Attention is currently required from: Arthur Heymans, Felix Singer, Subrata Banik, Tim Wawrzynczak, Angel Pons, Lean Sheng Tan, Werner Zeh, Patrick Rudolph, EricR Lai.
Sridhar Siricilla has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/60405 )
Change subject: soc/intel/common/cse: Add `finalize` operation for CSE
Patch Set 25:
File src/soc/intel/common/block/cse/cse.c:
https://review.coreboot.org/c/coreboot/+/60405/comment/29563125_6435994c
PS24, Line 1195: static void cse_final(struct device *dev)
: if (CONFIG(SKIP_FSP_NOTIFY_PHASE_READY_TO_BOOT)) {
: cse_send_end_of_post();
: cse_control_global_reset_lock();
: if (CONFIG(DISABLE_HECI1_AT_PRE_BOOT)) {
: cse_set_to_d0i3();
: heci1_disable();
: if (CONFIG(SKIP_FSP_NOTIFY_PHASE_END_OF_FIRMWARE))
: heci_set_to_d0i3();
CB_INTEL_SOC_RUN_OPS_BEFORE_PAYLOAD_LAUNCH?? seriously?! A Kconfig option that says coreboot runs […]
Even thats the case with FSP-NotifyPhase API call as well today, Please check the log below:
NotifyPhaseApi() - Begin [Phase: 00000040]
FSP Ready To Boot ...
NotifyPhaseApi() - End [Status: 0x00000000]
PROGRESS CODE: V0000487F I0
PROGRESS CODE: V00002800 I0
NotifyPhaseApi() - Begin [Phase: 000000F0]
FSP End of Firmware ...
Because coreboot chose to give call those FSP Notify APIs sequentially. But, the flow can be changed later with existing desing. But, can your new flow allows such flexibility?
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: I70bde33f77026e8be165ff082defe3cab6686ec7
Gerrit-Change-Number: 60405
Gerrit-PatchSet: 25
Gerrit-Owner: Subrata Banik
subratabanik@google.com
Gerrit-Reviewer: Angel Pons
th3fanbus@gmail.com
Gerrit-Reviewer: EricR Lai
ericr_lai@compal.corp-partner.google.com
Gerrit-Reviewer: Felix Singer
felixsinger@posteo.net
Gerrit-Reviewer: Lean Sheng Tan
sheng.tan@9elements.com
Gerrit-Reviewer: Patrick Rudolph
siro@das-labor.org
Gerrit-Reviewer: Tim Wawrzynczak
twawrzynczak@chromium.org
Gerrit-Reviewer: Werner Zeh
werner.zeh@siemens.com
no-reply@coreboot.org
Gerrit-CC: Arthur Heymans
arthur.heymans@9elements.com
arthur@aheymans.xyz
Gerrit-CC: Paul Menzel
paulepanter@mailbox.org
Gerrit-CC: Rizwan Qureshi
rizwan.qureshi@intel.com
Gerrit-CC: Sridhar Siricilla
sridhar.siricilla@intel.com
Gerrit-Attention: Arthur Heymans
Gerrit-Attention: Felix Singer
Gerrit-Attention: Subrata Banik
Gerrit-Attention: Tim Wawrzynczak
Gerrit-Attention: Angel Pons
th3fanbus@gmail.com
arthur@aheymans.xyz
Gerrit-Attention: Lean Sheng Tan
Gerrit-Attention: Werner Zeh
Gerrit-Attention: Patrick Rudolph
siro@das-labor.org
Gerrit-Attention: EricR Lai
Gerrit-Comment-Date: Wed, 09 Feb 2022 03:25:12 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Subrata Banik
Comment-In-Reply-To: Sridhar Siricilla
Comment-In-Reply-To: Arthur Heymans
arthur@aheymans.xyz
Comment-In-Reply-To: Lean Sheng Tan
Gerrit-MessageType: comment
