Felix Held has submitted this change. ( https://review.coreboot.org/c/coreboot/+/68538 )
Change subject: soc/amd/stoneyridge/uart: introduce and use soc_get_uart_ctrlr_info ......................................................................
Introduce and use soc_get_uart_ctrlr_info to access the uart_info array to further decouple uart_info from the code as preparation to factor out most of the code to a common implementation.
Signed-off-by: Felix Held felix-coreboot@felixheld.de Change-Id: I813483bc0421043dc67c523f0ea2016a16a29f60 Reviewed-on: https://review.coreboot.org/c/coreboot/+/68538 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Fred Reitberger reitbergerfred@gmail.com --- M src/soc/amd/stoneyridge/uart.c 1 file changed, 33 insertions(+), 4 deletions(-)
Approvals: build bot (Jenkins): Verified Fred Reitberger: Looks good to me, approved
diff --git a/src/soc/amd/stoneyridge/uart.c b/src/soc/amd/stoneyridge/uart.c index 3b6d49c..9a8add0 100644 --- a/src/soc/amd/stoneyridge/uart.c +++ b/src/soc/amd/stoneyridge/uart.c @@ -20,18 +20,30 @@ } }, };
+static const struct soc_uart_ctrlr_info *soc_get_uart_ctrlr_info(size_t *num_ctrlrs) +{ + *num_ctrlrs = ARRAY_SIZE(uart_info); + return uart_info; +} + uintptr_t get_uart_base(unsigned int idx) { - if (idx >= ARRAY_SIZE(uart_info)) + size_t num_ctrlrs; + const struct soc_uart_ctrlr_info *ctrlr = soc_get_uart_ctrlr_info(&num_ctrlrs); + + if (idx >= num_ctrlrs) return 0;
- return uart_info[idx].base; + return ctrlr[idx].base; }
void set_uart_config(unsigned int idx) { - if (idx >= ARRAY_SIZE(uart_info)) + size_t num_ctrlrs; + const struct soc_uart_ctrlr_info *ctrlr = soc_get_uart_ctrlr_info(&num_ctrlrs); + + if (idx >= num_ctrlrs) return;
- gpio_configure_pads(uart_info[idx].mux, 2); + gpio_configure_pads(ctrlr[idx].mux, 2); }
