Kyösti Mälkki (kyosti.malkki@gmail.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6117
commit 8fcdda6cf0c198ece0ee908d91d8736d76b3e552 Author: Kyösti Mälkki kyosti.malkki@gmail.com Date: Thu Jun 26 05:30:54 2014 +0300
AMD boards: Fix typos
Change-Id: I5df80e6445f390060372be8760c9b5e960e4a6e5 Signed-off-by: Kyösti Mälkki kyosti.malkki@gmail.com --- src/northbridge/amd/agesa/family10/northbridge.c | 2 +- src/northbridge/amd/agesa/family12/northbridge.c | 2 +- src/northbridge/amd/agesa/family14/northbridge.c | 2 +- src/northbridge/amd/agesa/family15/northbridge.c | 2 +- src/northbridge/amd/agesa/family15tn/northbridge.c | 2 +- src/northbridge/amd/agesa/family16kb/northbridge.c | 2 +- src/northbridge/amd/amdfam10/northbridge.c | 2 +- src/northbridge/amd/amdk8/northbridge.c | 2 +- 8 files changed, 8 insertions(+), 8 deletions(-)
diff --git a/src/northbridge/amd/agesa/family10/northbridge.c b/src/northbridge/amd/agesa/family10/northbridge.c index 60f3951..886d112 100644 --- a/src/northbridge/amd/agesa/family10/northbridge.c +++ b/src/northbridge/amd/agesa/family10/northbridge.c @@ -1028,7 +1028,7 @@ static void amdfam10_domain_set_resources(device_t dev)
//printk(BIOS_DEBUG, "node %d : mmio_basek=%08lx, basek=%08llx, limitk=%08llx\n", i, mmio_basek, basek, limitk);
- /* split the region to accomodate pci memory space */ + /* split the region to accommodate pci memory space */ if ((basek < 4*1024*1024 ) && (limitk > mmio_basek)) { if (basek <= mmio_basek) { unsigned pre_sizek; diff --git a/src/northbridge/amd/agesa/family12/northbridge.c b/src/northbridge/amd/agesa/family12/northbridge.c index 9757d96..5701ed0 100644 --- a/src/northbridge/amd/agesa/family12/northbridge.c +++ b/src/northbridge/amd/agesa/family12/northbridge.c @@ -714,7 +714,7 @@ printk(BIOS_DEBUG, "adsr - 0xa0000 to 0xbffff resource.\n"); "adsr: mmio_basek=%08lx, basek=%08llx, limitk=%08llx\n", mmio_basek, basek, limitk);
- /* split the region to accomodate pci memory space */ + /* split the region to accommodate pci memory space */ if ( (basek < 4*1024*1024 ) && (limitk > mmio_basek) ) { if (basek <= mmio_basek) { unsigned pre_sizek; diff --git a/src/northbridge/amd/agesa/family14/northbridge.c b/src/northbridge/amd/agesa/family14/northbridge.c index 7b6b401..75ea76d 100644 --- a/src/northbridge/amd/agesa/family14/northbridge.c +++ b/src/northbridge/amd/agesa/family14/northbridge.c @@ -708,7 +708,7 @@ static void domain_set_resources(device_t dev) "adsr: mmio_basek=%08lx, basek=%08llx, limitk=%08llx\n", mmio_basek, basek, limitk);
- /* split the region to accomodate pci memory space */ + /* split the region to accommodate pci memory space */ if ((basek < 4 * 1024 * 1024) && (limitk > mmio_basek)) { if (basek <= mmio_basek) { unsigned pre_sizek; diff --git a/src/northbridge/amd/agesa/family15/northbridge.c b/src/northbridge/amd/agesa/family15/northbridge.c index aa9ec56..05acf96 100644 --- a/src/northbridge/amd/agesa/family15/northbridge.c +++ b/src/northbridge/amd/agesa/family15/northbridge.c @@ -799,7 +799,7 @@ static void domain_set_resources(device_t dev)
- /* split the region to accomodate pci memory space */ + /* split the region to accommodate pci memory space */ if ((basek < 4*1024*1024 ) && (limitk > mmio_basek)) { if (basek <= mmio_basek) { unsigned pre_sizek; diff --git a/src/northbridge/amd/agesa/family15tn/northbridge.c b/src/northbridge/amd/agesa/family15tn/northbridge.c index 8c931ad..51df5ee 100644 --- a/src/northbridge/amd/agesa/family15tn/northbridge.c +++ b/src/northbridge/amd/agesa/family15tn/northbridge.c @@ -773,7 +773,7 @@ static void domain_set_resources(device_t dev)
- /* split the region to accomodate pci memory space */ + /* split the region to accommodate pci memory space */ if ((basek < 4*1024*1024 ) && (limitk > mmio_basek)) { if (basek <= mmio_basek) { unsigned pre_sizek; diff --git a/src/northbridge/amd/agesa/family16kb/northbridge.c b/src/northbridge/amd/agesa/family16kb/northbridge.c index f557468..f421413 100644 --- a/src/northbridge/amd/agesa/family16kb/northbridge.c +++ b/src/northbridge/amd/agesa/family16kb/northbridge.c @@ -779,7 +779,7 @@ static void domain_set_resources(device_t dev)
- /* split the region to accomodate pci memory space */ + /* split the region to accommodate pci memory space */ if ((basek < 4*1024*1024 ) && (limitk > mmio_basek)) { if (basek <= mmio_basek) { unsigned pre_sizek; diff --git a/src/northbridge/amd/amdfam10/northbridge.c b/src/northbridge/amd/amdfam10/northbridge.c index 26e040f..223cd9f 100644 --- a/src/northbridge/amd/amdfam10/northbridge.c +++ b/src/northbridge/amd/amdfam10/northbridge.c @@ -1029,7 +1029,7 @@ static void amdfam10_domain_set_resources(device_t dev)
// printk(BIOS_DEBUG, "node %d : mmio_basek=%08x, basek=%08x, limitk=%08x\n", i, mmio_basek, basek, limitk);
- /* split the region to accomodate pci memory space */ + /* split the region to accommodate pci memory space */ if ( (basek < 4*1024*1024 ) && (limitk > mmio_basek) ) { if (basek <= mmio_basek) { unsigned pre_sizek; diff --git a/src/northbridge/amd/amdk8/northbridge.c b/src/northbridge/amd/amdk8/northbridge.c index b0acdf7..ee5dfd2 100644 --- a/src/northbridge/amd/amdk8/northbridge.c +++ b/src/northbridge/amd/amdk8/northbridge.c @@ -1034,7 +1034,7 @@ static void amdk8_domain_set_resources(device_t dev) // printk(BIOS_DEBUG, "node %d : mmio_basek=%08x, basek=%08x, limitk=%08x\n", i, mmio_basek, basek, limitk); //yhlu #endif
- /* See if I need to split the region to accomodate pci memory space */ + /* See if I need to split the region to accommodate pci memory space */ if ( (basek < 4*1024*1024 ) && (limitk > mmio_basek) ) { if (basek <= mmio_basek) { unsigned pre_sizek;
