Edward O'Callaghan (eocallaghan@alterapraxis.com) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/7628
commit 4fe3615922147f973a4878c459a0fe619a5fc351 Author: Edward O'Callaghan eocallaghan@alterapraxis.com Date: Tue Dec 2 21:04:13 2014 +1100
mainboard/hp/pavilion_m6_1035dx: Remove HUDSON_LEGACY_FREE
The Embedded Controller sits behind the LPC bridge and so needs LPC decodes to be enabled.
Remove the LPC decode enable out of agesawrapper.c. The enable is in fact done in: 'VOID FchInitResetLpcProgram(IN VOID *FchDataPtr)' which writes the magic '0xFF03FFD5' to register 0x44 of the PCI 14.3 LPC Bridge to enable LPC decodes when HUDSON_LEGACY_FREE is not defined.
Change-Id: Ia487d21faa0fceb2557dbce14ef8822116fada91 Signed-off-by: Edward O'Callaghan eocallaghan@alterapraxis.com --- src/mainboard/hp/pavilion_m6_1035dx/Kconfig | 4 ---- src/mainboard/hp/pavilion_m6_1035dx/agesawrapper.c | 7 ------- 2 files changed, 11 deletions(-)
diff --git a/src/mainboard/hp/pavilion_m6_1035dx/Kconfig b/src/mainboard/hp/pavilion_m6_1035dx/Kconfig index 12e0579..30e50c1 100644 --- a/src/mainboard/hp/pavilion_m6_1035dx/Kconfig +++ b/src/mainboard/hp/pavilion_m6_1035dx/Kconfig @@ -69,8 +69,4 @@ config VGA_BIOS_ID string default "1002,9900"
-config HUDSON_LEGACY_FREE - bool - default y - endif # BOARD_HP_PAVILION_M6_1035DX diff --git a/src/mainboard/hp/pavilion_m6_1035dx/agesawrapper.c b/src/mainboard/hp/pavilion_m6_1035dx/agesawrapper.c index 4cbaeaa..4417681 100644 --- a/src/mainboard/hp/pavilion_m6_1035dx/agesawrapper.c +++ b/src/mainboard/hp/pavilion_m6_1035dx/agesawrapper.c @@ -118,8 +118,6 @@ AGESA_STATUS agesawrapper_amdinitmmio(void) { AGESA_STATUS Status; UINT64 MsrReg; - UINT32 PciData; - PCI_ADDR PciAddress; AMD_CONFIG_PARAMS StdHeader;
/* @@ -136,11 +134,6 @@ AGESA_STATUS agesawrapper_amdinitmmio(void) MsrReg = MsrReg | 0x0000400000000000; LibAmdMsrWrite (0xC001001F, &MsrReg, &StdHeader);
- /* For serial port */ - PciData = 0xFF03FFD5; - PciAddress.AddressValue = MAKE_SBDFO (0, 0, 0x14, 0x3, 0x44); - LibAmdPciWrite(AccessWidth32, PciAddress, &PciData, &StdHeader); - /* Set ROM cache onto WP to decrease post time */ MsrReg = (0x0100000000ull - CACHE_ROM_SIZE) | 5ull; LibAmdMsrWrite (0x20C, &MsrReg, &StdHeader);
