Attention is currently required from: Patrick Rudolph. Angel Pons has uploaded this change for review. ( https://review.coreboot.org/c/coreboot/+/58284 )
Change subject: soc/intel/broadwell: Clarify PCIe Non Common Clock mode ......................................................................
The "force ASPM" setting actually controls Non Common Clock mode with Spread Spectrum Clocking. Rename the associated variables accordingly and expand the comments according to document 535127 (BDW PCH-LP BS).
Change-Id: I4174f6302d62aea81aa74515e2e3135ee324aa7c Signed-off-by: Angel Pons th3fanbus@gmail.com --- M src/mainboard/google/auron/devicetree.cb M src/mainboard/google/auron/variants/buddy/overridetree.cb M src/mainboard/google/auron/variants/samus/overridetree.cb M src/mainboard/google/jecht/devicetree.cb M src/soc/intel/broadwell/pch/chip.h M src/soc/intel/broadwell/pch/pcie.c 6 files changed, 23 insertions(+), 22 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/84/58284/1
diff --git a/src/mainboard/google/auron/devicetree.cb b/src/mainboard/google/auron/devicetree.cb index 39c6554..6e912cd 100644 --- a/src/mainboard/google/auron/devicetree.cb +++ b/src/mainboard/google/auron/devicetree.cb @@ -42,8 +42,8 @@ register "sata_port_map" = "0x1" register "sio_acpi_mode" = "1"
- # Force enable ASPM for PCIe Port1 - register "pcie_port_force_aspm" = "0x01" + # Force enable Non Common Clock mode with SSC for PCIe Port1 + register "pcie_port_force_ncc_ssc" = "0x01"
# Disable PCIe CLKOUT 2-5 and CLKOUT_XDP register "icc_clock_disable" = "0x013c0000" diff --git a/src/mainboard/google/auron/variants/buddy/overridetree.cb b/src/mainboard/google/auron/variants/buddy/overridetree.cb index 0570cdc..ffa2d69 100644 --- a/src/mainboard/google/auron/variants/buddy/overridetree.cb +++ b/src/mainboard/google/auron/variants/buddy/overridetree.cb @@ -29,8 +29,8 @@ register "sata_port0_gen3_dtle" = "0x5" register "sata_port1_gen3_dtle" = "0x5"
- # Force enable ASPM for PCIe Port 5 - register "pcie_port_force_aspm" = "0x10" + # Force enable Non Common Clock mode with SSC for PCIe Port 5 + register "pcie_port_force_ncc_ssc" = "0x10"
# Enable port coalescing register "pcie_port_coalesce" = "1" diff --git a/src/mainboard/google/auron/variants/samus/overridetree.cb b/src/mainboard/google/auron/variants/samus/overridetree.cb index 0a92efe..e623387 100644 --- a/src/mainboard/google/auron/variants/samus/overridetree.cb +++ b/src/mainboard/google/auron/variants/samus/overridetree.cb @@ -34,8 +34,8 @@ # Set I2C0 to 1.8V register "sio_i2c0_voltage" = "1"
- # Force enable ASPM for PCIe Port 3 - register "pcie_port_force_aspm" = "0x04" + # Force enable Non Common Clock mode with SSC for PCIe Port 3 + register "pcie_port_force_ncc_ssc" = "0x04" register "pcie_port_coalesce" = "1"
# Disable PCIe CLKOUT 1-5 and CLKOUT_XDP diff --git a/src/mainboard/google/jecht/devicetree.cb b/src/mainboard/google/jecht/devicetree.cb index 08b2c95..a41bf59 100644 --- a/src/mainboard/google/jecht/devicetree.cb +++ b/src/mainboard/google/jecht/devicetree.cb @@ -34,8 +34,8 @@ register "sata_port_map" = "0x1" register "sata_devslp_disable" = "0x1"
- # Force enable ASPM for PCIe Port 4 - register "pcie_port_force_aspm" = "0x10" + # Force enable Non Common Clock mode with SSC for PCIe Port 4 + register "pcie_port_force_ncc_ssc" = "0x10"
# Enable port coalescing register "pcie_port_coalesce" = "1" diff --git a/src/soc/intel/broadwell/pch/chip.h b/src/soc/intel/broadwell/pch/chip.h index 2164a31..6153ffe 100644 --- a/src/soc/intel/broadwell/pch/chip.h +++ b/src/soc/intel/broadwell/pch/chip.h @@ -49,8 +49,8 @@ /* Enable linear PCIe Root Port function numbers starting at zero */ uint8_t pcie_port_coalesce;
- /* Force root port ASPM configuration with port bitmap */ - uint8_t pcie_port_force_aspm; + /* Force root port Non-Common Clock mode with SSC with port bitmap */ + uint8_t pcie_port_force_ncc_ssc;
/* Put SerialIO devices into ACPI mode instead of a PCI device */ uint8_t sio_acpi_mode; diff --git a/src/soc/intel/broadwell/pch/pcie.c b/src/soc/intel/broadwell/pch/pcie.c index 6976c69..43dfe79 100644 --- a/src/soc/intel/broadwell/pch/pcie.c +++ b/src/soc/intel/broadwell/pch/pcie.c @@ -436,7 +436,7 @@ static void pch_pcie_early(struct device *dev) { const struct soc_intel_broadwell_pch_config *config = config_of(dev); - int do_aspm = 0; + int pcie_ncc_ssc = 0; int rp = root_port_number(dev);
switch (rp) { @@ -448,38 +448,39 @@ * Bits 31:28 of b0d28f0 0x32c register correspond to * Root Ports 4:1. */ - do_aspm = !!(rpc.b0d28f0_32c & (1 << (28 + rp - 1))); + pcie_ncc_ssc = !!(rpc.b0d28f0_32c & (1 << (28 + rp - 1))); break; case 5: /* * Bit 28 of b0d28f4 0x32c register corresponds to * Root Port 5. */ - do_aspm = !!(rpc.b0d28f4_32c & (1 << 28)); + pcie_ncc_ssc = !!(rpc.b0d28f4_32c & (1 << 28)); break; case 6: /* * Bit 29 of b0d28f5 0x32c register corresponds to * Root Port 6. */ - do_aspm = !!(rpc.b0d28f5_32c & (1 << 29)); + pcie_ncc_ssc = !!(rpc.b0d28f5_32c & (1 << 29)); break; }
- /* Allow ASPM to be forced on in devicetree */ - if ((config->pcie_port_force_aspm & (1 << (rp - 1)))) - do_aspm = 1; + /* Allow Non Common Clock mode with Spread Spectrum to be forced on in devicetree */ + if (config && (config->pcie_port_force_ncc_ssc & (1 << (rp - 1)))) + pcie_ncc_ssc = 1;
- printk(BIOS_DEBUG, "PCIe Root Port %d ASPM is %sabled\n", - rp, do_aspm ? "en" : "dis"); + printk(BIOS_DEBUG, "PCIe Root Port %d Non Common Clock mode with SSC is %sabled\n", + rp, pcie_ncc_ssc ? "en" : "dis");
- if (do_aspm) { - /* Set ASPM bits in MPC2 register. */ + if (pcie_ncc_ssc) { + /* Disable ASPM L0s support in MPC2 register. */ pci_update_config32(dev, 0xd4, ~(0x3 << 2), (1 << 4) | (0x2 << 2));
/* Set unique clock exit latency in MPC register. */ pci_update_config32(dev, 0xd8, ~(0x7 << 18), (0x7 << 18));
+ /* Increase the elastic buffer pointer half full pointer values by 2. */ switch (rp) { case 1: pcie_add_0x0202000_iobp(0xe9002440); @@ -522,7 +523,7 @@ pci_update_config32(dev, 0x318, ~(0xffff << 16), (0x1414 << 16));
/* Set L1 exit latency in LCAP register. */ - if ((pci_read_config8(dev, 0xf5) & 0x1) || do_aspm) + if ((pci_read_config8(dev, 0xf5) & 0x1) || pcie_ncc_ssc) pci_update_config32(dev, 0x4c, ~(0x7 << 15), (0x4 << 15)); else pci_update_config32(dev, 0x4c, ~(0x7 << 15), (0x2 << 15));
