Paul Kocialkowski (contact@paulk.fr) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/11143
commit 935380ed10f1e5af95c216e2b2265192f1ae5ba5 Author: Paul Kocialkowski contact@paulk.fr Date: Sun Aug 9 10:23:38 2015 +0200
chromeos: No dependency of ChromeOS bindings against vboot firmware verification
Some ChromeOS bindings might be wanted without using vboot verification, so the CHROMEOS Kconfig option shouldn't depend on VBOOT_VERIFY_FIRMWARE. This allows booting Coreboot all the way up to payload from the RO firmware path, without jumping to a RW firmware along the way, during normal boot.
However, it makes sense to select it by default.
Change-Id: Ia4057a56838aa05dcf3cb250ae1a27fd91402ddb Signed-off-by: Paul Kocialkowski contact@paulk.fr --- src/vendorcode/google/chromeos/Kconfig | 7 +++++-- 1 file changed, 5 insertions(+), 2 deletions(-)
diff --git a/src/vendorcode/google/chromeos/Kconfig b/src/vendorcode/google/chromeos/Kconfig index 2f04f24..78a969a 100644 --- a/src/vendorcode/google/chromeos/Kconfig +++ b/src/vendorcode/google/chromeos/Kconfig @@ -31,7 +31,6 @@ config CHROMEOS select BOOTMODE_STRAPS select ELOG select COLLECT_TIMESTAMPS - select VBOOT_VERIFY_FIRMWARE help Enable ChromeOS specific features like the GPIO sub table in the coreboot table. NOTE: Enabling this option on an unsupported @@ -129,7 +128,7 @@ config VIRTUAL_DEV_SWITCH
config VBOOT_VERIFY_FIRMWARE bool "Verify firmware with vboot." - default n + default y depends on HAVE_HARD_RESET help Enabling VBOOT_VERIFY_FIRMWARE will use vboot to verify the components @@ -163,8 +162,12 @@ config WIPEOUT_SUPPORTED signal the application the need for factory reset (a.k.a. wipe out) of the device
+if VBOOT_VERIFY_FIRMWARE + source src/vendorcode/google/chromeos/vboot2/Kconfig
+endif # VBOOT_VERIFY_FIRMWARE + endif # CHROMEOS if !CHROMEOS config VIRTUAL_DEV_SWITCH
