Paul Menzel (paulepanter@users.sourceforge.net) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/3336
commit e4f44e690db1bf451aff93af3d66c7114781ecc7 Author: Paul Menzel paulepanter@users.sourceforge.net Date: Thu May 30 00:36:29 2013 +0200
gitconfig: Add sample checks shipped by git
Several checks are listed in git’s example hook files. So use the ones from the pre-commit hook. They check for non-ascii file names and whitespace errors.
Please run `make gitconfig` again to get the updated hooks.
Change-Id: Iad09ab62620b68e652cf55dc3f6d2033075989fb Signed-off-by: Paul Menzel paulepanter@users.sourceforge.net --- util/gitconfig/pre-commit | 42 ++++++++++++++++++++++++++++++++++++++++++ 1 file changed, 42 insertions(+)
diff --git a/util/gitconfig/pre-commit b/util/gitconfig/pre-commit index 8ab3e56..7043f42 100755 --- a/util/gitconfig/pre-commit +++ b/util/gitconfig/pre-commit @@ -1,2 +1,44 @@ #!/bin/sh exec make lint-stable + +if git rev-parse --verify HEAD >/dev/null 2>&1 +then + against=HEAD +else + # Initial commit: diff against an empty tree object + against=4b825dc642cb6eb9a060e54bf8d69288fbee4904 +fi + +# If you want to allow non-ascii filenames set this variable to true. +allownonascii=$(git config hooks.allownonascii) + +# Redirect output to stderr. +exec 1>&2 + +# Cross platform projects tend to avoid non-ascii filenames; prevent +# them from being added to the repository. We exploit the fact that the +# printable range starts at the space character and ends with tilde. +if [ "$allownonascii" != "true" ] && + # Note that the use of brackets around a tr range is ok here, (it's + # even required, for portability to Solaris 10's /usr/bin/tr), since + # the square bracket bytes happen to fall in the designated range. + test $(git diff --cached --name-only --diff-filter=A -z $against | + LC_ALL=C tr -d '[ -~]\0' | wc -c) != 0 +then + echo "Error: Attempt to add a non-ascii file name." + echo + echo "This can cause problems if you want to work" + echo "with people on other platforms." + echo + echo "To be portable it is advisable to rename the file ..." + echo + echo "If you know what you are doing you can disable this" + echo "check using:" + echo + echo " git config hooks.allownonascii true" + echo + exit 1 +fi + +# If there are whitespace errors, print the offending file names and fail. +exec git diff-index --check --cached $against --
