Attention is currently required from: Lean Sheng Tan.
Hello build bot (Jenkins), Angel Pons, Lean Sheng Tan,
https://review.coreboot.org/c/coreboot/+/68669
Change subject: soc/intel/elkhartlake: Fix incorrect divider for MDIO clock ......................................................................
After some measurements it turned out that Elkhart Lake uses a higher CSR clock internally from which the MDIO clock is derived. In order to stay compliant with the specification, the MDIO clock needs to be lower than 2.5 MHz. Therefore, the divider needs to be 102 and not 62. This patch changes the define to match the new divider value and uses this new define at the appropriate place.
Test=Measure the MDIO clock rate on mc_ehl2 which results in 2 MHz.
Change-Id: Idf498c3547530dfa395f54488ef244e787062e34 Signed-off-by: Werner Zeh werner.zeh@siemens.com --- M src/soc/intel/elkhartlake/include/soc/tsn_gbe.h M src/soc/intel/elkhartlake/tsn_gbe.c 2 files changed, 22 insertions(+), 3 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/69/68669/2
