producer data type. + /// + UINT8 Type; + /// + /// Byte 0x03: Revision of this FSP producer data type. + /// + UINT8 Revision; + /// + /// Byte 0x04: 4 byte field of Mrc version which is used to build this FSP image. + /// + UINT8 MrcVersion [4]; +} FSP_PRODUCER_DATA_TYPE2; + + +typedef struct { + FSP_INFO_HEADER FspInfoHeader; + FSP_INFO_EXTENDED_HEADER FspInfoExtendedHeader; + FSP_PRODUCER_DATA_TYPE1 FspProduceDataType1; + FSP_PRODUCER_DATA_TYPE2 FspProduceDataType2; + FSP_PATCH_TABLE FspPatchTable; +} FSP_PRODUCER_DATA_TABLES; +#pragma pack() + +#endif // _FSP_PRODUCER_DATA_HEADER_H diff --git a/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspUpd.h b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspUpd.h new file mode 100644 index 0000000..9661285 --- /dev/null +++ b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspUpd.h @@ -0,0 +1,48 @@ +/** @file + +Copyright (c) 2024, Intel Corporation. All rights reserved.<BR> + +Redistribution and use in source and binary forms, with or without modification, +are permitted provided that the following conditions are met: + +* Redistributions of source code must retain the above copyright notice, this + list of conditions and the following disclaimer. +* Redistributions in binary form must reproduce the above copyright notice, this + list of conditions and the following disclaimer in the documentation and/or + other materials provided with the distribution. +* Neither the name of Intel Corporation nor the names of its contributors may + be used to endorse or promote products derived from this software without + specific prior written permission. + + THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" + AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE + LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR + CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF + SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) + ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF + THE POSSIBILITY OF SUCH DAMAGE. + + This file is automatically generated. Please do NOT modify !!! + +**/ + +#ifndef __FSPUPD_H__ +#define __FSPUPD_H__ + +#include <FspEas.h> + +#pragma pack(1) + +#define FSPT_UPD_SIGNATURE 0x545F4450554C5450 /* 'PTLUPD_T' */ + +#define FSPM_UPD_SIGNATURE 0x4D5F4450554C5450 /* 'PTLUPD_M' */ + +#define FSPS_UPD_SIGNATURE 0x535F4450554C5450 /* 'PTLUPD_S' */ + +#pragma pack() + +#endif diff --git a/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspmUpd.h b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspmUpd.h new file mode 100644 index 0000000..4c98fa8 --- /dev/null +++ b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspmUpd.h @@ -0,0 +1,76 @@ +/** @file + +Copyright (c) 2024, Intel Corporation. All rights reserved.<BR> + +Redistribution and use in source and binary forms, with or without modification, +are permitted provided that the following conditions are met: + +* Redistributions of source code must retain the above copyright notice, this + list of conditions and the following disclaimer. +* Redistributions in binary form must reproduce the above copyright notice, this + list of conditions and the following disclaimer in the documentation and/or + other materials provided with the distribution. +* Neither the name of Intel Corporation nor the names of its contributors may + be used to endorse or promote products derived from this software without + specific prior written permission. + + THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" + AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE + LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR + CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF + SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) + ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF + THE POSSIBILITY OF SUCH DAMAGE. + + This file is automatically generated. Please do NOT modify !!! + +**/ + +#ifndef __FSPMUPD_H__ +#define __FSPMUPD_H__ + +#include <FspUpd.h> + +#pragma pack(1) + + +#include <MemInfoHob.h> + +/** FSP M Configuration +**/ +typedef struct { + /* Placeholder for FSP_M_CONFIG UPDs */ +} FSP_M_CONFIG; + +/** Fsp M UPD Configuration +**/ +typedef struct { + +/** Offset 0x0000 +**/ + FSP_UPD_HEADER FspUpdHeader; + +/** Offset 0x0020 +**/ + FSPM_ARCH2_UPD FspmArchUpd; + +/** Offset 0x0060 +**/ + FSP_M_CONFIG FspmConfig; + +/** Offset 0x0060 +**/ + UINT8 UnusedUpdSpace4[6]; + +/** Offset 0x0066 +**/ + UINT16 UpdTerminator; +} FSPM_UPD; + +#pragma pack() + +#endif diff --git a/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspsUpd.h b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspsUpd.h new file mode 100644 index 0000000..938c283 --- /dev/null +++ b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/FspsUpd.h @@ -0,0 +1,94 @@ +/** @file + +Copyright (c) 2024, Intel Corporation. All rights reserved.<BR> + +Redistribution and use in source and binary forms, with or without modification, +are permitted provided that the following conditions are met: + +* Redistributions of source code must retain the above copyright notice, this + list of conditions and the following disclaimer. +* Redistributions in binary form must reproduce the above copyright notice, this + list of conditions and the following disclaimer in the documentation and/or + other materials provided with the distribution. +* Neither the name of Intel Corporation nor the names of its contributors may + be used to endorse or promote products derived from this software without + specific prior written permission. + + THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" + AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE + IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE + ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE + LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR + CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF + SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS + INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN + CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) + ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF + THE POSSIBILITY OF SUCH DAMAGE. + + This file is automatically generated. Please do NOT modify !!! + +**/ + +#ifndef __FSPSUPD_H__ +#define __FSPSUPD_H__ + +#include <FspUpd.h> + +#pragma pack(1) + + +/// +/// Refer to the definition of PCH_INT_PIN +/// +typedef enum { + SiPchNoInt, ///< No Interrupt Pin + SiPchIntA, + SiPchIntB, + SiPchIntC, + SiPchIntD +} SI_PCH_INT_PIN; +/// +/// The PCH_DEVICE_INTERRUPT_CONFIG block describes interrupt pin, IRQ and interrupt mode for PCH device. +/// +typedef struct { + UINT8 Device; ///< Device number + UINT8 Function; ///< Device function + UINT8 IntX; ///< Interrupt pin: INTA-INTD (see SI_PCH_INT_PIN) + UINT8 Irq; ///< IRQ to be set for device. +} SI_PCH_DEVICE_INTERRUPT_CONFIG; + +/** FSP S Configuration +**/ +typedef struct { + /* Placeholder for FSP_S_CONFIG UPDs */ +} FSP_S_CONFIG; + +/** Fsp S UPD Configuration +**/ +typedef struct { + +/** Offset 0x0000 +**/ + FSP_UPD_HEADER FspUpdHeader; + +/** Offset 0x0020 +**/ + FSPS_ARCH2_UPD FspsArchUpd; + +/** Offset 0x0040 +**/ + FSP_S_CONFIG FspsConfig; + +/** Offset 0x0040 +**/ + UINT8 UnusedUpdSpace1[6]; + +/** Offset 0x0046 +**/ + UINT16 UpdTerminator; +} FSPS_UPD; + +#pragma pack() + +#endif diff --git a/src/vendorcode/intel/fsp/fsp2_0/pantherlake/MemInfoHob.h b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/MemInfoHob.h new file mode 100644 index 0000000..e010348 --- /dev/null +++ b/src/vendorcode/intel/fsp/fsp2_0/pantherlake/MemInfoHob.h @@ -0,0 +1,120 @@ +/** @file + This file contains definitions required for creation of + Memory S3 Save data, Memory Info data and Memory Platform + data hobs. + + @copyright + Copyright (c) 1999 - 2024, Intel Corporation. All rights reserved.<BR> + This program and the accompanying materials are licensed and made available under + the terms and conditions of the BSD License that accompanies this distribution. + The full text of the license may be found at + http://opensource.org/licenses/bsd-license.php. + THE PROGRAM IS DISTRIBUTED UNDER THE BSD LICENSE ON AN "AS IS" BASIS, + + WITHOUT WARRANTIES OR REPRESENTATIONS OF ANY KIND, EITHER EXPRESS OR IMPLIED. + +@par Specification Reference: +**/ + +#ifndef _MEM_INFO_HOB_H_ +#define _MEM_INFO_HOB_H_ + + +#pragma pack (push, 1) + +#if !defined(_PEI_HOB_H_) && !defined(__PI_HOB_H__) +#ifndef __HOB__H__ +typedef struct _EFI_HOB_GENERIC_HEADER { + UINT16 HobType; + UINT16 HobLength; + UINT32 Reserved; +} EFI_HOB_GENERIC_HEADER; + +typedef struct _EFI_HOB_GUID_TYPE { + EFI_HOB_GENERIC_HEADER Header; + EFI_GUID Name; + /// + /// Guid specific data goes here + /// +} EFI_HOB_GUID_TYPE; +#endif +#endif + +// +// MRC version description. +// +typedef struct { + UINT8 Major; ///< Major version number + UINT8 Minor; ///< Minor version number + UINT8 Rev; ///< Revision number + UINT8 Build; ///< Build number +} SiMrcVersion; + +// +// Matches MrcChannelSts enum in MRC +// +#ifndef CHANNEL_NOT_PRESENT +#define CHANNEL_NOT_PRESENT 0 // There is no channel present on the controller. +#endif +#ifndef CHANNEL_DISABLED +#define CHANNEL_DISABLED 1 // There is a channel present but it is disabled. +#endif +#ifndef CHANNEL_PRESENT +#define CHANNEL_PRESENT 2 // There is a channel present and it is enabled. +#endif + +// +// Matches MrcDimmSts enum in MRC +// +#ifndef DIMM_ENABLED +#define DIMM_ENABLED 0 // DIMM/rank Pair is enabled, presence will be detected. +#endif +#ifndef DIMM_DISABLED +#define DIMM_DISABLED 1 // DIMM/rank Pair is disabled, regardless of presence. +#endif +#ifndef DIMM_PRESENT +#define DIMM_PRESENT 2 // There is a DIMM present in the slot/rank pair and it will be used. +#endif +#ifndef DIMM_NOT_PRESENT +#define DIMM_NOT_PRESENT 3 // There is no DIMM present in the slot/rank pair. +#endif + +// +// Matches MrcBootMode enum in MRC +// +#ifndef __MRC_BOOT_MODE__ +#define __MRC_BOOT_MODE__ //The below values are originated from MrcCommonTypes.h + #ifndef INT32_MAX + #define INT32_MAX (0x7FFFFFFF) + #endif //INT32_MAX +typedef enum { + bmCold, ///< Cold boot + bmWarm, ///< Warm boot + bmS3, ///< S3 resume + bmFast, ///< Fast boot + MrcBootModeMax, ///< MRC_BOOT_MODE enumeration maximum value. + MrcBootModeDelim = INT32_MAX ///< This value ensures the enum size is consistent on both sides of the PPI. +} MRC_BOOT_MODE; +#endif //__MRC_BOOT_MODE__ + +/** + Memory Info Data Hob +**/ +typedef struct { +} MEMORY_INFO_DATA_HOB; + +/** + Memory Platform Data Hob +**/ +typedef struct { +} MEMORY_PLATFORM_DATA; + +typedef struct { + EFI_HOB_GUID_TYPE EfiHobGuidType; + MEMORY_PLATFORM_DATA Data; + UINT8 *Buffer; +} MEMORY_PLATFORM_DATA_HOB; + +#pragma pack (pop) + +#endif // _MEM_INFO_HOB_H_
