Attention is currently required from: Tim Wawrzynczak, Angel Pons, Arthur Heymans, Nick Vaccaro, Eric Lai, Lean Sheng Tan, Werner Zeh.
Subrata Banik has posted comments on this change. ( https://review.coreboot.org/c/coreboot/+/63692 )
Change subject: soc/intel/alderlake: Implement PCH lock down configuration
Patch Set 4:
File src/soc/intel/alderlake/lockdown.c:
https://review.coreboot.org/c/coreboot/+/63692/comment/9791754c_fcd608cc
PS4, Line 41: if (CONFIG(USE_FSP_NOTIFY_PHASE_POST_PCI_ENUM))
: return;
: /* Enable IOSF Primary Trunk Clock Gating */
: pcr_rmw32(PID_PSTH, PCR_PSTH_CTRLREG, ~0, PSTH_CTRLREG_IOSFPTCGE);
In CB:63640 the logic is inverted.To stay consistent it would look like:
if (!CONFIG(USE_FSP_NOTIFY_PHASE_POST_PCI_ENUM))
But up to you.
yeah, I did that to avoid braces and indentation @Werner, do you think this is reasonable ? with CB:63640, the entire `pmc_lockdown_cfg` function we are not skipping when `USE_FSP_NOTIFY_PHASE_POST_PCI_ENUM` is selected, hence had to use `invert` logic there
To view, visit
Gerrit-Project: coreboot
Gerrit-Branch: master
Gerrit-Change-Id: Ie28dde8f62adc5bafc4a42e608827f51da82570c
Gerrit-Change-Number: 63692
Gerrit-PatchSet: 4
Gerrit-Owner: Subrata Banik
subratabanik@google.com
Gerrit-Reviewer: Angel Pons
th3fanbus@gmail.com
Gerrit-Reviewer: Arthur Heymans
arthur@aheymans.xyz
Gerrit-Reviewer: Eric Lai
eric_lai@quanta.corp-partner.google.com
Gerrit-Reviewer: Lean Sheng Tan
sheng.tan@9elements.com
Gerrit-Reviewer: Nick Vaccaro
nvaccaro@google.com
Gerrit-Reviewer: Tim Wawrzynczak
twawrzynczak@chromium.org
Gerrit-Reviewer: Werner Zeh
werner.zeh@siemens.com
no-reply@coreboot.org
Gerrit-Attention: Tim Wawrzynczak
Gerrit-Attention: Angel Pons
th3fanbus@gmail.com
Gerrit-Attention: Arthur Heymans
arthur@aheymans.xyz
Gerrit-Attention: Nick Vaccaro
nvaccaro@google.com
Gerrit-Attention: Eric Lai
Gerrit-Attention: Lean Sheng Tan
Gerrit-Attention: Werner Zeh
Gerrit-Comment-Date: Fri, 22 Apr 2022 07:30:10 +0000
Gerrit-HasComments: Yes
Gerrit-Has-Labels: No
Comment-In-Reply-To: Werner Zeh
Gerrit-MessageType: comment
