Attention is currently required from: Tarun Tuli, Angel Pons, Lean Sheng Tan, Werner Zeh.
Hello build bot (Jenkins), Tarun Tuli, Angel Pons, Arthur Heymans, Lean Sheng Tan, Werner Zeh,
https://review.coreboot.org/c/coreboot/+/71575
Change subject: soc/intel/alderlake: Disable Intel TXT ......................................................................
This patch makes the call into TXT lib in order to disable the TXT.
TEST=Able to perform disable_txt and unlock memory which helped to access VGA framebuffer prior calling into FSP-M.
Signed-off-by: Subrata Banik subratabanik@google.com Change-Id: I9dd7c5492a5f45eef0dd9e836cc2da1844c78919 --- M src/soc/intel/alderlake/Kconfig M src/soc/intel/alderlake/romstage/romstage.c 2 files changed, 23 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/75/71575/3
