Andrey Petrov (andrey.petrov@intel.com) just uploaded a new patch set to gerrit, which you can find at https://review.coreboot.org/13301
commit 05f71aba76f26fea6bf12e792cbe053f8cba3214 Author: Alexandru Gagniuc alexandrux.gagniuc@intel.com Date: Tue Oct 6 17:16:41 2015 -0700
soc/apollolake: Add initial cache-as-ram setup for bootblock
This is the minimum setup needed to both get cache-as-ram setup and a C environment working. On apollolake, we only get 32 KiB of data loaded into an SRAM that is readonly to the main CPU. Due to this restriction we have to set CAR and a C environment very early on.
Change-Id: I65c51f972580609d2c1f03dfe2a86bc5d45d1e46 Signed-off-by: Alexandru Gagniuc alexandrux.gagniuc@intel.com Signed-off-by: Andrey Petrov andrey.petrov@intel.com --- src/soc/intel/apollolake/Kconfig | 27 ++++ src/soc/intel/apollolake/Makefile.inc | 6 + src/soc/intel/apollolake/bootblock/bootblock.c | 4 + src/soc/intel/apollolake/bootblock/cache_as_ram.S | 152 ++++++++++++++++++++++ src/soc/intel/apollolake/include/soc/bootblock.h | 4 + src/soc/intel/apollolake/placeholders.c | 8 ++ 6 files changed, 201 insertions(+)
diff --git a/src/soc/intel/apollolake/Kconfig b/src/soc/intel/apollolake/Kconfig index ca38494..e39fc9c 100644 --- a/src/soc/intel/apollolake/Kconfig +++ b/src/soc/intel/apollolake/Kconfig @@ -18,6 +18,7 @@ config CPU_SPECIFIC_OPTIONS select SSE2 select SUPPORT_CPU_UCODE_IN_CBFS # Misc options + select C_ENVIRONMENT_BOOTBLOCK select COLLECT_TIMESTAMPS select HAVE_INTEL_FIRMWARE select MMCONF_SUPPORT @@ -32,6 +33,32 @@ config CPU_SPECIFIC_OPTIONS select SOC_INTEL_COMMON select UDELAY_TSC
+config MMCONF_BASE_ADDRESS + hex "PCI MMIO Base Address" + default 0xe0000000 + +config IOSF_BASE_ADDRESS + hex "MMIO Base Address of sideband bus" + default 0xd0000000 + +config DCACHE_RAM_BASE + hex "Base address of cache-as-RAM" + default 0xfef00000 + +config DCACHE_RAM_SIZE + hex "Length in bytes of cache-as-RAM" + default 0x80000 + help + The size of the cache-as-ram region required during bootblock + and/or romstage. + +config DCACHE_BSP_STACK_SIZE + hex + default 0x4000 + help + The amount of anticipated stack usage in CAR by bootblock and + other stages. + config CPU_ADDR_BITS int default 36 diff --git a/src/soc/intel/apollolake/Makefile.inc b/src/soc/intel/apollolake/Makefile.inc index b37cf8d..b429b29 100644 --- a/src/soc/intel/apollolake/Makefile.inc +++ b/src/soc/intel/apollolake/Makefile.inc @@ -7,8 +7,14 @@ subdirs-y += ../../../cpu/x86/mtrr subdirs-y += ../../../cpu/x86/smm subdirs-y += ../../../cpu/x86/tsc
+bootblock-y += bootblock/bootblock.c +bootblock-y += bootblock/cache_as_ram.S +bootblock-y += placeholders.c + romstage-y += placeholders.c smm-y += placeholders.c ramstage-y += placeholders.c
+CPPFLAGS_common += -I$(src)/soc/intel/apollolake/include + endif diff --git a/src/soc/intel/apollolake/bootblock/bootblock.c b/src/soc/intel/apollolake/bootblock/bootblock.c new file mode 100644 index 0000000..a5f3beb --- /dev/null +++ b/src/soc/intel/apollolake/bootblock/bootblock.c @@ -0,0 +1,4 @@ +#include <soc/bootblock.h> +void asmlinkage bootblock_c_entry(void) +{ +} diff --git a/src/soc/intel/apollolake/bootblock/cache_as_ram.S b/src/soc/intel/apollolake/bootblock/cache_as_ram.S new file mode 100644 index 0000000..c81fe0a --- /dev/null +++ b/src/soc/intel/apollolake/bootblock/cache_as_ram.S @@ -0,0 +1,152 @@ +/* + * This file is part of the coreboot project. + * + * Copyright (C) 2015-2016 Intel Corp. + * (Written by Andrey Petrov andrey.petrov@intel.com for Intel Corp.) + * (Written by Alexandru Gagniuc alexandrux.gagniuc@intel.com for Intel Corp.) + * + * This program is free software; you can redistribute it and/or modify + * it under the terms of the GNU General Public License as published by + * the Free Software Foundation; either version 2 of the License, or + * (at your option) any later version. + */ + +#include <device/pci_def.h> +#include <cpu/x86/mtrr.h> +#include <cpu/x86/cache.h> +#include <cpu/x86/cr.h> +#include <cpu/x86/post_code.h> + +#define EVICT_CTL_MSR 0x2e0 + +.global bootblock_pre_c_entry +bootblock_pre_c_entry: + /* + * eax: BIST value + */ + movd %eax, %mm2 + +.global cache_as_ram +cache_as_ram: + post_code(0x21) + + /* Clear/disable fixed MTRRs */ + mov $fixed_mtrr_list_size, %ebx + xor %eax, %eax + xor %edx, %edx +clear_fixed_mtrr: + add $-2, %ebx + movzwl fixed_mtrr_list(%ebx), %ecx + wrmsr + jnz clear_fixed_mtrr + + post_code(0x22) + + /* Figure put how many MTRRs we have, and clear them out */ + mov $MTRR_CAP_MSR, %ecx + rdmsr + movzb %al, %ebx /* Number of variable MTRRs */ + mov $MTRR_PHYS_BASE(0), %ecx + xor %eax, %eax + xor %edx, %edx + +clear_var_mtrr: + wrmsr + inc %ecx + wrmsr + inc %ecx + dec %ebx + jnz clear_var_mtrr + + post_code(0x23) + + /* Configure default memory type to uncacheable (UC) */ + mov $MTRR_DEF_TYPE_MSR, %ecx + rdmsr + and $MTRR_DEF_TYPE_MASK, %eax + wrmsr + + post_code(0x24) + + /* Configure CAR region as write-back (WB) */ + mov $MTRR_PHYS_BASE(0), %ecx + mov $CONFIG_DCACHE_RAM_BASE, %eax + or $MTRR_TYPE_WRBACK, %eax + xor %edx,%edx + wrmsr + + /* Configure the MTRR mask for the size region */ + mov $MTRR_PHYS_MASK(0), %ecx + mov $~(CONFIG_DCACHE_RAM_SIZE - 1), %eax /* size mask */ + or $MTRR_PHYS_MASK_VALID, %eax + wrmsr + + post_code(0x25) + + /* Enable variable MTRRs */ + mov $MTRR_DEF_TYPE_MSR, %ecx + rdmsr + or $MTRR_DEF_TYPE_EN, %eax + wrmsr + + /* Enable caching */ + mov %cr0, %eax + and $~(CR0_CD | CR0_NW), %eax + invd + mov %eax, %cr0 + + /* Disable cache eviction (setup stage) */ + mov $EVICT_CTL_MSR, %ecx + rdmsr + or $0x1, %eax + wrmsr + + post_code(0x26) + + /* Clear the cache memory region. This will also fill up the cache */ + mov $CONFIG_DCACHE_RAM_BASE, %edi + mov $(CONFIG_DCACHE_RAM_SIZE >> 2), %ecx + xor %eax, %eax + rep stos %eax, %es:(%edi) + + post_code(0x27) + + /* Disable cache eviction (run stage) */ + mov $EVICT_CTL_MSR, %ecx + rdmsr + or $0x2, %eax + wrmsr + + post_code(0x28) + +car_init_done: + + /* Setup bootblock stack */ + mov $_car_stack_end, %esp + +before_carstage: + post_code(0x2b) + + /* We can call into C functions now */ + call bootblock_c_entry + + /* Never reached */ + +.halt_forever: + post_code(POST_DEAD_CODE) + hlt + jmp .halt_forever + +fixed_mtrr_list: + .word MTRR_FIX_64K_00000 + .word MTRR_FIX_16K_80000 + .word MTRR_FIX_16K_A0000 + .word MTRR_FIX_4K_C0000 + .word MTRR_FIX_4K_C8000 + .word MTRR_FIX_4K_D0000 + .word MTRR_FIX_4K_D8000 + .word MTRR_FIX_4K_E0000 + .word MTRR_FIX_4K_E8000 + .word MTRR_FIX_4K_F0000 + .word MTRR_FIX_4K_F8000 +fixed_mtrr_list_size = . - fixed_mtrr_list diff --git a/src/soc/intel/apollolake/include/soc/bootblock.h b/src/soc/intel/apollolake/include/soc/bootblock.h new file mode 100644 index 0000000..1cf9b70 --- /dev/null +++ b/src/soc/intel/apollolake/include/soc/bootblock.h @@ -0,0 +1,4 @@ +#ifndef _SOC_APOLLOLAKE_BOOTBLOCK_H_ +#define _SOC_APOLLOLAKE_BOOTBLOCK_H_ +void asmlinkage bootblock_c_entry(void); +#endif diff --git a/src/soc/intel/apollolake/placeholders.c b/src/soc/intel/apollolake/placeholders.c index cf0fe36..3a818eb 100644 --- a/src/soc/intel/apollolake/placeholders.c +++ b/src/soc/intel/apollolake/placeholders.c @@ -1,5 +1,7 @@ #include <cbmem.h> #include <cpu/x86/smm.h> +#include <delay.h> +#include <rules.h>
void *cbmem_top(void) { @@ -9,3 +11,9 @@ void *cbmem_top(void) void southbridge_smi_set_eos(void) { } + +#if ENV_BOOTBLOCK +void init_timer(void) +{ +} +#endif
