Attention is currently required from: Jérémy Compostella.
Arthur Heymans has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/80625?usp=email )
Change subject: arch/x86/bootblock.ld: Align the base of bootblock downwards ......................................................................
Instead of using some aritmetics that sometimes works, use the largest alignment necessary (page tables) and align downwards in the linker script.
This fixes linking failing when linking in page tables inside the bootblock.
This can result in a slight increase in bootblock size of at most 4096 - 512 bytes.
Signed-off-by: Arthur Heymans arthur@aheymans.xyz Change-Id: I78c6ba6e250ded3f04b12cd0c20b18cb653a1506 --- M src/arch/x86/bootblock.ld 1 file changed, 4 insertions(+), 7 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/25/80625/1
diff --git a/src/arch/x86/bootblock.ld b/src/arch/x86/bootblock.ld index d59eb27..6547985 100644 --- a/src/arch/x86/bootblock.ld +++ b/src/arch/x86/bootblock.ld @@ -17,19 +17,16 @@ . = _ebootblock - CONFIG_C_ENV_BOOTBLOCK_SIZE; #else . = BOOTBLOCK_TOP - PROGRAM_SZ; - . = ALIGN(64); + /* Page tables need to be at a 4K boundary so align the bootblock downwards */ + . = ALIGN(4096); + . -= 4096; #endif
_bootblock = .;
INCLUDE "bootblock/lib/program.ld"
- /* - * Allocation reserves extra space here. Alignment requirements - * may cause the total size of a section to change when the start - * address gets applied. - */ - PROGRAM_SZ = SIZEOF(.text) + 512; + PROGRAM_SZ = SIZEOF(.text);
. = MIN(_ECFW_PTR, MIN(_ID_SECTION, _FIT_POINTER)) - EARLYASM_SZ; . = CONFIG(SIPI_VECTOR_IN_ROM) ? ALIGN(4096) : ALIGN(16);
