Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/47301 )
Change subject: soc/intel/xeon_sp: Improve generating PCH IOAPIC MADT entry ......................................................................
The PCH IOAPIC ID is 0x8 so it needs to be generated before the IIO IOAPICs. Since we will get rid of the ioapic_id array this makes it more readable.
Change-Id: I64a3b259e438ef666fb68a433cceda10aebdb1bf Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/soc/intel/xeon_sp/acpi.c 1 file changed, 17 insertions(+), 12 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/01/47301/1
diff --git a/src/soc/intel/xeon_sp/acpi.c b/src/soc/intel/xeon_sp/acpi.c index fcd5f00..c70945a 100644 --- a/src/soc/intel/xeon_sp/acpi.c +++ b/src/soc/intel/xeon_sp/acpi.c @@ -101,6 +101,16 @@ current = xeonsp_acpi_create_madt_lapics(current);
cur_index = 0; + { + assert(cur_index < ARRAY_SIZE(ioapic_ids)); + assert(cur_index < ARRAY_SIZE(gsi_bases)); + int ioapic_id = ioapic_ids[cur_index]; + int gsi_base = gsi_bases[cur_index]; + current += add_madt_ioapic(current, 0, 0, ioapic_id, + hob->PlatformData.IIO_resource[0].StackRes[0].IoApicBase, + gsi_base); + ++cur_index; + }
for (int socket = 0; socket < hob->PlatformData.numofIIO; ++socket) { for (int stack = 0; stack < MAX_IIO_STACK; ++stack) { @@ -111,22 +121,17 @@ assert(cur_index < ARRAY_SIZE(gsi_bases)); int ioapic_id = ioapic_ids[cur_index]; int gsi_base = gsi_bases[cur_index]; - current += add_madt_ioapic(current, socket, stack, ioapic_id, ri->IoApicBase, gsi_base); - ++cur_index; - + uint32_t ioapic_base = ri->IoApicBase; /* * Stack 0 has non-PCH IOAPIC and PCH IOAPIC. * Add entry for PCH IOAPIC. */ - if (stack == 0 && socket == 0) { /* PCH IOAPIC */ - assert(cur_index < ARRAY_SIZE(ioapic_ids)); - assert(cur_index < ARRAY_SIZE(gsi_bases)); - ioapic_id = ioapic_ids[cur_index]; - gsi_base = gsi_bases[cur_index]; - current += add_madt_ioapic(current, socket, stack, ioapic_id, - ri->IoApicBase + 0x1000, gsi_base); - ++cur_index; - } + if (stack == 0 && socket == 0) + ioapic_base += 0x1000; + + current += add_madt_ioapic(current, socket, stack, ioapic_id, ioapic_base, + gsi_base); + ++cur_index; } }
build bot (Jenkins) has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47301 )
Patch Set 1:
(2 comments)
https://review.coreboot.org/c/coreboot/+/47301/1/src/soc/intel/xeon_sp/acpi.... File src/soc/intel/xeon_sp/acpi.c:
https://review.coreboot.org/c/coreboot/+/47301/1/src/soc/intel/xeon_sp/acpi.... PS1, Line 110: hob->PlatformData.IIO_resource[0].StackRes[0].IoApicBase, line over 96 characters
https://review.coreboot.org/c/coreboot/+/47301/1/src/soc/intel/xeon_sp/acpi.... PS1, Line 132: current += add_madt_ioapic(current, socket, stack, ioapic_id, ioapic_base, line over 96 characters
Hello build bot (Jenkins), Marc Jones, Jonathan Zhang, Patrick Rudolph,
Change-Id: I64a3b259e438ef666fb68a433cceda10aebdb1bf Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/soc/intel/xeon_sp/acpi.c 1 file changed, 16 insertions(+), 9 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/01/47301/2
Marc Jones has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47301 )
Patch Set 2: Code-Review+2
Patch Set 2:
(2 comments)
https://review.coreboot.org/c/coreboot/+/47301/2/src/soc/intel/xeon_sp/acpi.... File src/soc/intel/xeon_sp/acpi.c:
https://review.coreboot.org/c/coreboot/+/47301/2/src/soc/intel/xeon_sp/acpi.... PS2, Line 111: hob->PlatformData.IIO_resource[0].StackRes[0].IoApicBase, line over 96 characters
https://review.coreboot.org/c/coreboot/+/47301/2/src/soc/intel/xeon_sp/acpi.... PS2, Line 137: current += add_madt_ioapic(current, socket, stack, ioapic_id, ioapic_base, line over 96 characters
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/01/47301/3
Patch Set 3:
https://review.coreboot.org/c/coreboot/+/47301/3/src/soc/intel/xeon_sp/acpi.... File src/soc/intel/xeon_sp/acpi.c:
https://review.coreboot.org/c/coreboot/+/47301/3/src/soc/intel/xeon_sp/acpi.... PS3, Line 111: hob->PlatformData.IIO_resource[0].StackRes[0].IoApicBase, line over 96 characters
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/01/47301/4
Patch Set 4:
https://review.coreboot.org/c/coreboot/+/47301/4/src/soc/intel/xeon_sp/acpi.... File src/soc/intel/xeon_sp/acpi.c:
https://review.coreboot.org/c/coreboot/+/47301/4/src/soc/intel/xeon_sp/acpi.... PS4, Line 111: hob->PlatformData.IIO_resource[0].StackRes[0].IoApicBase, line over 96 characters
Patch Set 5:
https://review.coreboot.org/c/coreboot/+/47301/5/src/soc/intel/xeon_sp/acpi.... File src/soc/intel/xeon_sp/acpi.c:
https://review.coreboot.org/c/coreboot/+/47301/5/src/soc/intel/xeon_sp/acpi.... PS5, Line 111: hob->PlatformData.IIO_resource[0].StackRes[0].IoApicBase, line over 96 characters
Patch Set 6:
https://review.coreboot.org/c/coreboot/+/47301/6/src/soc/intel/xeon_sp/acpi.... File src/soc/intel/xeon_sp/acpi.c:
https://review.coreboot.org/c/coreboot/+/47301/6/src/soc/intel/xeon_sp/acpi.... PS6, Line 111: hob->PlatformData.IIO_resource[0].StackRes[0].IoApicBase, line over 96 characters
Patch Set 6:
(2 comments)
A couple of nits. It is almost ready to +2.
https://review.coreboot.org/c/coreboot/+/47301/6/src/soc/intel/xeon_sp/acpi.... PS6, Line 108: int ioapic_id = ioapic_ids[cur_index]; : int gsi_base = gsi_bases[cur_index]; Is there a reason to not declare these above so we don't don't do it twice and need a new scope here? A comment that this is setting the PCH IOAPIC and then the IIO APICs would be good. I know it is easier to see that in the next patch.
https://review.coreboot.org/c/coreboot/+/47301/6/src/soc/intel/xeon_sp/acpi.... PS6, Line 130: * Add entry for PCH IOAPIC. Does this comment need an update? I think that this is the IIO APIC entry.
Hello Marc Jones, build bot (Jenkins), Jonathan Zhang, Patrick Rudolph,
Change-Id: I64a3b259e438ef666fb68a433cceda10aebdb1bf Signed-off-by: Arthur Heymans arthur@aheymans.xyz --- M src/soc/intel/xeon_sp/acpi.c 1 file changed, 18 insertions(+), 15 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/01/47301/7
Arthur Heymans has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/47301 )
Patch Set 7:
(2 comments)
Is there a reason to not declare these above so we don't don't do it twice and need a new scope here […]
Done
Done
Patch Set 7: Code-Review+2
Arthur Heymans has submitted this change. ( https://review.coreboot.org/c/coreboot/+/47301 )
Change-Id: I64a3b259e438ef666fb68a433cceda10aebdb1bf Signed-off-by: Arthur Heymans arthur@aheymans.xyz Reviewed-on: https://review.coreboot.org/c/coreboot/+/47301 Tested-by: build bot (Jenkins) no-reply@coreboot.org Reviewed-by: Marc Jones marc@marcjonesconsulting.com --- M src/soc/intel/xeon_sp/acpi.c 1 file changed, 18 insertions(+), 15 deletions(-)
Approvals: build bot (Jenkins): Verified Marc Jones: Looks good to me, approved
diff --git a/src/soc/intel/xeon_sp/acpi.c b/src/soc/intel/xeon_sp/acpi.c index f747f87..3b4b713 100644 --- a/src/soc/intel/xeon_sp/acpi.c +++ b/src/soc/intel/xeon_sp/acpi.c @@ -86,6 +86,8 @@ unsigned long acpi_fill_madt(unsigned long current) { int cur_index; + int ioapic_id; + int gsi_base; const IIO_UDS *hob = get_iio_uds();
/* With XEON-SP FSP, PCH IOAPIC is allocated with first 120 GSIs. */ @@ -102,6 +104,12 @@ current = xeonsp_acpi_create_madt_lapics(current);
cur_index = 0; + ioapic_id = ioapic_ids[cur_index]; + gsi_base = gsi_bases[cur_index]; + current += add_madt_ioapic(current, 0, 0, ioapic_id, + hob->PlatformData.IIO_resource[0].StackRes[0].IoApicBase, + gsi_base); + ++cur_index;
for (int socket = 0; socket < hob->PlatformData.numofIIO; ++socket) { for (int stack = 0; stack < MAX_IIO_STACK; ++stack) { @@ -111,25 +119,20 @@ continue; assert(cur_index < ARRAY_SIZE(ioapic_ids)); assert(cur_index < ARRAY_SIZE(gsi_bases)); - int ioapic_id = ioapic_ids[cur_index]; - int gsi_base = gsi_bases[cur_index]; - current += add_madt_ioapic(current, socket, stack, ioapic_id, - ri->IoApicBase, gsi_base); - ++cur_index; + ioapic_id = ioapic_ids[cur_index]; + gsi_base = gsi_bases[cur_index]; + uint32_t ioapic_base = ri->IoApicBase;
/* * Stack 0 has non-PCH IOAPIC and PCH IOAPIC. - * Add entry for PCH IOAPIC. + * The IIO IOAPIC is placed at 0x1000 from the reported base. */ - if (stack == 0 && socket == 0) { /* PCH IOAPIC */ - assert(cur_index < ARRAY_SIZE(ioapic_ids)); - assert(cur_index < ARRAY_SIZE(gsi_bases)); - ioapic_id = ioapic_ids[cur_index]; - gsi_base = gsi_bases[cur_index]; - current += add_madt_ioapic(current, socket, stack, ioapic_id, - ri->IoApicBase + 0x1000, gsi_base); - ++cur_index; - } + if (stack == 0 && socket == 0) + ioapic_base += 0x1000; + + current += add_madt_ioapic(current, socket, stack, ioapic_id, + ioapic_base, gsi_base); + ++cur_index; } }
