Attention is currently required from: Tim Crawford, Tim Wawrzynczak, Patrick Rudolph. Hello build bot (Jenkins), Tim Wawrzynczak, Patrick Rudolph,
https://review.coreboot.org/c/coreboot/+/56867
Change subject: soc/intel/tgl: Allow setting PCIe subsystem IDs after FSP-S ......................................................................
Prevent the FSP from writing its default SVID SDID values of 8086:7270 for internal devices as this locks most of the registers. Allows the subsystemid values set in devicetree to be used.
A description of this SSID table override behavior, along with example code, is provided in the TigerLake FSP Integration Guide, section 15.178 ("SI_CONFIG Struct Reference").
The xHCI and HDA devices have RW/L registers rather than RW/O registers. They can be written to multiple times but cannot be modified after being locked, which happens during FspSiliconInit. Because coreboot populates subsystem IDs after SiliconInit, these devices specifically must be written beforehand or will otherwise be locked with their default values of 0:0.
TGL also introduces parameters for customizing the default SVID:SSID. These must be set or it will still use the FSP defaults.
Tested by checking lspci output on System76 darp7 (TGL-U).
References: - b1fa231d76a ("soc/intel/cnl: Allow setting PCIe subsystem IDs after FSP-S") - TigerLake FSP Integration Guide - Intel Document #631120-001
Change-Id: I391b9fd0dc9dda925c1c8fe52bff153fe044d73e Signed-off-by: Tim Crawford tcrawford@system76.com --- M src/soc/intel/tigerlake/fsp_params.c 1 file changed, 55 insertions(+), 0 deletions(-)
git pull ssh://review.coreboot.org:29418/coreboot refs/changes/67/56867/2
