Nicolas Reinecke (nr@das-labor.org) just uploaded a new patch set to gerrit, which you can find at http://review.coreboot.org/6759
commit 3fb27d3177684780c9583b45676e138550312846 Author: Nicolas Reinecke nr@das-labor.org Date: Sun Aug 24 22:12:37 2014 +0200
lenovo/t520: update Kconfig
override default ivy BIOS_PCI_ID add model & part number Remove ARCH_X86 as is in, fd33781 Move ARCH_* from board/Kconfig to cpu or soc Kconfig.
Change-Id: I61dc6434de7af2d8672f784df87a8b9d3f0fb068 Signed-off-by: Nicolas Reinecke nr@das-labor.org --- src/mainboard/lenovo/t520/Kconfig | 11 +++++++++-- 1 file changed, 9 insertions(+), 2 deletions(-)
diff --git a/src/mainboard/lenovo/t520/Kconfig b/src/mainboard/lenovo/t520/Kconfig index 5d43ea1..0f0fd88 100644 --- a/src/mainboard/lenovo/t520/Kconfig +++ b/src/mainboard/lenovo/t520/Kconfig @@ -2,7 +2,6 @@ if BOARD_LENOVO_T520
config BOARD_SPECIFIC_OPTIONS # dummy def_bool y - select ARCH_X86 select CPU_INTEL_SOCKET_RPGA988B select NORTHBRIDGE_INTEL_SANDYBRIDGE select SOUTHBRIDGE_INTEL_BD82X6X @@ -36,7 +35,11 @@ config MAINBOARD_DIR
config MAINBOARD_PART_NUMBER string - default "XXXXXXX" + default "4242W1A" + +config MAINBOARD_VERSION + string + default "ThinkPad T520"
config MMCONF_BASE_ADDRESS hex @@ -62,6 +65,10 @@ config DRAM_GATE_GPIO int default 10
+config VGA_BIOS_ID + string + default "8086,0126" + config VGA_BIOS_FILE string default "pci8086,0126.rom"
