Patrick Georgi has submitted this change. ( https://review.coreboot.org/c/coreboot/+/63368 )
Change subject: mb/google/brya/var/nereid: Add WLAN power sequence ......................................................................
There are currently two issues related to the WLAN power sequencing on nereid: - If the EN pin GPP_B11 is not high during cold boot, the SoC gets stuck in S3. - During warm reboot, if we only assert RST without pulling the power low, then the kernel crashes.
As a workaround while we investigate these issues, we pull the EN high in S5, then actively drive it low in bootblock and high in romstage to make sure it goes low during warm reboot.
BUG=b:227694137, b:225261075 TEST=Cold boot succeeds, and there's no kernel crash during warm reboot.
Change-Id: I1ca46d9649eff3f96a0e77db594d87288b29a83a Signed-off-by: Reka Norman rekanorman@google.com Reviewed-on: https://review.coreboot.org/c/coreboot/+/63368 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Kangheui Won khwon@chromium.org Reviewed-by: Sam McNally sammc@google.com --- M src/mainboard/google/brya/variants/nereid/gpio.c 1 file changed, 15 insertions(+), 0 deletions(-)
Approvals: build bot (Jenkins): Verified Kangheui Won: Looks good to me, approved Sam McNally: Looks good to me, approved
diff --git a/src/mainboard/google/brya/variants/nereid/gpio.c b/src/mainboard/google/brya/variants/nereid/gpio.c index f9ef8c9..f011e2f 100644 --- a/src/mainboard/google/brya/variants/nereid/gpio.c +++ b/src/mainboard/google/brya/variants/nereid/gpio.c @@ -41,6 +41,10 @@
/* Early pad configuration in bootblock */ static const struct pad_config early_gpio_table[] = { + /* B11 : PMCALERT# ==> EN_PP3300_WLAN_X */ + PAD_CFG_GPO(GPP_B11, 0, DEEP), + /* H20 : IMGCLKOUT1 ==> WLAN_PERST_L */ + PAD_CFG_GPO(GPP_H20, 0, DEEP), /* A13 : GPP_A13 ==> GSC_SOC_INT_ODL */ PAD_CFG_GPI_APIC(GPP_A13, NONE, PLTRST, LEVEL, INVERT), /* E12 : THC0_SPI1_IO1 ==> SOC_WP_OD */ @@ -57,6 +61,11 @@ PAD_CFG_NF(GPP_H11, NONE, DEEP, NF2), };
+static const struct pad_config romstage_gpio_table[] = { + /* B11 : PMCALERT# ==> EN_PP3300_WLAN_X */ + PAD_CFG_GPO(GPP_B11, 1, DEEP), +}; + const struct pad_config *variant_gpio_override_table(size_t *num) { *num = ARRAY_SIZE(override_gpio_table); @@ -68,3 +77,9 @@ *num = ARRAY_SIZE(early_gpio_table); return early_gpio_table; } + +const struct pad_config *variant_romstage_gpio_table(size_t *num) +{ + *num = ARRAY_SIZE(romstage_gpio_table); + return romstage_gpio_table; +}
3 is the latest approved patch-set. No files were changed between the latest approved patch-set and the submitted one.
